Need some info on building a propper 2l bottom end
Hi guys hope you all doing well!
I want to upgrade on my caddy's 2l 8v bottom end. Stil stock standard at this stage. I heard some one saying 2.3 caravelle pistons wil make a huge differance but not sure if it is the right way to go. Any guidens would be highly appriciated. Running on 282 estas cam with dicktator management and the std bottom now. Keep in mind it is my daily driver.
Thanks in advance!
Thanks in advance!
- chucker02
- Car Model: Citi ADY
Re: Need some info on building a propper 2l bottom end
Build a 2.1 with a tdi crank, heard that it makes the most difference and adds alot of torque.
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
2003 Audi A3 1.8t
So I need the 1.9 tdi crank for that and whet pistons do I need?chucker02 wrote:Build a 2.1 with a tdi crank, heard that it makes the most difference and adds alot of torque.
- Car Model: '16 Golf 7R, 86 Caddy 16V ITBs
The std 2l bottom end is strong enough if you want 2l.
Focus on the head to get more power. You did not state any orher mods to head apart from 282 estas cam. A port and flow with work done to the valves and branch would free up more ponies. If you decide to skim the head to increase compression, don't skim morr than 0.5 mm from std or you may need to add fuel additives.
Other than that, chucker02 has said you can go for a 2.1l motor and still need to do supporting mods to the head to get the most out of the motor and not just by fitting a cam.
Search around on the forum and you will find more info regarding such a conversion. CA18 nissan pistons are used, but only on 16v conversions as the 16v head has a larger combustion chamber. Afaik a bmw piston can be used for a 8v 2.1l conversion, but can't recall which one. Get in touch with Torker here on the forum or Sarel 8v performance. They should be able to give you the correct info.
Thanks for the advice! I will do some home work and go from there.PapaJo wrote:The std 2l bottom end is strong enough if you want 2l.
- Car Make: Isuzu
- Car Model: KB250 LE 2006
I've been looking at a bunch of different conversions lately and Apparently this mod eats bearings , but I'm by no means an expert just giving a heads up .chucker02 wrote:Build a 2.1 with a tdi crank, heard that it makes the most difference and adds alot of torque.
I spoke to Nellis today and he has head which was done by Mike Dixon and from some of my connectons and was told it will be a wise choice to go for it. As far as the bottom end, it will be on hold for now.
I picked up another bugger-up today. When driving at 200km/h for about 50km the engin pushes a bit of oil out at the breather, is this normal on these 2l engins or where should I look for the cause?
I fitted new rings and big-ends and did propper honing on the sleeves. There was no ridge on the sleeves and drove gently for the first 1000km befor doing the dyno. Motor engineering did the head and messed it up so they gave me a 1.6 head which I had to reem the intake in order for the injectors not to squirt against the head. The valve stems was replaced but not the guids. Could this also cause the engin to breath as much?
Above all there is no problem with power or excelleration.
By the way! Thanks for all the advice and support so far, nice to get some honest opinions from guys with experience on these engins.
When motor was assembled, did you install the plastic oil splash cover that fit over the cam below the tappet cover?
How is the breather on the block connected? Going to an oil catch tank with breather filter on?
- THANAS
- Car Model: MkV Jetta TFSI Sportline
- Membership No: 2035
More importantly where do you live that you can do 200 kph for 50 kms?
__THANAS
__
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
__
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__CCBB ADY Citi
Northern cape postmasburg, no cops around except in December around Christmas. The bottom breather is blanked of and on top only the filter. Yes the splashplate in the top is in place! No oul catch tank fitted yet, howeve I did order one.
What happens if you unblock the bottom breather? Things are put there by the engineers for a reason.The bottom breather is blanked of and on top only the filter
1977 Datsun 1200GX
Ex car: 1994 Citi golf CTI
56mm Freeflow exhaust system.
Stock motor.
Wife's car: 2010 Chevrolet Spark 800cc
1977 Datsun 1200GX
Stock motor.
It gets worse!
But below 5k rpm no problems! Only when driving at very high rpm for a period of time.
I'm no expert. Lets wait for the experts to comment but that sounds like a ring seal problem at high revs/high pressure.
How many km on the block?
1977 Datsun 1200GX
Stock motor.
1977 Datsun 1200GX
Stock motor.
- vadia
- Car Make: vw,nissan,merc
- Car Model: mk1,np300,c200 amg,gti7
hi when i cracked my no1 piston on my 1.8 afv block rebored 20thou it pissed oil out off both breathers and it was turbo charged
opel monza cd
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
- 104bpm
- Car Model: '98 Golf 1
Lmao!THANAS wrote:More importantly where do you live that you can do 200 kph for 50 kms?
Not sure. Bought it with the block.
Open that bottom breather. It is ther for a reason.corney wrote:Northern cape postmasburg, no cops around except in December around Christmas. The bottom breather is blanked of and on top only the filter. Yes the splashplate in the top is in place! No oul catch tank fitted yet, howeve I did order one.
Nope, decided to gather all the parts and then rebuild the whole engin from top to bottom. Rebore, cut crank, blueprint and get a head from Mike dixon. I believe that is the surest way to make sure it runs perfect.
Any sugestions on who does propper porting and flowing? I heard Mike Dixon does a great job on the vw heads. Don't want to make another mistake
The breather is the only issue and yes all engines will breathe when you work them that hard. It is pretty normal.
Open the bottom breather, put it into a bottle and empty it out now and then.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
'07 Audi A4 2l TDI
Will try it and give you feedback on the results. Thanks for the advice!
