Newbie needs roofing help
Moe_G10
Post by Moe_G10 » Mon May 01, 2017 3:29 pm
Hi guys. I've just joined the forum and I'm hoping someone can help me with the sunroof troubles I've been having. Water is leaking down the front right hand side drain and I can't find the drain. I see the water trailing down from the fender and it looks like it's somewhere underneath the bonnet but no luck in finding it. I'm about to search the forum to see if anyone else has had the same problems but I thought I'd introduce myself at the same time.
I'm from the Gauteng and I drive a Polo MK4 that's not housing me from excessive rain
Supervan II
Car Make: SEAT
Re: Newbie needs roofing help
Post by Supervan II » Tue May 02, 2017 4:17 pm
Use the search function
Or even: Google it. This was the first suggestion!
Post by panic-mechanic » Wed May 03, 2017 9:10 am
What is a polo mk4. Pictures?
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
amstel18
Car Model: Polo TSI
Post by amstel18 » Wed May 03, 2017 9:15 am
panic-mechanic wrote:What is a polo mk4. Pictures?
https://en.wikipedia.org/wiki/Volkswagen_Polo_Mk4
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Moe_G10
Post by Moe_G10 » Wed May 03, 2017 9:23 am
Same, just the face-lift one. 9N3 I think.
Okay so from what I've read here is that you find a speedometer cable or a curtain wire and shove it down the drain. I've noticed the right side water goes down slower than the left so obviously the drain is blocked. The water exits from the boot drainage plug instead of the front as the left hand side does. I managed to get some curtain wire and I shoved it down the drain but I didn't manage to get it down fully. It's as if something is blocking. Should I try compressed air? Or something else. I dunno any recommendations?
Moe_G10
Post by Moe_G10 » Wed May 03, 2017 9:24 am
And that's her with the sunroof problems.... Image
Post by panic-mechanic » Thu May 04, 2017 6:47 am
Ah 9n3. You can try compressed air but maybe first try thinner wire than curtain and see if you can't get past the obstruction.
'07 Audi A4 2l TDI
spdgti
Post by spdgti » Thu May 04, 2017 9:29 am
'08 06 Magma Orange Cross Polo
ex: Reflex Silver GTi-R
