Plastic Battery Box, Possible 1.9 TDi (74kW) Modification
Morné Pieters
Car Make: VW & Mercedes-Benz
Car Model: 07 1.9TDi & 09 C350 CDi
Post by Morné Pieters » Mon May 25, 2015 12:07 am
Hello Everyone
I have seen a few pictures here on the forum and have read about earlier Sportline models that came standard from the factory with the following plastic battery box below:
It looks like a nice modification and I would like to know if I can get this plastic battery box from either Goldwagen or even VW for my 1.9 TDi (74 kW)? Is it expensive? Does someone have a part number? Will it have enough clearance or interfere with a PD160 intake installed? Will it be easy to install? Is it worth it or should I rather not bother?
The referred picture in the post is a modified version borrowed from Silverbird_96Kw pictures to show the plastic battery box with a yellow arrow.
I look forward to your feedback :hurray:
2007 White Polo 9N3 1.9 TDi (PD100) - Daily Ride (Odo 262 300 km)
PD160 Intake lPD130 Intake Manifold + Pipes IEGR Blank lBMS Oil Catch Can lPD130 Turbo lDe-Cat lStraight Flow FMIC (450x230x65 mm) & 50 mm S/S Boost Pipes lWulfchip Software lFK Projector Headlights & 6000K HID lLED Retrofit lCustom LED Footwell Lighting lCustom Leather Interior lGTI Black Interior lCustom Speedo Cluster lCruse Control Retrofit
JDT
Wheel Whore
Car Model: Golf 5 2.0 TDI
Re: Plastic Battery Box, Possible 1.9 TDi (74kW) Modificatio
Post by JDT » Mon May 25, 2015 6:18 am
Hi man it is strange that your car didn't come standard with that battery box, i thought all TDI's had them. it won't be in the way for the pd160 intake.
Golf 5 2.0 TDI
Stage 1 JD Tuned Software
Crawler
Car Model: 9N3 Polo TDi
Membership No: 1358
Post by Crawler » Mon May 25, 2015 7:41 am
my 2007 also does not have it
CW Polo TDi Sportline
BIGMIG
Porra Love
Car Model: 9N3 GTB22/60vk Sportline
Membership No: 1574
Post by BIGMIG » Mon May 25, 2015 7:47 am
Unfortunately they decided to do some weight saving on the sportline model to try and increase its performance at a lower cost begining to mid 07.
Full battery cover = Skeleton type
ECU security cage = NUDA
Bonnet shock = Old school style
Passenger height adjustable seat = Fixed, for extra passenger good vibrations
Extra compartment under passenger seat = More air space
Rear windows that could open slightly = Fixed for that air tight feel.
Im sure there is more
My DonkeyPiel assassin
Goose, soot ninja
BIGMIG
Porra Love
Membership No: 1574
Post by BIGMIG » Mon May 25, 2015 7:48 am
Its just a case of getting the part number or the chassis number so that you can order the parts, it fill be a direct fit.
PD160 snorkel will also fit, it will be tight but it will fit.
Goose, soot ninja
BigBear
Car Make: FORD
Car Model: ST
Membership No: 1598
Post by BigBear » Mon May 25, 2015 7:52 am
Our 2005 9n3 74kw PD100 came with the cover as well.
My Rides:
2009 Ford Focus ST 225 Frozen White 5 Door Leather + Sunroof
2005 Ford Ranger 4000V6 4x4 Oyster Silver Super Cab XLT
1978 Beetle 1600S
Family V Dubs:
2005 Polo 1.9 TDI Highline 5 Door ( 9n3 74kW PD100 )
2007 Polo 1.6 Comfortline 4 Door 9n3 (Write Off)
Non V Dubs:
1997 Ford Explorer 4.0 V6 AT 4x4 Maroon SUV XLT
2013 Chevrolet Cruze 1.8 LS
Morné Pieters
Post by Morné Pieters » Sat May 30, 2015 5:24 pm
JDT
Thank you for the feedback sir. As BIGMIG said, I think the facelifted models did not come with the battery box. Also keep in mind that I don't have the Sportline 3-door model but the Highline 5-door model. Thanks for the info on the PD160 :thumbup:
Crawler
Would you like to have such a box under your bonnet sir? Maybe try the mode if it is not that expensive :cool:
BIGMIG
Thank you for the feedback sir. I have the skeleton type battery cover as seen below:
The info on the Sportline 3-door model is interesting the changes they made. I presume this all happened on the face lifted model? I however have the Highline 5-door Model. If I give VW my VIN number, I guess that will not help as it did not come originally with such a battery box... :cry: Is there any other way to get the aprt number? I will try and dig form my side :geek: Thanks for the info on the PD160 :thumbup:
BigBear
Thank you for the feedback sir. I believe it looks much nicer with the battery box compared to the skeleton type. :thumbup:
Shivbeanz
Car Model: 9n Sportline
Post by Shivbeanz » Sat May 30, 2015 6:40 pm
Hey bud, I've got a part number on the lid for you :hi:
6Q0 915 429 B
I'll upload a pic of my fuse box to make sure they're the same as I've got a 9N
(Oo=o=oO)
Shivbeanz
Post by Shivbeanz » Sat May 30, 2015 6:58 pm
The lid has two forks which slide into the holes (orange circle) on the fuse box and snaps over the red circle
Please excuse the dirty engine bay, exams are looming :oops:
(Oo=o=oO)
Morné Pieters
Post by Morné Pieters » Sun May 31, 2015 11:10 am
Shivbeanz
Thank you for the part number sir, I really appreciate your effort :hug:
The part number you gave me put no on a search and I found the following thread on all the other part numbers, case, lid & fuse box assembly to make up one assembly below:
http://translate.googleusercontent.com/ ... ANyHCpix1g
Thanks for the explanation on how the lid works and no worries about the dirty engine, mine doesn't look any cleaner anyways :oops: and I have no excuse except being lazy :eek:
Shivbeanz
Post by Shivbeanz » Sun Jun 07, 2015 9:57 pm
No problems bud, hope you come right!
Quite a useful site you found there :thumbup:
(Oo=o=oO)
