Speedo drops, ABS, Powersteering and management light flashs
ssbarnard
Car Model: Polo Tdi Sportline 2005
Post by ssbarnard »
The following problem comes up sporadically:
My ABS light, Power steering light, management light, and warning light comes up coupled with the speedo dropping to 0km/h.
When turning off the car and starting it again, it goes away and returns...whenever.
I took it for a VAG and the following fault was picked up: 00597 Differing wheel speed impulse. Value of resistance too great.
I assume it's the speed sensor...the problem: where.
I don't really know what to do and how to go about fixing it. If I can pin-point which wheel it is, I can obviously help the cause.
any ideas?
Further to this, I find a bit of shuddering when braking. I have replaced the front disks, but the problem is there. It seems less...but still there. I want to say that the next step is to replace the wheel bearing, but I don't want to change it if it's not necessary.
Don't know if these two problem is related?
Chuck_Norris
Registered for: 13 years
Car Model: Polo 1.9 TDI
Re: Speedo drops, ABS, Powersteering and management light fl
Post by Chuck_Norris »
1st check you earth strap,
the one from the battery to the body. They corrode and also cause these problems some times.
ssbarnard
Post by ssbarnard »
Thanks man. Ive gone through that rigmarole. Not avail
Sinbad
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
You have a wiring problem. Check the wiring to the wheel speed sensors under the car. It's probably chafed through somewhere
Sent from my SM-G900H using Tapatalk
ssbarnard
Post by ssbarnard »
Thanks gents...
I will let you know what the result is
sean919
Car Model: FD3S RX7, Amarok
Post by sean919 »
Caddyon had the same issue, turned out to be bad wheel bearing housing. Had to replace the whole thing I think.
PM him and ask...
'13 Amarok BiTDi 4x4 (Bike Trailer)
'95 Mazda RX7 FD3S (Racecar)
'16 KTM 350 SX-F (Dirt Toy)
'09 KTM 450 SMR (Racebike)
'11 KTM 690 SMC-R (Street Toy)
'08 Range Rover Sport TDV8
'08 BMW 320d M-sport
'05 9N3 Polo Sportline - 1.9 TDi BT
'08 Velociti 1.4i - 2.0 16v ABF
'10 Audi A3 1.6 (Dubai)
'01 Golf IV 1.6 (UK)
'06 Corsa Ute 1.4
Caddyon
Car Model: Polo 9N3 1.9Tdi Sportline
Membership No: 2025
Post by Caddyon »
sean919 wrote:Caddyon had the same issue, turned out to be bad wheel bearing housing. Had to replace the whole thing I think.
PM him and ask...
Yeah that is exactly what happened to mine.
Bearing housing was worn causing trouble between the speed sensor and the bearing.
What was your solution ?
Tyrone - SR Tuned - http://www.facebook.com/srtuned
Current 06 9N3 Sportline - 1.9 BIG TURBO TDi SRTuned / Profiturbo.com
Power Figures 221wkw and 569wnm
Dezzi Drags = Boost + Diesel, no gas : 12.5
Current 2010 KTM 200 XC-W
Ex=Vw MkI Citi
Ex=Ford Ranger 2500Tdi 4x4 Supercab
Ex=Vw Caddyon 2.0 8v
Ex=2001 Vw Jetta 4 v5
Ex=2000 Opel Corsa GSI
Ex=1967 Ford Anglia 1600 Sport
Ex=1999 Opel Corsa Ute Chin Scraper
ssbarnard
Post by ssbarnard »
I don't have a solution yet. Took it in for a check today. Tell me, what did it end up costing you? I am bloody fed up with the issue. Did your powersteering also give issues?
Caddyon
Membership No: 2025
Post by Caddyon »
ssbarnard wrote:I don't have a solution yet. Took it in for a check today. Tell me, what did it end up costing you? I am bloody fed up with the issue. Did your powersteering also give issues?
No actual powersteering issue. But the powersteering light was on.
All because of facking bearing housing. I will have to pull out the receipt to double check cost.
