VW GOLF 4 2.0 Engine mods - cam/chip
- Registered for: 16 years
- Car Make: BMW
- Car Model: E82 125i COUPE
Good day folks.....
So i'm looking at going a bit faster with my 85kw golf.
03 Golf 4 2.0 - APK engine.
Was looking at a 270d cam, vernier and a chip.
The questions:
what would i look at for the costs of doing the above?
what would the petrol damages be? drastic or not so bad?
what else would i need to change?
will the engine internals be good? and then gearbox? i know i need to put in a new clutch and pressure plate as so as cash says i can.
The questions:
".......life moves pretty fast, you don't stop and look around once in a while, you could miss it......" Ferris Beuller
- Car Make: BMW
Re: VW GOLF 4 2.0 Engine mods - cam/chip
Test 1: [Std cam + vernier + Unichip]
97.2KW @ 5686rpm
183N.m @ 3423rpm
Test 2: [Sportcam 272° + vernier + Unichip]
105.7KW @ 5697rpm
188N.m @ 4391rpm
would the above apply to my car?
- Shadows101Fall
A vernier pully won't give you any increases on power, all it is is a fine tuning tool for cam timing. And to be honest I can't see you getting 12 kw from chip tuning alone on a NA car. Chip tuning isn't the same in NA as it is in forced induction, on turbo cars you can pull timing and increase boost and fuel to increase power, but on a NA car there isn't much to do. Chip tuning in NA cars is for when you fit a bigger cam and flow the head for example, the ECU would need the fueling and timing to be set to best accentuate the mods done to the engine, then you'll see an increase in power.
You could fit a 276 and get it chipped and set up for the cam, should see a few kw's, you can also fit a k&n filter to get one or two extra kw's. Fuel economy is more dependent on the driver than anything else. I wouldn't worry too much about it, if anything you might see one or two km's less per litre. And don't worry about gearbox or clutch problems, the slight increase in power won't do anything to the internals or drivetrain.
There is a guy on the forum that can set you up with estas cams, I am not sure about the price currently but it was around R1560.00 last time I saw. It is also good practice to replace the lifters if another cam shaft is fitted, a set of lifters go for around R400.
I buy broken/smashed/written off cars
Current: 2005 Alfa Romeo GT 1.9 JTDm
Ex: 2014 Nissan NP200 1.6i - meh.. Sold
Ex: 2000 Alfa Romeo GTV 3.0 Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=197077
Ex:1980 2 door mk1 build thread Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=192831
no cam readily available for that engine...
- Shadows101Fall
Isn't the 2.0 motor in the golf 4/jetta 4 the normal ABA crossflow motor?
Edit: read like a tottie. Yeah man your **** out of luck, not much you can do with that motor.
Mmm. Old age creepingmin here but yes apk should take a regular cam.
Take a piccie of it please.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
I am just thinking even after spending all the money to try and get your Golf 4 faster, you will be disappointed because that body is heavy.
- Shadows101Fall
Wait is APK normal 8v xflow format or same as the polo motors? If it's the normal 8v format then all I said still applies
- Car Make: BMW
what do you need a pic of? the engine with the cover off?panic-mechanic wrote:Mmm. Old age creepingmin here but yes apk should take a regular cam.
will try asap....
yep its the 8v
basically this bad boy....(google pic)
yeah regular x-flow. should take the normal cam.
- graham savage
- Colonel
- Membership No: 803
Make sure the cam has 5 journals for APK
Please pardon my ignorance; is the APK "drive by wire" or not? If not then the "usual" 8v cams would be OK.
- Brotiform
- Car Model: YPA
- Membership No: 1135
Save your money. Low and slow.
"Your whole year's po3s also, bud" - Ghandi
- graham savage
- Colonel
They are shortblock, internal water pump, chain driven oil pump, drive by cable 8v cross flow motors BUT the cylinder head has 5 cam bearings unlike usual 8v's that have only the 4. Most aftermarket cams will have the journals correct but a lot of factory cams will not.
As having modified this motor I can tell you it is as strong as the older 8v's BUT you would be better off swapping it out for a 1.8t or VR6 or putting an ABF/KR 16v head onto it or like I did go straight for turbo.
