Hi All
I am installing cruise-control on my car. But not the OEM plug in type. I have one with a servo that I will connect to the fuel pedal. See pic1 (not the same brand, the pic is only for reference). The OEM route would have been easier but I got this kit for free and is new about R4'500, and I am halfway done.
I already connected the:
1) Power
2) Ground
3) Brake status signal at pedal
4) Clutch status signal at pedal
What I need still to do:
5) Connect speed signal behind cluster.
6) Install servo near fuel pedal.
I looked all over the web and cant find a wiring diagram to fit the pin layout of the Green plug behind my cluster. See pic2 and pic3 for the layout of my plug. I looked on workshop manuals .com (pic 4) and I can find the cluster diagram for installation etc. but not the pin layout. On other forums I found the pin layout for the Golf 4 and 5, the Citi Golf, even the polo 5 but none of them match my polo's plug.
Can anyone help me with the speedo cluster green pin layout for my 2006 1.9 tdi polo?
Gerrit
Polo Speedo Cluster Green Pin Layout for DIY Cruise-Control
- Car Model: Polo 1.9tdi
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Re: Polo Speedo Cluster Green Pin Layout for DIY Cruise-Cont
Contact Shaheen from E-Tuners. Find his details in the sponsor section
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
There are three wires on your speedo pickup on the gearbox. Using a multimeter see if you can trace any of them to the cluster plug. if you find it then that is the speed signal.
Just an update;
Last night I jacked the right front wheel in the air and put is on a stand and put bricks in front of the other 3 wheels. I started the car and put it in second and released the clutch slowly. The wheel turned and the car didn't run off the stand
I connected the one end of my multimeter to ground and with the other I tried to find a wire with frequency on so I know it was the speed signal. There were a few wires with variable frequency on and I didn't want to rev the engine I was afraid the car would jump of the stand and run through the wall! So I didn't get what I was looking for.
In the process something started peeping a lot because I triggered the airbag on one of the pins. Luckily it didn't deploy , I assume it's because I didn't have my seatbelt plugged in.
This a dodgy exercise and I don't think I will try it again...
Any other ideas?
Any other ideas?
What you did was not what i recommended so that is still the idea i recommend.
Yes I know it's not what you recommended. I phoned a shop who install the same type of cruise control and asked them how they find the signal and that is how they do it. But they lift both wheels...
Success!
Last night I soldered the speed sense wire from the cruise control to pin number 5 on the 32pin plug on the back of the instrument cluster, as seen in the first image. It was a white wire with a purple stripe.
(Thanks to Bestech and their friendly service who gave me the correct pin number and colour within minutes! The cruise control is quite expensive but it's a really good product. This is the 4th car its been in since 2003, when 1st installed)
I couldn't really test it until everything was done and I could go for a test drive. So I quickly installed the servo as seen in the second image. Over the weekend I will install the servo properly.
