Red Velociti - Detail attempt
Irfaan
fuckitimtiredletsgetdonewiththis
Car Model: 07' Velociti, 06' MK5 GTi
Membership No: 1757
Post by Irfaan » Mon Mar 02, 2015 10:42 pm
A bit delayed but here we go.
It all started when I managed to get a Shield DA for next to nothing. I decided my pride and joy deserved some much needed care and after the Soap Rides car wash leaving Holograms and buffer trails all over the car, it really needed to be sorted out.
Anyway I visited Crazy Detailer and got me some goodies. I spoke to Lawrence via pm and also read the Detailing advice thread from start to end, and picked up some tips and tricks. Couple that along with alot of YouTube vids and some odd reading off detail forums and I was confident enough to give it a go.
Some Before pics:
Pre Wash which doesnt look all that bad
Some water marks and droppings courtesy of Nature
On to the wash. HP Rinse was done, followed by a good foam using Cyclo Auto Suds. I left it to settle and rinsed it off. A second foam blast was given, this time I left the foam on and continued with the 2BM wash. A few mists of AF Iron out(Worked like a charm)
After the final rinse
This is where I used the Shield quick detailer and fine clay. Ummm no pics, I was too busy and forgot :yawn:
Anyway after the clay I used the foam cannon again, the 2BM wash method and gave it another rinse. Thereafter using the CD drying towel. Once things were all dry, I didn't have to look for swirls or any defects, it was all over.
On to paint work:
I got so stuck into it I forgot to take 50/50 pics.
I used a small section of the bonnet as a test patch, using Menz FG400 and the Orange Pad. Followed by Menz SF4000 and the Green pad and finishing with Menz PF2500.
So like I said no 50/50 pics. However here is some panel shots of the end product before laying the wax.
And the final product. Sealed with the Collonite Insulator wax
Rims & Tyres were cleaned using Prepsol(Because no money for fancy mag cleaner) Followed by AF Iron out. I used gloss worx wax on the rims and Gloss worx tyre shine.
About the tyre shine, It lasts through dirt and dust. And can probably handle one rain. Much better than most of the Tyre Shine products I've used and smells lekker (Not that I sniff tyres :lol: )Highly recommended. However if you use Meguirs, dont expect Gloss Worx to defer your purchase decision.
And that is pretty much it. It was exciting seeing the swirls and holograms disappear. Too much hard work. I take my hat off to the detailers who do this every weekend and in between manage to take all those pics.
Thanks to Lawrence for all the info. CD for great service and all the others who entertained my questions. I think I've done well and theres still alot to learn,
Thanks for looking :hug:
Yip I still got my 1.4 Citi
iLy
Re: Red Velociti - Detail attempt
Post by iLy » Mon Mar 02, 2015 10:49 pm
Nice work, car is looking minty fresh!
Keep calm and drive low
Current: 1991 Golf Mk2 CLi
Instagram @247ily
chucker02
Car Model: Citi ADY
Post by chucker02 » Mon Mar 02, 2015 10:52 pm
Very awsome bud! The transformation is insane! Very good work!
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
zane.mk1
Car Model: MK6 GTI
Post by zane.mk1 » Tue Mar 03, 2015 8:45 am
Awesome job! :hurray:
And your car looks! :drool: :drool:
The Daily: '12 VW Polo 6R Comfortline
The Blompot: '11 VW Golf MK6 R
Future Trackstar: '06 Citi 1.4i
Post by lawrence » Tue Mar 03, 2015 8:46 am
:hurray:
Absolutely awesome bud - well done. Car looks much better. So besides realizing that detailing is hard work, are there any other thoughts you would like to share about the process or the outcome? Had you clayed before and if not, what was that like for you?
How did you find #845 - you can use it to protect your rims too
Don't take this the wrong way, but I'd like to give you a better understanding of the Menzerna Polishes and when to use them.
