8v bottom with 16v head
mike65
Car Model: mk1
Postby mike65 » Fri Apr 21, 2017 3:10 pm
Howsit gents ive been searching here for a build tread on this topic but cant seem to find one.
oks a 16v motor is +- 15k which i dnt have cash.What i do have is a ADY complete bottom end and hopefully geting my 16v head by tomorrow.
I know most of the things i need for this conv but would just like to verify it.
All parts i need are pulleys? uno dizzy cap? 16v oil pump?(think ima mod the 8v oil pump) new service kit? pistons? mod mp9 rail or 16v modded one and management? anything else im missing?
Then could anyone give me some more info on decent mods to get around 125kw out of the motor?
my 1st mod will be the ca18 pistons :drool:
Watch this space
Car Make: VW, VW, Aprilia
Car Model: Mk2, Mk3, Aprilia Tuono V4
Re: 8v bottom with 16v head
Postby Jetta2 » Fri Apr 21, 2017 3:13 pm
It has been discussed to death a million times on the forum - 16V head + 8V bottom end = 8.5:1 compression ratio which is perfect for boost.
You will need 16V pistons if you are planning on running naturally aspirated.
1989 Mk2 Jetta 2.0 8V-T
2013 Aprilia Tuono V4 APRC
Postby panic-mechanic » Fri Apr 21, 2017 3:27 pm
Where exactly does the uno dissy cap feature?.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
PapaJo
Car Model: '16 Golf 7R, ´86 Caddy pick-up
Postby PapaJo » Fri Apr 21, 2017 11:00 pm
mike65 wrote:Howsit gents ive been searching here for a build tread on this topic but cant seem to find one.
As Jetta2 said, many of those posts on this forum.
Search for Torker on the forum and you find very much of the info you need on his build threads.
Uno dizzy cap like this one. Will not fit on ABF 16v dizzy as the ABF dizzy utilize 2 screws to hold the cap down. It works on the KR 16v dizzy.
PapaJo
Postby PapaJo » Fri Apr 21, 2017 11:04 pm
On a second thought........ the ADY motor has a 60-2 crank sensor and choose the right management system (60-2) and run coils pack on wasted spark. No need for a dizzy or Uno cap.
DotDubb
Can I buy your wheels?
Car Make: 2007 Velociti
Car Model: Ranger,Fortuner
Membership No: 1593
Postby DotDubb » Sat Apr 22, 2017 9:29 am
You have a lot of possibilities with mods, I'm a sucker for a 16v N/A
Here is my mods done to my 16v:
BMW 84mm pop up pistons
TDI crank
Stage 3 flow from 8v Performance
Solid lifter
288 exh,276 int vanderlinde cams 11.8mm lift
Dictator management
Poy Special gearbox
+ a few odds and ends
All built by Sarel from 8v Performance
Great motor with tons of torque right through the rpm range.
'07 Velociti 2.1 1.6v 133wkw 210nm - IN PROGRESS -Bloody Mary
'60 DKW 1000s - OLD Audi
'07 Polo Gti Etuners stg2+ - Olop GiT
'80 2door MK1 2.0 8v MP9 - Hot chocolate
mike65
Car Model: mk1
Postby mike65 » Mon Apr 24, 2017 12:11 pm
jetta2 i have said i need the 16v pistons and im fitting the ca18 pistons its 83mm
It is a kr head and not an abf.
PAPAjo ill need some more info on that never knew that.
Dotdubb thats more or less what im looking for or anything that will give me 125kw or more...just not turbo.
Watch this space
PapaJo
Postby PapaJo » Mon Apr 24, 2017 12:17 pm
You will need to check the piston crown to head clearance if you go 83mm on KR head.
Browse the forum for 60-2 builds.
Return to “N/A Engines”
Users browsing this forum: No registered users and 15 guests
