Shorter Sump for Citi Golf
Wheelwore
Car Model: MK1 Velociti 1.6i
Post by Wheelwore » Mon Dec 01, 2014 1:36 pm
Has anyone tried this..to avoid damaging the sump on static cars
2007 - Velociti 2.0 ABF Black Magic
2008 - Velociti 1.4i Midnight Blue
2002 - Chico 1.4i White - Chicolux
1996 - VR6 2.8 Golf
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Re: Shorter Sump for Citi Golf
Post by AlexTDi » Mon Dec 01, 2014 2:23 pm
Wheelwore wrote:Has anyone tried this..to avoid damaging the sump on static cars
Negative, unless finding an import which is near impossible, SHAUN investigated this IIRC for his Jet.
Rather lift the motor higher in the bay with some custom mounts.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Mon Dec 01, 2014 2:27 pm
Stick with the steel sump, they can handle more abuse than an aluminium sump.
Current rides:
Hyundai - 1.4 Getz (daily)
Wheelwore
Post by Wheelwore » Mon Dec 01, 2014 3:01 pm
Need sump further away the road..
1996 - VR6 2.8 Golf
Boost
Car Model: Caddy pickup
Membership No: 1921
Post by Boost » Mon Dec 01, 2014 3:09 pm
Just dont have the car so damn low :lol:
That will require a lot more than just the sump. Lifting the engine is limited. You have already pushed your side shafts closer to the chassis legs. But if you come up with a solution please let us know.
Sent from my Nokia 3310 using Tapatalk
Current: 2008 VW Caddy R-Line 20V BIG T :driving:
2017 Chev Captiva 2.2d LT daily
2000 Vw Citi 1.6i
2013 GW Audi A3 Sportback 1.8TFSI SE S-Tronic (POS)
2006 Volvo S40 T5
2004 Nissan 350Z Coupe
2000 VW Golf 4 GTI (247wKw @ 1.3bar)
2007 Fiat Grande Punto
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
yeo786
Car Model: Velociti 1.6i
Post by yeo786 » Mon Dec 01, 2014 3:16 pm
I think Riaan aka Project 8v aka Throttles has a solution, its on his build thread in the xtreme veedubz website
If you're in control, you're not going fast enough!
Current :
VW Velociti 1.6i
Ex -Honda Ballade EF 160i 16V Dohc - Sold
Ex -VW Citi 2.0 8V Carb - Sold
Ex -CitiRox 1.4i - Stolen
Wheelwore
Post by Wheelwore » Mon Dec 01, 2014 3:38 pm
why we struggle like this in SA
1996 - VR6 2.8 Golf
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY » Mon Dec 01, 2014 4:01 pm
Lift motor, c notch, ball joint extensions. Move on with life.
If baller go for dry sump.
Wheelwore
Post by Wheelwore » Mon Dec 01, 2014 4:04 pm
Ball Joint extenders and Tie rod flip kit I had to order from States
C notch - Done
Lift Motor ....Tell me more about this...
1996 - VR6 2.8 Golf
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Mon Dec 01, 2014 10:21 pm
Stock engine and gearbox mounts are off center, toward the top of the bushes. Have custom polyurethane ones made that are closer to the bottom and you should lift about 25mm. Leave the rear mount alone and the drive shaft won't lift very much. The front stabiliser will need some modding to make it fit, but it has lots of movement so it shouldn't take much to get right.
Wheelwore
Post by Wheelwore » Tue Dec 02, 2014 8:46 am
thanks..custom polyurethane -- who can make this
1996 - VR6 2.8 Golf
Psycho8v
Car Model: Citi Golf
Membership No: 1881
Post by Psycho8v » Tue Dec 02, 2014 9:24 am
Wheelwore wrote:thanks..custom polyurethane -- who can make this
Won't Andre's rubber in CPT be able to help you bud? I know I've read on the forum he makes all sorts of different shore hardness mounts for people, surely he'll be able to help make a custom mount for you?
http://www.andresrubber.com/contact.html
Cyle16v
Car Make: Mazda
Car Model: Boosted 3
Membership No: 1923
Post by Cyle16v » Tue Dec 02, 2014 9:39 am
yup he will.
he sells a poly kit for the mk1 for like R700
and you can send in exsiting mounts for him to fill.
best thing I would suggest is get two mounts, send them to Andre have him move the pilot holes for the bolts far down as possible and fill with the poly.
Missioner had suggested this, I am just adding to it
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Dec 02, 2014 12:20 pm
If you are handy enough you can buy the poly as a 2-pack resin and cast your own mounts, using the original metal parts.
Current rides:
marzbars
Car Model: 1984 Jetta GLS Auto
Membership No: 1316
Post by marzbars » Tue Dec 02, 2014 12:36 pm
Why not do something like this?
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY » Tue Dec 02, 2014 12:54 pm
marzbars wrote:Why not do something like this?
Cause that doesn't help much at all
DCmk3
Car Model: MK4 GTi
Post by DCmk3 » Tue Dec 02, 2014 1:10 pm
Turning a lowered car into a sparkler when it grinds bumps? :troll:
'03 Golf Mk4 GTi
missioner
Post by missioner » Tue Dec 02, 2014 1:58 pm
Oh use the old sump from the 1.3 citi or 1.6 golf 2 it's vee shaped and will give a little more clearance
