Polo 1.4 TDi engine shaking
tau86
Postby tau86 » Sun Apr 30, 2017 2:52 am
Hi Everyone,
I am from Maseru, Lesotho and new in the forum, thanks for welcoming me. I have a polo 1.4 tdi which is at a mechanic now I drove for a day and the parked, after about 30 mins when I started it the engine started to shake very bad. There is no smoke coming out at exhaust but idling is not constant...goes po-porr...po-porr. Took it for diagnosis and says short curcuit/injector valve not opening for cylinder 1. Took injector to Pretoria to be checked and they said its fine. Put it again back..drove for a day and snap back again. diagnosis read same thing again. What could be happening here? by the way, revs are okay
Re: Polo 1.4 TDi engine shaking
Postby panic-mechanic » Sun Apr 30, 2017 7:20 pm
wiring harnass error. Is it the 3 cyl PD tdi?
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
tau86
Postby tau86 » Sun Apr 30, 2017 7:30 pm
Yes...its a 3 cylinder... AMF engine
Postby panic-mechanic » Mon May 01, 2017 9:59 am
check or replace the wiring harnass in the head leading to the injectors. Common issue on them.
'07 Audi A4 2l TDI
tau86
Postby tau86 » Mon May 01, 2017 2:52 pm
Okay, will do so. Can also the injector pump on the right side of the engine cause this issue?
Postby panic-mechanic » Mon May 01, 2017 9:14 pm
no the pump just makes pressure and the injectors are fired electrically. If the other 2 are working the pump is fine.
go read this to get a better understanding of the system
http://pics.tdiclub.com/data/516/VW_TDI ... peDuse.pdf
'07 Audi A4 2l TDI
tau86
Postby tau86 » Thu May 04, 2017 8:49 pm
I am back, i cleaned the harness with Q20 and it didn't change. However, we found that the injector seal was the one with issues. There is no shaking now, we just did a small fix on the seal so I still need to get a new one with o-rings (machenic recommended). So all in all the engine runs perfectly apart from now I hear a qha qha qha sound when I drive...but its not there whn i rev engine on neutral or car idling...only whn i drive
Return to “TDI Engines”
Users browsing this forum: No registered users and 15 guests
