Hi
I'm a owner of a golf 4 tdi aswell.Currently i'm having a problem with performance and i'm not sure if it relates to the turbo. I have recently done a major service at VW.When i drive at about 120-130km i can feel the mist on the car and then all of the sudden i loose power totally,like there's no turbo or something.Please assist on recomendations.
Problem with Turbo/Performance
- Registered for: 19 years 2 months
I have very limited turbo diesel knowledge but my boss drives one and has had two problems. The first time there was a problem with the boost and it was a sensor in the air box that needed replacing. Apperently it gets damp and vw does a modification to the air box . It is a common problem on the earlier tdi or so the mechanic told him.
The second problem was total loss of power and after the mach said the turbo had failed it turned out it was a split boost pipe.
Hope this points you in the right direction .
- Registered for: 21 years 3 months
- Membership No: 731
yeh u talking about the MAF sensor in the airbox/intake. HATES water. Mine went a while ago.
It is a very common problem on the MK4 TDI's. U cant disconnect the MAf and see if she goes better, if she does then u know its that.
Otherwise u could get someone to run logs of the airflow. Mine was fine until the turbo really started boosting and then it just registered hardly any airflow and cut the boost right down.
Turbo....Look for change in the sound of the turbo while boosting.
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
"We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. So we build VDubs son..."
"Owning a MK1 varies between having sex to getting hit in the balls. Usually several times in one day."
1966 Splitty.
No Mk1 ;(
