What tyre spec on DTM's
Mitch
Car Model: MK6 GTI
Membership No: 1840
Post by Mitch » Fri May 05, 2017 11:19 am
I currently have 225/40/18 (stock tyre size) all round. When I rotated the tyres, putting the better tread tyres upfront, there is quite an unpleasant amount of rubbing. The car is a daily and it was liveable with fairly worn down tyres. I need to put 2 new tyres in the front.
What profile should I go for that will trim down the tyre a bit. My car isn't extremely low, but the fitment of the DTM's is a bit more aggressive.
Pic below for ride height. I can go lower if I can get the front to stop rubbing.
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Re: What tyre spec on DTM's
Post by Neuk » Fri May 05, 2017 11:23 am
What is the ET difference between the stock 18" wheels and the DTM wheels? What are the specs of the DTM wheels?
Nic
Daily Drive: 2015 VW Golf R
Mitch
Car Model: MK6 GTI
Membership No: 1840
Post by Mitch » Fri May 05, 2017 11:27 am
8J I can't remember the offset.
I remember working it out to be either 15mm or 20mm or thereabouts more stickingoutness than the stock wheel.
The tyres now touch when driving over harsh bumps or dongas. And some speedhumps.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk » Fri May 05, 2017 11:32 am
Mitch wrote:8J I can't remember the offset.
There is your problem, the 15mm or 20mm ET difference and I think the stock wheels are only 7.5J?
Nic
Mitch
Car Model: MK6 GTI
Membership No: 1840
Post by Mitch » Fri May 05, 2017 11:39 am
Yeah i know that is the problem. Which is why i want to fit smaller tyres. Not stretched, but a little less meat. The wheels have a near flush fitment
JasonCPT
Car Model: A4 1.8T
Post by JasonCPT » Fri May 05, 2017 11:47 am
215/40 should be fine. I run them on my 9j's with no issues (they are stretched).
2004 B6 Audi A4 1.8T - Atlas Grey
FK Automotive | Forge | Jaylan Performance | Zeetech Customs | VAGAS | Ratchet Garage
NHB_R
Post by NHB_R » Fri May 05, 2017 11:49 am
You can also machine 5mm off the wheel itself? Should the tyre change not be a viable route.
I would prefer to keep as much rubber on as possible
Howie-WP
Membership No: 2033
Post by Howie-WP » Fri May 05, 2017 11:55 am
Mitch wrote:The tyres now touch when driving over harsh bumps or dongas. And some speedhumps.
I had the same on my Mk5 with the DTM's with the same tyre size, I did the front fender mod (screw and lip) and that helped a lot. Also you can roll fenders.....
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk » Fri May 05, 2017 11:58 am
I would rather address the issue than put a band aid on it but that is just me. A slightly narrower tyre like @JasonCPT suggests might help a bit and it shouldn't stretch too much on an 8J.
Nic
Post by panic-mechanic » Fri May 05, 2017 12:27 pm
Yup fix it by raising the thing a little. It already looks like the suspension is broke as it stands there. :smile:
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Mitch
Car Model: MK6 GTI
Membership No: 1840
Post by Mitch » Fri May 05, 2017 12:30 pm
panic-mechanic wrote:Yup fix it by raising the thing a little. It already looks like the suspension is broke as it stands there. :smile:
I am trying very hard to not do this. If anything I would like to make it lower occassionally.
Post by panic-mechanic » Fri May 05, 2017 1:06 pm
Honestly this is one thing where i just about differ with probably 90% of people here. I like cars with usable and working suspensions.
Turning a car into a uncomfortable scraping useless piece of junk that looks like carp to me anyway is something I just don't get.
That 'look' I hate and what it actually does to,cars in terms of damage I hate even more. To me if you want that look then stick it on air for when you feel you should show off or whatever it is called and then pick the thing up to a comfortable safe for the car and conditions height for everyday use. This dragging it's arse on the ground like a scooting dog all the time is just stupid. It damages suspension parts and underbodies all the time.
'07 Audi A4 2l TDI
ICE King
Post by ICE King » Fri May 05, 2017 1:51 pm
panic-mechanic wrote:Honestly this is one thing where i just about differ with probably 90% of people here. I like cars with usable and working suspensions.
This! :hurray: someone said it
Whats the point of modding a car literally broken and making it impractical to be used as a vehicle.
To answer the OP's question, A narrower Tyre is the easiest option apart from raising the car abit.
Rides:
Mitch
Car Model: MK6 GTI
Membership No: 1840
Post by Mitch » Fri May 05, 2017 2:34 pm
Different strokes for different folks. I prefer the look of a lowered car, so i lower my car. I'm hesitant on a narrower tyre though. will try lifting it up a little bit, just to help clearance with new tyres.
FWIW i drive my car about 3000km a month, at this height (for the last 1.5 years or so), and it hasn't been an inconvenience to be low.
ICE King
Post by ICE King » Fri May 05, 2017 3:35 pm
Fully understand and that's fair bro. everyone has their own traits. The look does look tits when lowered.
Rides:
Post by panic-mechanic » Fri May 05, 2017 5:41 pm
slightly lowered they look nice. half the tyre hidden by the wheel arch. Nope.
'07 Audi A4 2l TDI
