Ansell
Posts: 181 Registered for: 10 years 9 months
Car Model: 1997 Golf 3
Post
by Ansell » Mon Oct 03, 2016 6:21 pm
Howsit okes,
Oil leak.
Any ideas? Seal? Gasket?
Shot chaps!
1997 Golf M K 3 GSX (1.8 MP9)
Specs:
79.7kw at 5209rpm and 160nm at 4240rpm (Saichs Dyno)
Modifications:
Stock exhaust with one 50mm-57mm freeflow box.
Standard airbox
Standard cam
Ex: 1970 Beetle 1300 twin-port
If you don't look back at your car after you park it, then you own the wrong car.
Posts: 26715 Registered for: 22 years 11 months
Post
by panic-mechanic » Mon Oct 03, 2016 7:25 pm
Yeah either the top seal on the heat exchanger or the exchanger itself.
Seal are loose available from GW when i checked last.
Ansell
Post
by Ansell » Mon Oct 03, 2016 10:34 pm
Thanks panic. I'll check it out.
Specs:
Modifications:
Standard airbox
Standard cam
dcmk4
Posts: 1741 Registered for: 11 years 2 months
Car Model: MK7 GTi
Post
by dcmk4 » Mon Oct 03, 2016 11:15 pm
Since you would be working around that area it's probably worthwhile to also change the gasket/seal that is situated between the block and the housing for the heat exchanger.
I speak from personal experience when I was changing the oring seal and heat exchanger due to a leak the gasket to the block was also leaking as the ridge in it that should form the seal was completely flattened on my mk3.
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
Post
by panic-mechanic » Tue Oct 04, 2016 7:39 am
Engine slant back so if it was leaking there it would not be on the heat exchanger.
Ansell
Post
by Ansell » Tue Oct 04, 2016 5:02 pm
Well from the top of the engine there isn't any oil coming from the top of the cooler.
It seems that the oil is coming from the area where the housing connects to the block.
I'll have a look at the o ring as well on the cooler but there's a lot of a lot of oil around the flange on the block.
Specs:
Modifications:
Standard airbox
Standard cam
Ansell
Post
by Ansell » Tue Oct 04, 2016 5:12 pm
Here's a top view. Doesn't seem to be the o ring.
Seems like the oil is seeping out from the flange on the block.
Specs:
Modifications:
Standard airbox
Standard cam
Howie-WP
Posts: 14272 Registered for: 22 years 11 months
Membership No: 2033
Post
by Howie-WP » Tue Oct 04, 2016 6:15 pm
Also clean area around the exchanger, so that you have a better idea of the source.
Ansell
Post
by Ansell » Tue Oct 04, 2016 10:27 pm
I'll give it a spray will some cleaner and see where it seeps from tomorrow.
It's a real mess. Oil just runs everywhere. Had to put a pint of oil in today.
Hope to find the cause tomorrow.
Specs:
Modifications:
Standard airbox
Standard cam
Post
by panic-mechanic » Wed Oct 05, 2016 8:15 am
And of course you checked that the filter is tight...and that you uave not left an old seal and put a new filter on so there are two.
Ansell
Post
by Ansell » Wed Oct 05, 2016 12:16 pm
Yes. The filter seems to be fine. There's one seal on it.
Bought the housing gasket today at GW.
R17.00 was a bargain!
Specs:
Modifications:
Standard airbox
Standard cam
Howie-WP
Membership No: 2033
Post
by Howie-WP » Wed Oct 05, 2016 12:36 pm
Ansell wrote: Yes. The filter seems to be fine. There's one seal on it.
Part #? I might need same at some point.....
Ansell
Post
by Ansell » Wed Oct 05, 2016 1:00 pm
Sure thing.
Specs:
Modifications:
Standard airbox
Standard cam
Post
by panic-mechanic » Wed Oct 05, 2016 1:23 pm
Remember there are two versions of that. Depending on year so just check.
Ansell
Post
by Ansell » Sat Oct 08, 2016 12:41 pm
So I have to replace my o ring on the cooler but can't get the cooler off the rod.
Please tell me that there's a way to remove the rod.
I really don't want to have to remove the coolant hoses. They're so difficult to get to.
Specs:
Modifications:
Standard airbox
Standard cam
dcmk4
Car Model: MK7 GTi
Post
by dcmk4 » Sat Oct 08, 2016 12:55 pm
To remove the pipe is quite a bit of work as you don't want to damage the threads using pliers or something similar to that. Even though the coolant hoses are rather difficult to work with I found it easier to just remove them from the cooler and drop the cooler off that pipe. Then remove the other portion from the block with the pipe still inside.
'14 Golf Mk7 GTI
Littco L380x
All the ponies
Ansell
Post
by Ansell » Sat Oct 08, 2016 5:13 pm
Yeah that was my biggest fear. Didn't want to damage the threads or anything.
Was thinking of locking two nuts on the thread and then removing the rod that way.
I'm going to have another look tomorrow.
I've thought of replacing the housings gasket on the block as well but everything is so awkward to get to.
Specs:
Modifications:
Standard airbox
Standard cam
dcmk4
Car Model: MK7 GTi
Post
by dcmk4 » Sun Oct 09, 2016 10:33 am
Access to the bolts securing it to that block isn't that bad once the cooler is out of the way though.
'14 Golf Mk7 GTI
Littco L380x
All the ponies
Ansell
Post
by Ansell » Sun Oct 09, 2016 11:41 am
I'm not replacing the housings gasket. I'm replacing the o ring on top of the cooler. That's why I'm removing the rod.
Specs:
Modifications:
Standard airbox
Standard cam
Ansell
Post
by Ansell » Fri Jun 19, 2020 9:21 am
I never managed to sort this out...still leaking today.
Can a cracked crankcase breather pipe on the block cause oil to drip down?
Specs:
Modifications:
Standard airbox
Standard cam
UDC
Posts: 5742 Registered for: 18 years 5 months
Membership No: 1041
Post
by UDC » Fri Jun 19, 2020 9:40 am
Ansell wrote: ↑ Fri Jun 19, 2020 9:21 am
yes
Fiki
Posts: 3 Registered for: 15 days
Post
by Fiki » Mon Jun 16, 2025 8:58 pm
Hi there, I’ve noticed some leaks around my oil cooler. I just wanted to ask, would it be better to replace the entire oil cooler or just the seals?
