Alternator Bearing or water pump - Citi Golf
Little D
Car Model: Polo 1.2 TSI
Post by Little D » Mon Apr 21, 2014 8:29 pm
Hi all..
Over last few weeks, have a weird rubbing noise around the alt and water pump area. I took belet off and noise gone so definately one of the two..
I just need to establish which is exactly the culprit without buying one item and its the next.. The noise isn't there constantly and doesn't get louder or anything.. The belt is fine and tension is ok..
Anyone can help will highly be appreciated.
I even used the longer screwdriver and placed against alt to hear but sound is all different.
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Pieta
Car Model: 97 Polo Classic
Membership No: 1909
Re: Alternator Bearing or water pump - Citi Golf
Post by Pieta » Mon Apr 21, 2014 9:43 pm
Little D wrote:Hi all..
Most probably the water pump. What's the mileage on your car? You can also feel for play on the water pump pulley.
Pieter "Pieta" Oberholzer
97 - Polo Classic 1.6i MP9
- Bilstein + H&R
- 57mm Freeflow
80.4hp /110NM @ Panic's Dyno
20V AGU - http://vwclub.co.za/forum/viewtopic.php?f=11&t=193644
Little D
Post by Little D » Mon Apr 21, 2014 10:56 pm
210000.. I did change as precaution some time back..
I span the pulley and its doesn't have much play..
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Post by Naku786 » Mon Apr 21, 2014 11:03 pm
Start the car and get a longish screwdriver, put the sharp end on waterpump/alternator and your ear on the other end... you will hear were the noise is coming from... unconventional but works
Little D
Post by Little D » Mon Apr 21, 2014 11:06 pm
Sharp . Tried with alty only. Will do on waterpump also. Thanks
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Pieta
Membership No: 1909
Post by Pieta » Mon Apr 21, 2014 11:25 pm
Naku786 wrote:Start the car and get a longish screwdriver, put the sharp end on waterpump/alternator and your ear on the other end... you will hear were the noise is coming from... unconventional but works
+1 This works like a charm
- Bilstein + H&R
- 57mm Freeflow
Atsta
Post by Atsta » Tue Apr 22, 2014 12:18 am
alternativelly, get some of that penetrating/lubricating fluid, the one that comes with a long thin red tube that gets pressed into the nozzle, so that you can have very accurate control over where you spray it.
aim the spray at any of the suspected components, don't forget the idler pulley over which the fan belt runs, those idler pulleys bearings are known to run dry and start to make noise.
the one where the noise goes silent is likely to be the culprit
I have known people to change steering pumps, air-con pumps, alternators etc, very expensive exercise, and the noise still doesn't go away....then they do the trick above, and when the oil gets into the idler pulley, the noise went away, and the replacement cost is minimal compared to the other big components.
Little D
Post by Little D » Tue Apr 22, 2014 8:08 am
Thanks Guys
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Apr 22, 2014 8:10 am
One way to test the alternator is to take the belt off and spin up the pulley with your fingers, it should be quiet - no rumbling noises.
Current rides:
Hyundai - 1.4 Getz (daily)
Little D
Post by Little D » Tue Apr 22, 2014 1:04 pm
I will certainly.
The alt does sound a bit rough but not the noise that its making.
sounds like a wobble sound or so.
the waterpump does have a screetch.
Waterpumps , Meyle i heard is good but how does it compare to OEM?
Well Vw wants over R1300 for it :-)
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Naku786
Cake Laaitie Killer
Post by Naku786 » Tue Apr 22, 2014 2:05 pm
Little D wrote:I will certainly.
Just buy the pump, you can use the same housing. Change your themostat while you at it. I used a GMB brand product, brilliant quality IMO.
Pieta
Membership No: 1909
Post by Pieta » Tue Apr 22, 2014 2:26 pm
GW Sells Meyle and in all honesty, I have used 3 of these and never had issues. Even have a Meyle part on my ABF.
- Bilstein + H&R
- 57mm Freeflow
Little D
Post by Little D » Tue Apr 22, 2014 5:28 pm
I have been to one spare shop and offered me GMB. I wasn't really knowledgable about it though. They also said its good. Well the meyle one is R100 more so I thought I'd stick to what I know.. Vw quoted me for thermo R141 which isn't too bad.
I checked now and the waterpump is definetely making noise. I used the screwdriver method
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
thepot
Car Model: vivo 1.6
Post by thepot » Tue Apr 22, 2014 5:35 pm
How much the waterpump cost?
Do it once, do it right!
'13 Polo Vivo 1.6 - stock
'08 rox 1.4i - 76kw - sold
Little D
Post by Little D » Tue Apr 22, 2014 5:45 pm
Around 400-500
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
thepot
Car Model: vivo 1.6
Post by thepot » Tue Apr 22, 2014 10:04 pm
Awe. Thanks buddy
Naku786
Cake Laaitie Killer
Post by Naku786 » Wed Apr 23, 2014 7:44 am
Little D wrote:Around 400-500
I paid R 230.00 for a GMB pump from midas :hi:
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Wed Apr 23, 2014 8:00 am
Yes it's cheaper if you buy just the pump without the housing...
Current rides:
Little D
Post by Little D » Wed Apr 23, 2014 8:23 am
I got quote on GMB complete - R320
So roughly same.
Who stocks Echlin Though?
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Naku786
Cake Laaitie Killer
Post by Naku786 » Wed Apr 23, 2014 8:27 am
Little D wrote:I got quote on GMB complete - R320
So roughly same.
Autozone and most decent spares shop
thepot
Car Model: vivo 1.6
Post by thepot » Fri Apr 25, 2014 2:06 pm
Goldwagen quote - R384. Complete
make is WAG.
Any good/reviews?
Naku786
Cake Laaitie Killer
Post by Naku786 » Fri Apr 25, 2014 2:13 pm
thepot wrote:Goldwagen quote - R384. Complete
make is WAG.
Any good/reviews?
WAG is the GW house brand, never used it so cant comment. I always settle for topran/febi/meyle if I buy from GW...
Echlin or GMB from spares shops...
thepot
Car Model: vivo 1.6
Post by thepot » Fri Apr 25, 2014 2:16 pm
Eish.
Thanks naku, will ask for meyle if I'm there.
where's torker now to comment. Sure he has used it all before lol
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Sat Apr 26, 2014 7:11 am
I've bought a GMB pump from Midas before and it served me well. Thermostat I will always go OEM for extra peace of mind. This is what I'll be fitting in both my 16V's - spot the difference...
Current rides:
Taz0
Car Model: Mk1 golf
Membership No: 1925
Post by Taz0 » Sat Apr 26, 2014 11:18 am
1 outlet
Mk1 caddy tfsi dsg
Polo 9n3 2.0 8v
REVO Authorised Dealer
REVOSA
