http://vagcafe.com/?product=gfb-dv-dive ... tfsi2-0tsi
Product Description
GFB’s DV+ solution couldn’t be simpler – keep what works and replace what doesn’t.
Worldwide Patent and Design Patent Pending
Retains the factory solenoid coil for seamless integration
Replaces plastic valve parts with metal for reliability and strength on chipped engines
Direct-fit replacement with GFB’s TMS benefits
Exclusive “pilot-actuated” valve mechanism for rapid response at high boost
GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles.
The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances.
The end result is sharper throttle response, lightning-fast valve actuation, and it will hold as much boost as you can throw at it. Read all about the DV+ story on the next page.
Other manufacturers’ products involve replacing the entire system with a traditional pneumatic valve, requiring long vacuum hose runs, additional parts for tapping into the intake manifold vacuum, plus either a different solenoid valve to actuate the pneumatic valve or a ballast resistor to plug into the OE wiring loom. All these additional items result in a product that is slower, less responsive, more expensive and takes much longer to install.
GFB’s DV+ solution on the others hand is more responsive, less expensive, easier to install, and doesn’t cause compressor surge/turbo flutter. Oh, and it doesn’t require different springs or frequent re-builds.
Suits all VAG 2.0T FSI and TSI engines fitted to:
•AUDI A3 Typ 8P 2.0t FSI 03-13 8PA 147kw Petrol Engine FWD Hatchback 09/04-on
•AUDI A3 Typ 8P 2.0t FSI 03-13 8P1 147kw Petrol Engine FWD Hatchback 09/04-08/12
•AUDI A3 Typ 8P 2.0t FSI 03-13 8P7 147kw Petrol Engine FWD Convertible 04/08-on
•AUDI A4 B7 2.0 TFSI 04-08 8ED, B7 147kw Petrol Engine FWD Wagon 11/04-06/08
•AUDI A4 B7 2.0 TFSI 04-08 8EC, B7 147kw Petrol Engine FWD Sedan 11/04-06/08
•AUDI A4 B7 2.0 TFSI 04-08 8H7, B6, 8HE, B7 147kw Petrol Engine FWD Convertible 01/06-03/09
•VW Golf GTI Mk5 2.0t 04-09 1K1 147kw Petrol Engine FWD Hatchback 05/05-02/09
•VW Golf R 4motion Mk6 2.0t FSI 08-on 5K1 188kw Petrol Engine AWD Hatchback 11/09-11/13
•VW Passat B6 2.0 TSI 05-11 3C5 147kw Petrol Engine FWD Wagon 08/05-11/10
•VW Passat B6 2.0 TSI 05-11 3C2 147kw Petrol Engine FWD Sedan 07/05-07/10
•VW Polo GTI Mk4F (Typ 9N3) 1.8t 05-09 9N_ 110kw Petrol Engine FWD Hatchback 09/05-11/09
•AUDI S3 quattro Typ 8P 2.0t FSI 06-13 8PA 188kw Petrol Engine AWD Hatchback 07/08-on
•AUDI S3 quattro Typ 8P 2.0t FSI 06-13 8P1 188kw Petrol Engine AWD Hatchback 02/07-08/12
•AUDI TT Typ 8J 2.0t FSI 06-on 8J9 200kw Petrol Engine AWD Convertible 05/08-on
•AUDI TT Typ 8J 2.0t FSI 06-on 8J9 147kw Petrol Engine FWD Convertible 03/07-06/10
•AUDI TT Typ 8J 2.0t FSI 06-on 8J3 155kw Petrol Engine AWD Coupe 05/10-on
•AUDI TT Typ 8J 2.0t FSI 06-on 8J9 155kw Petrol Engine FWD Convertible 05/10-on
•AUDI TT Typ 8J 2.0t FSI 06-on 8J3 200kw Petrol Engine AWD Coupe 05/08-on