Irfaan wrote:I used a small section of the bonnet as a test patch, using Menz FG400 and the Orange Pad. Followed by Menz SF4000 and the Green pad and finishing with Menz PF2500
Each polish can be ascribed a level of cut - in other words how much paint it can remove (on a scale of 1 being the lowest to 10 being the max).
FG400 9
PF2500 5
SF4000 4
Then each polish can also be ascribed a finishing ability - in other words how glossy the polish leaves the paint (on a scale of 1 being the lowest to 10 being the max)
FG400 7
PF2500 7
SF4000 10
Based on this what you did with your paint is (and this is really an over-simplification to illustrate the point)....
cut down 9 layers deep to remove some swirls and left the paint at a 7/10 gloss (FG400)
cut down 4 layers deep to remove some swirls and left the paint at a 10/10 gloss (SF4000)
At this stage, this is the 'typical' 2-step approach with Menz polishes..... FG400 to cut out the damage, followed by SF4000 to refine the finish and improve the gloss.
But then you followed this with PF2500 which REDUCED the gloss to 7/10.
If you actually needed to cut down that deep into the paint to remove all the defects, then the better approach would have been
FG400/PF2500/SF4000
Make sense?
Post by Kyle » Tue Mar 03, 2015 8:52 am
Wow :hurray: :hurray:
Tre
Car Make: Opel, Renault
Car Model: corsa ute, Duster Dci, R26 Meg
Post by Tre » Tue Mar 03, 2015 9:00 am
invaluable info for free...shot lawrence
'09 Renault megane R26
'14 Renault Duster DCI
'07 Corsa UTE
''14 Silverback Sola 1...'gorilla in the mist'
Preggz
Car Model: 06 Velociti & 13 6r PGti
Post by Preggz » Tue Mar 03, 2015 9:34 am
Great Work on the Attempt
car is looking Sweet :drool:
LöW Ridër Velociti
JOMs FTW
Reflex Sliver Polo 6R GTI (Stock)
Irfaan
Membership No: 1757
Post by Irfaan » Tue Mar 03, 2015 9:56 am
lawrence wrote::hurray:
FG400 9
PF2500 5
SF4000 4
FG400 7
PF2500 7
SF4000 10
FG400/PF2500/SF4000
Make sense?
- I need more pads
- I need proper spot lights to check the other defects
- I need to get Maxi Suds II
- I need that citrus blast formula
- I need patience to tape off the rubber pieces :lol:
- I need to wear a a back brace the days following completion of a detail.
I have Clayed before, only this time it sounded so bad like a light sand paper over the body. It took extra long because I wanted to make sure I got it done right. However, I think fine clay is too weak and something a tad bit more aggressive if I may say, is needed. I say this because of the tar which refused to come out and left me irritated, so I used Auto Glym Tar remover. Anyway keeping that in mind I did watch many video's trying to see different ways of claying etc.
Thanks for the Menz clarification Lawrence, I didn't think of it in that way. I just tried the finest cut first and seen that didnt work so I played around with what i had until I seen swirls disappear. In all honesty I think I got lucky. I always take what you say as knowledge so definitely not taking it wrong. And you know I will ask your advice on alot of things. :hug:
Apart from all this, Many of neighbors who seen me busy and seen the end result asked me to "Polish" their cars and I rejected.
This being the reason:
1. I gave up 4 days of my life cleaning the car inside and out, and while it paid off I just don't have the time or energy to do it for another person.
2. They have moer expensive cars. (Ferrari's, Porsche's and Big ass mercs)
3. I can't take the risk of messing up somebody else's car.
4. I am not experienced enough
5. My back is Fecked for 2 days after and it's painful
I did enjoy the whole exercise, and I'll continue buying things. But I will do this for myself only.
Post by lawrence » Tue Mar 03, 2015 10:03 am
Yeah I always say that okes getting into machine polishing seriously underestimate a) how physically demanding it is, b) how mentally exhausting it can be concentrating so hard for 30 hours and c) how many pads they will need
IMO you simply cannot have enough buffing pads or MF towels....or lights :grin:
Anyway it sounds like you enjoyed it, which is the main thing.... the minute maintaining your car (or full on detailing for that matter) becomes a 'chore' or something you are not excited about, then you are finished....
