Adaptors please help PCD change
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 7:36 am
Hi guys need help on this wanting to know do i need two sets of adaptors to change my PCD from 4x100 to 5x114 or wat?
thanks in advance
missioner
Car Model: '87 MK1 Golf Citi
Re: Adaptors please help PCD change
Post by missioner » Wed Nov 05, 2014 7:58 am
Get the hubs drilled.
Using 5x114 rims you have to be very careful selecting rims with the right offset. Remember that word. Offset is the distance from the center of the rim to the lip measured across the width of the rim not the spokes.
What I'm getting at is adapters will significantly reduce the offset of your new rims and negatively affect the handling, tyre to fender clearance, wheel bearing lifespan and a whole lot of other suspension and steering problems.
Have the hubs and discs drilled it will cost less than the adapters and is a safer solution than adapters
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY » Wed Nov 05, 2014 8:08 am
missioner wrote:Get the hubs drilled.
Good luck having enough meat on the hub to redrill to 5x114.3 from 4x100 :thumbup:
missioner
Post by missioner » Wed Nov 05, 2014 8:20 am
Good luck having enough meat on the hub to redrill to 5x114.3 from 4x100 Image
So what do you suggest then?
If it was me I wouldn't even try fitting BMW rims to my golf. Leave that to the ricers
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 8:22 am
dude it cant be drilled i must make adaptors if it was to 5x100 pcd i think you can drill the hubs but not 5x114 bud
i think i just started hating the word offset.
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY » Wed Nov 05, 2014 8:29 am
adapters, they perfectly safe and work well.
Yes offset needs to be checked but that's a minor issue imo, easily checked.
Most adapters will be around 20mm thck, so look at the offset of the wheel you want and add 20mm of poke to your calcs.
And 5x114.3 is Japanese spec PCD, not BMW, BMW is 5x120.
Lol at ricer comment
missioner
Post by missioner » Wed Nov 05, 2014 8:31 am
We all learn every day.
OP what car are these jap ricer rims going onto?
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 8:36 am
These are the wheels and dont think they jap wheels at all
dub167
Car Model: mk2 GTI
Mk2 golf bud
missioner
Post by missioner » Wed Nov 05, 2014 8:41 am
Alfa romeo?
Ok
Ricer comment retracted.
missioner
Post by missioner » Wed Nov 05, 2014 8:42 am
Was the alfa front or rear wheel drive?
This is important because it determines the offset you are working with.
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 8:45 am
I think its a rear wheel drive bud
mags to fit Alfa 6 sedan is that a RWD
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY » Wed Nov 05, 2014 8:59 am
missioner wrote:Was the alfa front or rear wheel drive?
The offset should be stamped on the back of the spokes along with PCD and width etc.
Those look like Compomotives, the alfa part is just a centre cap.
Post by Kyle » Wed Nov 05, 2014 9:00 am
In for lolz
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 9:05 am
Kyle wrote:In for lolz
now y do u wanna go and do that
Saiendra
Criminal Troll.
Car Model: Golf VI 2.0T ED35
Post by Saiendra » Wed Nov 05, 2014 9:06 am
Drill hubs to 5x100 PCD, Fit 5x100 to 5X114.3 PCD Adapters made by Deriam Engineering.
Plates will be 30 mm thick if you decide to go with a double adapter and may leave the off-set way too aggressive.
(5x100 -> 5x114.3 will be 20 mm) (Subtract 20 mm from the current off-set on your wheels to get the new off-set)
Contact people:
Sharon - 0824454769 (Deriam Engineering for Adapters)
Zubair - 0832656668 (Wheels and More to re-drill hubs to 5x100 PCD)
Spacers will cost around R1300 - R1500 depending on width etc...
On car PCD drilling will cost you around R700.
Daily - Gold-Metallic / 1985 Golf II CSL.
Racekor - United Grey / 2012 Golf VI GTI 2.0 TFSI ED35.
dub167
Car Model: mk2 GTI
Post by dub167 » Wed Nov 05, 2014 9:08 am
Thanks alot Saiendra will go that route by drilling the hubs
Saiendra
Criminal Troll.
Post by Saiendra » Wed Nov 05, 2014 9:17 am
Mod cars they said... It will be fun they said...
Aslam_MK4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Post by Aslam_MK4 » Wed Nov 05, 2014 9:42 am
Yay im a ricer
Got x5 wheels on my mk4
I have 25mm adaptors front
15mm adaptors rear
Bagged mk4 2dr
"Ride or die"
Post by Kyle » Wed Nov 05, 2014 10:43 am
aslam325 wrote:Yay im a ricer
15mm adaptors rear
We still love you :hug:
THE GAME
Wheel Hoarder
Car Make: VW / BMW
Car Model: Golf VR6
Post by THE GAME » Wed Nov 05, 2014 11:32 am
Im also doing some calculations for my new wheels
& it seems im gonna go via Deriam engineers
need 25mm adaptors 5x 100 to 5x 112,
"HaTe iT oR LoVe It"
2001 E39 M5 Antracite
1997 Golf VR6 White
1992 E30 325i Silver
2011 BMW 320d M Sport White(Yes another White one)
1991 E30 318i coupe Red
2011 BMW 320d Msport
2004 323 Mazda (Daily)
Golf 5 GTI DSG United Grey
2005 318i E46 Individual
2001 Polo Playa 1.6
200i 16v Dohc Mazda
2004 318i E46 Special Edition
2002 Polo Playa 1.6s
