Polo 1.2 Bluemotion EGR removal/deactivation and DPF removal
lukesky
Registered for: 8 years 8 months
Post by lukesky »
Which is a good place in cape town to do the above work and what are the other options with regards to the egr value and DPF removal or deactivation?
Also I noticed that the stop/start function does not work any work more, when the car went for a diagnostic the only apparent issue was egr value?
Re: Polo 1.2 Bluemotion EGR removal/deactivation and DPF rem
Say thanks that the stop start does not work. Those things just eat starters batteries and flywheels.
Kaapse Piesang
Car Model: 2013 Polo 1.2 tdi
Post by Kaapse Piesang »
Hi, I have the same problem...VW Dealer diagnosed my Tdi with replacing the DPF filter @ R37k
My car is a 2013 with 180000kms.
I have three warning lights on and I am driving around in limp mode.
What are my options?
Please help !
Mario@C-TEQ
Post by Mario@C-TEQ »
I can assist in CPT, Ive done many DPF deletes/Removals.
Mario
sales@c-teq.co.za
0727467415
gatshi
Registered for: 8 years 7 months
Car Model: 1.2TDI Polo 6R CFWA
Post by gatshi »
My Polo 1.2 TDI 2012 DPF has been removed by a uninformed mechanic. Now I have fault codes: P2463 and P2563. Coil light, exhaust light and engine light on with limp mode permanently.
The turbo was repaired before the DPF was removed.
Is the P2563 FAULT code caused by the DPF that was removed? There isn't vacuum on the actuator. The N75 valve has been replaced. Still looks like the N75 is not switching on. If I put vacuum manually on the turbo actuator then the actuator moves.
Sigh. Any ideas? Any one with a similar problem?
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
You cannot simply remove the DPF without coding out the DPF in the ECU. Get the DPF coded out and your error lights will go away.
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
gatshi
Post by gatshi »
Hi, yes I know the ECU has to be remapped, but the ECU is a Delphi DCM3.7. According to everyone I asked, can't be remapped.
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
gatshi wrote:Hi, yes I know the ECU has to be remapped, but the ECU is a Delphi DCM3.7. According to everyone I asked, can't be remapped.
You asked the wrong people, See Mario's response above, give him a call. There are a few tuners that can help you
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
ETunersSA
Registered for: 16 years 10 months
Car Model: ******
Post by ETunersSA »
VAG Delphi DCM3.7 cannot be remapped unfortunately.
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
ETunersSA wrote:VAG Delphi DCM3.7 cannot be remapped unfortunately.
Even if bench Flashed?
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
gatshi
Post by gatshi »
I assume any type of flashing is not possible with the VAG Delphi DCM3.7.
So... any ideas?
Polo6RGTI_2
Registered for: 8 years 10 months
Post by Polo6RGTI_2 »
Marnes at HM Auto can do it.
ETunersSA
Car Model: ******
Post by ETunersSA »
Even bench flash. ECU can be read but not written. RSA digitial signature for checksum cannot be calculated or bypassed as yet.
gatshi
Post by gatshi »
An alternative is to use a Unichip. How that works beats me. I am installing one Monday. Will let you guys know if it worked.
Aslam_mk4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Post by Aslam_mk4 »
gatshi wrote:An alternative is to use a Unichip. How that works beats me. I am installing one Monday. Will let you guys know if it worked.
Steves auto clinic Vanderbijlpark?
I got 2 cars to do let me know how it goes
Bagged mk4 2dr
"Ride or die"
gatshi
Post by gatshi »
Yup. They sound confident and guarantee the work.
GremlinCCS
Registered for: 9 years 4 months
Post by GremlinCCS »
The unichip just lies to the original ECU to make it read values that's not true. So in theory if they say they can do it I will believe them. But with my third car that has a unichip I can't say I'm a fan, many says it's just not set correctly but they have all been done at dastek them self's and Ive never been 100% happy with the results.
Sent from my E6553 using Tapatalk
carapau
Registered for: 17 years
Car Model: Ibiza Cupra Tdi
Post by carapau »
The 1.2 tdis no one locally can do them.
We do have however have now a solution for dpf off and egr off on those cars , but its extremely expensive and the ecu needs to be sent overseas .
Regards
227 Kw & 580nm of pure Diesel Power
http://youtu.be/aw1bIpwPQtg
gatshi
Post by gatshi »
SAC fitted the Unichip. The DPF error went away for a while. Came back after +-100km. They said it could come back, and that some settings/values have to be changed.
Unfortunately, the P2563 error is NOT caused by the DPF. So my car is still in limp mode. The turbo was repaired. It seems the actuator on the turbo is faulty, or the sensor is, or something.
They don't sell the actuator separately, and I don't know how to test the actuator sensor. Any ideas?
Aslam_mk4
Membership No: 1824
Post by Aslam_mk4 »
gatshi wrote:SAC fitted the Unichip. The DPF error went away for a while. Came back after +-100km. They said it could come back, and that some settings/values have to be changed.
You just keep this thread updated on the dpf issue
I'm getting fat ok of the engine light on
Bagged mk4 2dr
"Ride or die"
christou
Registered for: 8 years 6 months
Re: Polo 1.2 Bluemotion TDi
Post by christou »
Good Morning , I need some advise please , My Polo yesterday had no problems but today the fuel filter light came on and for about 20km then suddenly the Catalytic converter light came on with a flashing Glow plug light the car is 500km away from the next service date and the place where I service my car said this is because its due for service that is why those lights came on , problems I experience is loss in boost ( power )
I hope its not serious or do I need to take it in ASAP ?
gatshi
Post by gatshi »
Hi
What does a fuel filter light look like?
Sounds serious. Car under warranty?
christou
Post by christou »
No warranty , the glow plug flashes ( how do I attach the picture )
gatshi
Post by gatshi »
Maybe its the MIL light?
No boost possibly means limp mode. Take it in asap. Car goes into limp mode to avoid further damage.
Hopefully it is not your DPF.
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
christou wrote:Good Morning , I need some advise please , My Polo yesterday had no problems but today the fuel filter light came on and for about 20km then suddenly the Catalytic converter light came on with a flashing Glow plug light the car is 500km away from the next service date and the place where I service my car said this is because its due for service that is why those lights came on , problems I experience is loss in boost ( power )
For further assistance, perhaps post your own thread as your issue has nothing to do with this thread where the original poster is trying to get help on his issue.
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
