Mp9 coil dicktator and distributor setup connection
mk1strand
Post by mk1strand » Sun Jun 29, 2014 7:16 pm
All the wiring is done just want to know the last thing how do you setup the dicktator without the TP100 module
I read something that you connect the coil and distributor can someone just give clarity on that please and thank you.
its a dicktator standard
Taz0
Car Model: Mk1 golf
Membership No: 1925
Re: Mp9 coil dicktator and distributor setup connection
Post by Taz0 » Sun Jun 29, 2014 8:50 pm
On the mp9 coil
Ground to ground
Positive to ignition
Green / thin wire to dictator trigger out wire
On distributor
Ground to ground
Positive to tps 5v positive
Trigger to dictator trigger in signal wire
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVO Authorised Dealer
REVOSA
mk1strand
Post by mk1strand » Sun Jun 29, 2014 10:14 pm
Will see if i can figure that out thank you
mk1strand
Post by mk1strand » Mon Jun 30, 2014 7:34 am
Will this spark the car or should i go tp100
Taz0
Car Model: Mk1 golf
Membership No: 1925
Post by Taz0 » Mon Jun 30, 2014 7:58 am
It will spark the car... No need to go tp100 if you have a mp9 coil
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVOSA
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:12 am
<a href="http://s1143.photobucket.com/user/phili ... 0.jpg.html" target="_blank"><img src="http://i1143.photobucket.com/albums/n63 ... WA0030.jpg" border="0" alt=" photo IMG-20140629-WA0030.jpg"/></a>
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:13 am
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:14 am
Is that image correct?
THANAS
Car Model: MkV Jetta TFSI Sportline
Membership No: 2035
Post by THANAS » Mon Jun 30, 2014 11:27 am
Your scale is out.
Hehe, looks correct as per what the others are recommending.
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:33 am
I didnt draw it the guy connecting it did
mk1strand
But thank you ccbb hopefully we start tonight
THANAS
Membership No: 2035
Post by THANAS » Mon Jun 30, 2014 11:51 am
lekker, which motor did you end up going with?
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__CCBB ADY Citi
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:55 am
Still the 1600i just getting car to run boss complained as i worked with car and mp9 didnt work nice still getting the 1.8 20valve NA
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:58 am
The 20 valve should be done end of november
mk1strand
Post by mk1strand » Mon Jun 30, 2014 11:37 pm
Ok so we got car to turn and all that but not starting or idling its started once and just died again i think its a timing problem so wil look at that tomorrow night
Taz0
Car Model: Mk1 golf
Membership No: 1925
Post by Taz0 » Tue Jul 01, 2014 5:16 am
Have you loaded a start up map?
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVOSA
THANAS
Membership No: 2035
Post by THANAS » Tue Jul 01, 2014 6:45 am
Not necessarily timing, could be fueling too. Check whether all your sensors are working correctly and then tow it to your tuner. No point fussing around yourself, there's a reason they charge for what they do, it's because they're better than you :P
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__CCBB ADY Citi
8Valver
Car Model: 1.8i Citi Sport
Post by 8Valver » Tue Jul 01, 2014 9:49 am
Are you reading water temperature? Also wont start otherwise..
mk1strand
Post by mk1strand » Tue Jul 01, 2014 10:36 pm
Car starts and drives got a tuned map from friend just have a problem with my throttle body car cant idle it closes totaly tps is connected correct so no idea what it is made a temp solution to keep it open a bit wil take it to dyno tec soon and post some power figures
Taz0
Car Model: Mk1 golf
Membership No: 1925
Post by Taz0 » Tue Jul 01, 2014 10:50 pm
What throttle body are you using ?
Adjust the idle screw...
If you are using mp9 throttle body then drill and tap a screw in to act as an idle adjustment screw
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVOSA
mk1strand
Post by mk1strand » Tue Jul 01, 2014 10:51 pm
Its a import motor intake so i have no idea
mk1strand
Post by mk1strand » Tue Jul 01, 2014 10:55 pm
mk1strand
Post by mk1strand » Tue Jul 01, 2014 10:56 pm
Its an old photo so not sure what that is still same intake
Taz0
Car Model: Mk1 golf
Membership No: 1925
Post by Taz0 » Wed Jul 02, 2014 2:50 am
If its still the same throttle body then you need to make up an idle screw so that it can just keep it a crack open
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVOSA
mk1strand
Post by mk1strand » Wed Jul 02, 2014 7:04 am
How do i do that yes its the same
