TIG Welded exhausts and downpipes
ob wan
Car Model: MK1 2.0 16vT
Post by ob wan » Wed Mar 29, 2017 9:23 am
I'm looking into manufacturing exhausts, downpipes and boostpipes from stainless steel, what does the need in the market look like? would it keep me busy?
will be in the centurion area
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
Aslam_MK4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Re: TIG Welded exhausts and downpipes
Post by Aslam_MK4 » Wed Mar 29, 2017 9:28 am
If your prices are good and the quality is great you would go far
Word of mouth is where it's at nowadays in business
Bagged mk4 2dr
"Ride or die"
-=sT3V3=-
Car Make: ShitiGolf + CRX
Car Model: 92' ADY + 91' B20Vtec
Post by -=sT3V3=- » Wed Mar 29, 2017 9:35 am
if you become the go to guy on the forum for stainless exhausts that will generate a decent stream of clients.
Do you have a shop currently?
Post by panic-mechanic » Wed Mar 29, 2017 9:41 am
As a sideline you will survive. As your only income, don't think the market is big enough in southa frica and it will take a long time and a lot of work and word of mouth before somebody with a million and some bmw will drop it there and order an obwan instead of an acrapovic.
Too much snob value to rather import milltek and acra in this country although i think it is stupid and over rated.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
ob wan
Post by ob wan » Wed Mar 29, 2017 10:04 am
planning on getting a shop sometime soon, with a lift, all the other groceries I already have
05 G5 Gti (ex)
97 LSvtec (ex)
-=sT3V3=-
Post by -=sT3V3=- » Wed Mar 29, 2017 10:30 am
What is your capacity for work currently?
Panic has some good points, most guys only ever need a good full exhaust once per project :|
ob wan
Post by ob wan » Wed Mar 29, 2017 10:36 am
currently not very busy coz I don't have floor space, but I'm busy negotiating for a spot in a workshop with a lift, then I can tackle it full steam
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Mar 29, 2017 10:55 am
Maybe just some background, I used to work for an exhaust company for about 4 years when I was younger, so I now the inner workings of gas flow and all that, the types of exh's that I want to build will be the specialist type, not just freeflows for tazz's and citi's...
have built my fair share of exh's and boostpipes in the past, just never had a TIG to do clean welds like just a TIG welder can do, now I'm almost surgical with it... :-)
05 G5 Gti (ex)
97 LSvtec (ex)
Post by panic-mechanic » Wed Mar 29, 2017 10:59 am
Lift You can get second hand around 10-15k if you look around.
Shop costs rent see if you can't backyard it for a while.
It's that rent that kills you in the beginning.
'09 Audi Q5 3l tdi
ob wan
Post by ob wan » Wed Mar 29, 2017 11:49 am
backyarding it will be ideal, want to lay down a concrete slab for the lift, I really want to work from home... just scared of the "back yard" stereo type created...
05 G5 Gti (ex)
97 LSvtec (ex)
amstel18
Car Model: Polo TSI
Post by amstel18 » Wed Mar 29, 2017 1:29 pm
ob wan wrote:backyarding it will be ideal, want to lay down a concrete slab for the lift, I really want to work from home... just scared of the "back yard" stereo type created...
Don't be scared. It's going to be a word of mouth business in any case as your average joe isn't going to pay good prices for their tazz...
I've seen some of the better jobs coming out of a back yard. Then there use to be a tuning shop in CPT that you could eat from the floor type of place and I only heard bad things about it.
So ja, you don't need a grand setup in the beginning... Just document your past work which you could send/share as reference.
Cause if I was in the market and you can show me this:
Then you better be sure to provide that and not this Image whilst promising the above :lol: :lol:
Good luck with the venture!