•AUDI TT Typ 8J 2.0t FSI 06-on 8J3 155kw Petrol Engine FWD Coupe 05/10-on
•AUDI TT Typ 8J 2.0t FSI 06-on 8J3 147kw Petrol Engine FWD Coupe 08/06-06/10
•VW 2.0 TSI 147 kW 162 147kw Petrol Engine FWD Sedan 12/10-on
•VW 2.0 TSI / TFSI 1K2 147kw Petrol Engine FWD Sedan 10/05-10/10
•AUDI 8J3 2.00/2.5 TFSI 8J3 250kw Petrol Engine AWD Coupe 07/09-on
•AUDI 8J3 2.00/2.5 TFSI 8J3 155kw Petrol Engine AWD Coupe 05/10-on
•AUDI 8J3 2.00/2.5 TFSI 8J3 200kw Petrol Engine AWD Coupe 05/08-on
•AUDI 8J3 2.00/2.5 TFSI 8J3 147kw Petrol Engine FWD Coupe 08/06-06/10
•AUDI 8J3 2.00/2.5 TFSI 8J3 155kw Petrol Engine FWD Coupe 05/10-on
•AUDI 8J9 2.0 TFSI 8J9 147kw Petrol Engine FWD Convertible 03/07-06/10
•AUDI 8J9 2.0 TFSI 8J9 155kw Petrol Engine FWD Convertible 05/10-on
•AUDI TTS 8J9 T.0 TFSI 8J9 200kw Petrol Engine AWD Convertible 05/08-on
•AUDI TTRS 8J9 2.5 TFSI 8J9 250kw Petrol Engine AWD Convertible 07/09-on
•VW Scirocco Mk3 2.0t FSI and 1.4 TSI (turbo only) 06-on Mk3 195kw Petrol Engine FWD Coupe 06/06-on
•VW Scirocco Mk3 2.0t FSI and 1.4 TSI (turbo only) 06-on Mk3 154kw Petrol Engine FWD Coupe 06/06-on
•VW Scirocco Mk3 1.4 TSI (turbo only) Mk3 90kw Petrol Engine FWD Coupe 06/06-on
•VW Scirocco Mk3 1.4 TSI (turbo only) 137 188kw Petrol Engine FWD Coupe 11/09-on
•SKODA VRS & RS 1Z3 147kw Petrol Engine FWD Hatchback 01/08-on
•SKODA VRS & RS 1Z5 147kw Petrol Engine FWD Wagon 10/05-on
•VW Golf GTI MK6 2.0 TSI 08-13 5K1 155kw Petrol Engine FWD Hatchback 04/09-11/12
•VW Tiguan 2.0 TSI 11-on 5N_ 132kw Petrol Engine AWD Closed Off-Road Vehicle 05/11-on
•VW Tiguan 2.0 TSI 11-on 5N_ 155kw Petrol Engine AWD Closed Off-Road Vehicle 05/11-on
•VW Tiguan 2.0 TFSI 07/-on 5N_ 147kw Petrol Engine AWD Closed Off-Road Vehicle 09/07-on
•VW Tiguan 2.0 TFSI 07/-on 5N_ 125kw Petrol Engine AWD Closed Off-Road Vehicle 09/07-on
GFB DV+ introductory price!
- VAG Cafe
- Registered for: 20 years 5 months
- Car Model: RS3
- Membership No: 675
- Donnie Darko
- Colonel
- Membership No: 1834
Re: GFB DV+ introductory price!
Got mine
Thanks for the awesome service
Ex: 2016 BMW M4
Ex: 2016 Audi RS3 8V
Ex: 2016 VW Golf 7 ED40 Clubsport DSG
Ex: 2012 VW Golf 6 ED35 Manual - 342WHP and 500NM
Ex: 2015 BMW F21 M135i Sport Auto - 393.2WHP and 639NM
Ex: 2013 BMW F20 M135i Sport Auto - 332WHP and 626NM
Ex: 2012 Golf R DSG - 300WHP and 473NM
Ex: 2010 Scirocco DSG 155KW - 300.8WHP and 416NM
Ex: 2008 Ford Focus ST - 262.2WHP and 425NM
Ex: 2006 Golf 5 GTI DSG
- Taz0
- Car Model: Polo 9N3 2.slow
- Membership No: 1925
Uncle from what I see the 1.8t dv+...
Is it a complete replacement unit ?
Like so ?
http://gfb.com.au/products/blow-off-and ... bov-by-gfb
Like so ?
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
Mk5 R32
- VAG Cafe
- Car Model: RS3
Hey bru,
Thats the unit yes
I have Forge 008 units in stock for the 1.8T BUT if you want this GFB badboy, i'll have it added to my next shipment
Thats the unit yes
