Clutch Bracket at Firewall
Juano
Post by Juano » Thu Nov 27, 2014 8:23 am
I've serviced my clutch and pressure plate about 4 years ago on my 2003 cit golf, and recently the bracket that's attached to the firewall started pulling away from the firewall. I've been trying to weld it back but its in such a award place :crazy: so it makes it difficult to weld it properly back, any suggestions???
Donavan
Re: Clutch Bracket at Firewall
Post by Donavan » Thu Nov 27, 2014 8:47 am
Goldwagen sells a plate that fits onto the firewall.
Audi A4 B8 2.0T - Daily
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Post by Naku786 » Thu Nov 27, 2014 8:47 am
buy the firewall bracket plate from GW
Juano
Post by Juano » Thu Nov 27, 2014 9:06 am
Unfortunately my car doesn't work with a plate I've seen the plate at goldwaggen, my car has a T structured bracket there and theres no plate around it,I've seen the velocitys and newer golfs are the same... :yawn:
Naku786
Cake Laaitie Killer
Post by Naku786 » Thu Nov 27, 2014 9:34 am
You have this then
Image[/URL][/img]
You can swap over to the old style system, remove the bracket (2 no. 10 nuts) & remove the saddlebag locking pin. Then you need to remove the arm from the pedal... I just removed the clutch pedal assembly & took it out.
Get the "long" clutch cable, hook onto pedal, fit bracket & reassemble & bobs your aunties uncle...
Just note the pedal feel will be a little harder with the long cable.
Juano
Post by Juano » Thu Nov 27, 2014 2:44 pm
Geez you a genius bud!!! I was thinking of doing that!! will do it this weekend! thanks man!!!!