Ex=Vw MkI Citi
ssbarnard
Post by ssbarnard »
Thanks bud. the problem is that they cant determine which bearing housing it is. Its a bit frustrating
Caddyon
Membership No: 2025
Post by Caddyon »
ssbarnard wrote:Thanks bud. the problem is that they cant determine which bearing housing it is. Its a bit frustrating
It is usually the front left housing...being the wheel that picks up all the **** from left hand side of the road.
it might just be the bearing. Diagnostics should tell you which speed sensor isn't picking up the bearing.
Ex=Vw MkI Citi
Deranged_9n3
Darth Vader
Registered for: 14 years 6 months
Car Model: Polo 1.9TDI Sportline
Membership No: 1639
Post by Deranged_9n3 »
Have you taken the sensors out and given them a good clean ??
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
AlexTDi
Registered for: 13 years 10 months
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi »
First thing I would look at is the earth cable, give it a clean and make sure it is making proper contact.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Ngcebo
Re: Speedo drops, ABS, Powersteering and management light flashs
Post by Ngcebo »
Howsit guys . How did u sort out the problem. Im experiancing the same problem with my crosspolo 2008 model. Speedo drops. And it shows light. Alse vibrate when braking
Masetisiyabonga
Registered for: 5 years 3 months
Post by Masetisiyabonga »
Hi guys I that most people are saying its the wheel bearing, I am experiencing the same problem on my vw polo 2014 model.
•Speed meter is always on zero
•Odometer km reading stopped working
•Abs light is always on.
•Power steering light went on and off just once
•When I turn corners my fuel gauge goes down n up again all the time
Can all this happen because of the bearing being lose on one of the wheels?
PeterTech
Registered for: 6 years 8 months
Car Model: Polo 1.6 TDI
Post by PeterTech »
Check your battery. TDIs like to act funny when the battery is low.
Sent from my G3312 using Tapatalk
Gaylin90
Registered for: 7 years 7 months
Post by Gaylin90 »
Hi guys had the same issue on my polo,changed both front bearings with carrier issue was still there I changed the earth cable still nothing I didn't a battery change nothing till I came across something very odd was putting tyre wax on my tires and noticed when I did new tyres all round the guys mixed up the tyres so I was running 205/40/17 in the front and rear was 215/45/17 went back to hi-q they changed my rear tyres and my issue was solved after that.
Sangster21
Post by Sangster21 »
Anyone find a solution for the problem ?
MarlonMP
Post by MarlonMP »
Had it checked out all above problems,wheel bearings gone,polo vivo 1.6 2013
TreasureMan
Registered for: 7 years 9 months
Car Model: MK2 Jetta 1.8 clx
Post by TreasureMan »
Masetisiyabonga wrote: Sat Mar 14, 2020 3:32 pm Hi guys I that most people are saying its the wheel bearing, I am experiencing the same problem on my vw polo 2014 model.
Having the same issue with a 1.4 polo, 2014 model. I diagnosed it only to find that the two speed sensors are faulty. Going to change them and will come back and tell you if it worked.
Ramonwolff
Post by Ramonwolff »
Any luck with this gents??
I've got the exact same problem
Modisha
Post by Modisha »
Hi gents I trust everyone is well I'm having the same problem I drive as polo 1.9 tdi (ATD) I took it in nd I was told I need to change the left front wheel bearing...Il do so over the weekend and get back to you guys
Gaylin90
Post by Gaylin90 »
Good day gents
Had the exact same issue I replace sensors and bearings still had same issue was told earth cable problem not solved eventually I noticed my tyre size front and rear was not the same a fitment error from dunlop so went back replace all 4 tyres and my issue was gone PERMANENTLY
brads2603@gmail.com
Registered for: 3 years 10 months
Post by brads2603@gmail.com »
Hi Guys
I have this same issue, has anyone figured out the problem as yet?
I see people are talking about bearings but i changed all bearings not so long ago.
brads2603@gmail.com
brads2603@gmail.com wrote: Thu Sep 02, 2021 7:19 am Hi Guys
I had changed the left abs sensor yesterday but still nothing. could it possibly be a a wiring problem as well. Should i change front bearings again for safety.
