Trendline to Comfortline headlights conversion
liquidsnake
Car Model: Polo 6R
Post by liquidsnake »
Hello guys, just a quick intro on my car and the issue, hope someone out there can help me or point me in the right direction...
I have a Polo 6r trendline which comes with the below headlights:
i have recently gone and bought myself a set of Polo comfortline headlights from a friend which looks like this:
I tried fitting them with new bulbs and all but I cant seem to get the high beam and low beams to be on at once. If i switch to high beam , the low beam switches off and vice versa.
Does someone perhaps know why? I know its not the set of headlights because I tried my wifes headlights (she has the comfortline) and that has the same issue.
Thanks for takng the time to read!
Current Ride: 2013 - Present Polo 6r 1.4 2012
Previous Rides: 2009 - 2013 Golf CitiRox 1.4i 2009
Howie-WP
Membership No: 2033
Re: Trendline to Comfortline headlights conversion
Post by Howie-WP »
Surely High beam and Low beam can not be on at the same time? You use either at one time, not both at the same time...... or am I misunderstanding?
spdgti
Registered for: 22 years 10 months
Post by spdgti »
H4 vs H7,H1 bulbs?
Check the wiring, you will need to create a link to the highbeam of the C/F bulb, as all the connections are on a single three pin connector on the T/L bulb.
edit: oops mis-read you initial problem :oops:
'08 06 Magma Orange Cross Polo
ex: Reflex Silver GTi-R
spdgti
Post by spdgti »
Howie-WP wrote:Surely High beam and Low beam can not be on at the same time? You use either at one time, not both at the same time...... or am I misunderstanding?
Yes they can, when 'brights' are selected, but sometimes highbeam won't work if foglamps are on?
liquidsnake
Car Model: Polo 6R
Thanks to the responses guys... I notice that the twin halogen headlight on my wifes comfortline polo,has both lights switch on and this issue is probably because my switch or wiring loom is different. I will just have to drive like that with one on, its not like high beams are used too often together with low beam. @spdgti I will look into asking an auto electrician but for nw i dont think i can link those 2 on my own
