2009 jetta 1.9 tdi
Mr.G24
Car Model: MK5 Jetta 1.9 TDi Comfortline
2009 jetta 1.9 tdi
Post by Mr.G24 » Thu Apr 27, 2017 10:40 pm
Hi
I bought a 2009 jetta 1.9 tdi with a bxe engine and has 190 500km on the clock,all services hs been done and car very well looked after.here and there a couple of things needs attention and i have some questions....
I read on the forum that a decat help turbo life and gives a bit better fuel consumpion.i'm thinking of doing the decat,but only that,no backbox delete and the like for now.will this be wise with such high km?will only the decat give a bit better throttle response and slight exhaust sound change,nothing else?
Is there anything else i can do except a software upgrade,any other hardware upgrades that would be beneficial and does not cost an arm and a leg?
Does these motors have a EGR to blank off and what is the pro's of this?
Also does this diesel have the Diesel particulate filter and whatnis the function of that?
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
Mr.G24
Re: 2009 jetta 1.9 tdi
Post by Mr.G24 » Sun Apr 30, 2017 7:46 am
So is a decat good to do on my jetta that has such high mileage?what is this EGR blank off and de-activation of it and does my jetta have a diesel particulate filter and what is the use of this part.
77kw @ 4000
250nm @ 1900
Pynoxim
Car Make: SEAT
Car Model: Rotten Ibiza
Post by Pynoxim » Sun Apr 30, 2017 10:49 am
Do the oil pump when you have a chance before anything else if it hasn't been done yet. My colleagues mint BXE 1.9TDI sent a rod through the block due to oil pump failure, turns out it's a common issue.
Thursday Milkshake Crew
'00 GS2 Lexus GS300
Tdi jetta 4 ever
Car Model: Jetta 4 1.9 Tdi, Isuzu2.5DKBLe
Post by Tdi jetta 4 ever » Tue May 16, 2017 10:37 am
It will only be a good thing to decat especially on that amount of km's. Turbo will run cooler. EGR blank off i cannot comment.
Robin
Current rides: 02' Jetta 4 1.9 Tdi, 99' Isuzu KB 250 Dle(Faithfull aka slowmo) Audi A4 B7 2.0 Tdi Multitronic(non runner)
Mr.G24
Post by Mr.G24 » Wed May 17, 2017 7:42 am
thanks so much for the feedback guys. i don't want the car to sound to loud, but can i only do the decat and leave the middle silencer and back silencer in or can i take the middle silencer out as well? i will leave the back silencer otherwise i can only think that it's going to be loud, i just want to free up the turbo a bit and get that nice turbo sound via the exhaust.
77kw @ 4000
250nm @ 1900
Post by panic-mechanic » Wed May 17, 2017 9:05 am
Cat does nothing to the sound. If you want noise you have to remove a silencer. If you decat for noise you are doing it for the wrong reason.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
jimbo
Car Model: MK5 1.9 TDI DSG
Post by jimbo » Wed May 17, 2017 11:17 am
FYI - the bxe engine only has one sliencer.
I recently had the decat done on mine, only the cat and the rear silencer no middle silencer (on my golf at least)
I also agree with Panic, the decat doesn't do much for the 'turbo sound'.
Sent from my LG-H815 using Tapatalk
Mr.G24
Post by Mr.G24 » Wed May 17, 2017 12:01 pm
understood,i'm herre to learn about these things, as i don't have an idea about these things, that is why i ask,i note that the de-cat will only let the turbo run cooler and also does not have that restriction of flow when having a cat , mine does have a cat, middle silencer and rear silencer.Will remove the cat and the middle silencer as well.
thanks for the feedback.
77kw @ 4000
250nm @ 1900
THANAS
Car Model: MkV Jetta TFSI Sportline
Membership No: 2035
Post by THANAS » Wed May 17, 2017 12:06 pm
Keep the whole system, ask for it to be cut off in places that it can be welded back together easily, go straight pipe and if it's too much, you can put the rear box back on and/or middle box.
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