Keep at it and with practice it will all become a lot easier :thumbup:
Post by Kyle » Tue Mar 03, 2015 10:04 am
lawrence wrote:Yeah I always say that okes getting into machine polishing seriously underestimate a) how physically demanding it is, b) how mentally exhausting it can be concentrating so hard for 30 hours and c) how many pads they will need
:iagree:
Post by N3mo » Tue Mar 03, 2015 10:19 am
Well done
CharlDHechter
Car Model: 1987 Mk2 2.0L 8v
Post by CharlDHechter » Tue Mar 03, 2015 12:38 pm
Wow, very clean and shiny. Love the color :drool:
Irfaan
Membership No: 1757
Post by Irfaan » Tue Mar 03, 2015 12:46 pm
Thanks guys
Kiran
Thumbie
Car Model: Golf 1 Citi
Membership No: 2028
Post by Kiran » Tue Mar 03, 2015 1:48 pm
wow well done bru the car looks amazing
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi » Tue Mar 03, 2015 2:04 pm
Well done bud, it came out well
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Car Make: Fiat
Car Model: Uno
Post by Unobeat » Tue Mar 03, 2015 3:11 pm
What transformation, the paint is so damn shiny and clean.
Good job bud :thumbup:
Car Make: Fiat
Car Model: Uno
Post by Unobeat » Tue Mar 03, 2015 3:12 pm
:iagree:
+1
Rsi huntered
Post by Rsi huntered » Tue Mar 03, 2015 6:53 pm
:hurray: :hurray: :hurray: well done bud.... cabbie came out really good.....
Yip I agree very time consuming.....I did 2 car..
Thursday.... Friday. ... Saturday and Sunday. ... It was back breaking BUT I went back for more :grin: cause I'm aiming for perfection or something close enough. ... still need to do my brothers car but soon...
My DA machine broke (some factory fault ) waiting for it to return and need to juggle my studies and doing more cars :troll:
Polo 6C-2016
2004 Golf 1 Baby 1.4i +VAT :evil: 76.3 [email protected]
Polo 2008(9n3)Ex:-(
Golf 1(2 door)branch,exhaust,domingo's,leather seats,electric windows, 2.0L 16v ( sold ) :cry: Ex.
Golf 2 2L 16v full house(RIP) :bang: Ex
Life160
Post by Life160 » Tue Mar 03, 2015 8:22 pm
Well done bud!
The hard work definitely paid off.
MK6 GTI 12' (APR)
Citi Life 01' - 1.6i 8v :(
76.6kw/144nm (RBTS)
Zubair
Car Model: MK1
Post by Zubair » Tue Mar 03, 2015 9:23 pm
With FG400 and SF4000 I find myself rarely reaching for my supply of 2500. Thats one gorgeous looking Citi btw.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
Irfaan
Membership No: 1757
Post by Irfaan » Tue Mar 03, 2015 10:30 pm
Thanks Gents. I'll be attempting headlight restoration on my uncles car soon and will report back.
@Life160 is it making you regret selling your citi yet? :lol:
@Zubair thanks bro, needs some 3 piece wheels though
@Rsi you have patience and lust for back aches. I think deadlifts will do for me hahaha. Post some pics of your car's when done
LFC
Post by LFC » Wed Mar 04, 2015 12:12 pm
Came out awesome Irfaan, well done :hurray:
Tashveer
Car Model: Cti
Membership No: 2095
Post by Tashveer » Wed Mar 04, 2015 12:40 pm
Look :hurray: s great buddy. Well done.
1993 CTi ABF
2004 Citi Life 1.6i
Life
Post by Life » Wed Mar 04, 2015 12:44 pm
Looking Awesome. :drool:
Cannot wait to get a DA polisher and get cracking on my Citi.
For tyre shine and endurance in rain etc. give the Motip Aerosol spray a try, I haven't looked back since trying it.