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
THANAS
Car Model: MkV Jetta TFSI Sportline
Membership No: 2035
Post by THANAS » Wed Mar 29, 2017 2:05 pm
There is definitely a market for reasonably priced, bolt on turbo manifolds/boost pipe and cooler kits. Many people want turbo and cooler/piping upgrades but are wary of having the car sit for weeks while manifolds and piping are made from scratch. The result is the use of inefficient cast systems or importing from eBay. Vehicle specific and turbo specific bolt on kits are where it is at.
I.e. Bottom mounted GT28 tubular manifold for PGTi/1.8T. And boost pipe/cooler kits that actually fit and don't require grills and crash bars to be cut.
It takes more RnD to make but in the end that time is saved once the jigs are made. The future is in well made bolt on kits.
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
Post by panic-mechanic » Wed Mar 29, 2017 6:46 pm
Problem with bolt on kits are that they are turbo specific. so you dictate what turbo has to be used..
'09 Audi Q5 3l tdi
jaredm01
Post by jaredm01 » Wed Mar 29, 2017 7:46 pm
I agree with Panic, do it from home for now so you don't over commit. Spend some time marketing your stuff on social and digital media, if you do it well people will recommend you. Kits like intercooler kits, throttle, discharge, down pipes, etc are also a good place to look into. There will be more money there than custom BT manifolds.
chucker02
Car Model: Citi ADY
Post by chucker02 » Wed Mar 29, 2017 10:02 pm
THANAS wrote:There is definitely a market for reasonably priced, bolt on turbo manifolds/boost pipe and cooler kits. Many people want turbo and cooler/piping upgrades but are wary of having the car sit for weeks while manifolds and piping are made from scratch. The result is the use of inefficient cast systems or importing from eBay. Vehicle specific and turbo specific bolt on kits are where it is at.
Yes please, someone needs to start building these kits properly
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
ob wan
Post by ob wan » Sat Apr 22, 2017 3:20 pm
managed to secure some space in a shop at Zwartkops (rent free just profit sharing for now) with access to a CNC plasma cutter so I can cut all the necessary flanges, off to the bank next week to get some coins for a lift then it's game time! so the main focus of business will be downpipes, turbo manifolds, exhausts and boost pipes... looking at building rollcages in the near future too...
exciting times ahead
05 G5 Gti (ex)
97 LSvtec (ex)
chucker02
Car Model: Citi ADY
Post by chucker02 » Sat Apr 22, 2017 3:43 pm
Thats awsome bud, all the best with the new venture
2003 Audi A3 1.8t
ob wan
Post by ob wan » Sat Apr 22, 2017 4:01 pm
thank you sir, forgot to mention the log type turbo intake manifolds that we'll be building aswell
05 G5 Gti (ex)
97 LSvtec (ex)
stig
Car Model: Polo 1.9 TDi Highline 96KW
Membership No: 2083
Post by stig » Sat Apr 22, 2017 5:46 pm
Good luck. Ps. Build some tubular manifolds for BT tdi conversions. Like the darkside ones. Guys would buy them like sweet cakes
The Ride:
H&M Dyno Night: 114KW 429NM
ob wan
Post by ob wan » Sat Apr 22, 2017 5:48 pm
stig wrote:Good luck. Ps. Build some tubular manifolds for BT tdi conversions. Like the darkside ones. Guys would buy them like sweet cakes
will definitely look into that, thanks
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Thu May 04, 2017 3:22 pm
image uploading not working....
05 G5 Gti (ex)
97 LSvtec (ex)
stig
Membership No: 2083
Post by stig » Thu May 04, 2017 9:56 pm
U using photobucket?
The Ride:
1.8iblackie
Car Model: vw polo classic. NO ENGINE
Post by 1.8iblackie » Sun May 07, 2017 11:31 am
Check out ELECTIG EEL on facebook.
8vT 187.2kW and 361Nm
ob wan
Post by ob wan » Sun May 07, 2017 1:15 pm
stig wrote:U using photobucket?
yes
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Sun May 07, 2017 1:19 pm
05 G5 Gti (ex)
97 LSvtec (ex)
