Dicktator 60-2 Help
- BADBOY
- Car Model: Hilux 3.0D4D
- Membership No: 797
Dicktator 60-2 Help
Hi guys,
I need some assistance with my unit. I replaced my Dicktator Standard unit on my Golf two weeks ago and went with the following:
-60.2 Unit
-2.0 ADY with Crank angle Sensor
-Golf Four Pin coil pack
-New GW Crank Angle sensor (magnetic)
The issue I am having is that after hooking up everything, the unit is not picking up timing. The lead wire going to crank angle sensor(thick red one) has blue/white and shield(Gnd), I wired up as (pin1 blue,pin2 white,pin3 shield/gnd) onto the three pin GW unit. The unit has been sent to Dictator for testing and has been given a clean bill of health.
Could the harness or magnetic pickup be causing the issue?
-60.2 Unit
VW Golf GTi 16vT(current)
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW Golf IV GTI 132 REVO-Ex
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- chucker02
- Car Model: Citi ADY
Re: Dicktator 60-2 Help
Doesnt it need the hall type sensor instead of the magnetic one?
1971 VW beetle
1971 VW beetle
- General
- Car Model: Golf GT
- Membership No: 1464
Yip very difficult to distinguish between the two types of senders, you might have the wrong sender in there. I normally check it with a multimeter - if you get a resistance reading between pin 1 and 3 it's a Hall type sender and if you get a reading between pin 1 and 2 it's magnetic. Default for Dicktator 60-2 is Hall, you only get magnetic if you specify you want it...chucker02 wrote:Doesnt it need the hall type sensor instead of the magnetic one?
Current rides:
Hyundai - 1.4 Getz (daily)
- Pieta
- Car Model: 04 A4 1.8T 6spd S-Line
- Membership No: 1909
Sensor needed from GW is part number 10703. Hooked one of these up to Dictator 60-2, checked on the laptop if I get engine rpm reading while cranking and voila. Working. Shout if you don't come right with the wiring, can double check mine.
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- BADBOY
Torker wrote:Yip very difficult to distinguish between the two types of senders, you might have the wrong sender in there. I normally check it with a multimeter - if you get a resistance reading between pin 1 and 3 it's a Hall type sender and if you get a reading between pin 1 and 2 it's magnetic. Default for Dicktator 60-2 is Hall, you only get magnetic if you specify you want it...chucker02 wrote:Doesnt it need the hall type sensor instead of the magnetic one?
Eish I was not aware of that(i can kick myself)...will make a turn to GW tomorrow and ask for the hall type.
thanks Torker
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- BADBOY
thanks for the feedback guys!
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- Pieta
If this helps,
Been there. Read through the post as linked below, that sensor gets discussed. Use it, don't use it.
http://www.vwclub.co.za/forum/viewtopic ... 2&t=161968
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- BADBOY
Pieta wrote:If this helps,
thanks boet, will give it a try tomorrow.
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- Pieta
No probs, if you worry about the wiring, let me know can take a pic of how mine is wired up, Torker assisted me with the wiring.BADBOY wrote:Pieta wrote:If this helps,
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
Read through that post again just now - was still running the 8V in the GT at that stage, how time flies...Pieta wrote:No probs, if you worry about the wiring, let me know can take a pic of how mine is wired up, Torker assisted me with the wiring.BADBOY wrote:Pieta wrote:If this helps,
Current rides:
- Pieta
Yeah since then, you set the benchmark with the 16v, made all of us jealous and I am broke financially. LOLTorker wrote:Read through that post again just now - was still running the 8V in the GT at that stage, how time flies...Pieta wrote:No probs, if you worry about the wiring, let me know can take a pic of how mine is wired up, Torker assisted me with the wiring.BADBOY wrote:Pieta wrote:If this helps,
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- BADBOY
Hi, gave goldwagen a call they claim part number is incorrect.Pieta wrote:Sensor needed from GW is part number 10703. Hooked one of these up to Dictator 60-2, checked on the laptop if I get engine rpm reading while cranking and voila. Working. Shout if you don't come right with the wiring, can double check mine.
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- Pieta
Which Goldwagen? Phone Wikus or Ashley at Goldwagen Delarey. Got mine from there and I checked the invoice last night.BADBOY wrote:Hi, gave goldwagen a call they claim part number is incorrect.Pieta wrote:Sensor needed from GW is part number 10703. Hooked one of these up to Dictator 60-2, checked on the laptop if I get engine rpm reading while cranking and voila. Working. Shout if you don't come right with the wiring, can double check mine.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- BADBOY
Pieta wrote:Which Goldwagen? Phone Wikus or Ashley at Goldwagen Delarey. Got mine from there and I checked the invoice last night.BADBOY wrote:Hi, gave goldwagen a call they claim part number is incorrect.Pieta wrote:Sensor needed from GW is part number 10703. Hooked one of these up to Dictator 60-2, checked on the laptop if I get engine rpm reading while cranking and voila. Working. Shout if you don't come right with the wiring, can double check mine.
I owe you guys a drink. Gave them a call all sorted, will collect tonight from Ashley.
thanks once again.
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- THANAS
- Forum Advertiser
- Registered for: 10 years 9 months
- Car Model: AW Polo GTi
- Membership No: 2035
Does dictator only work with hall units? I'm running a single magnetic pickup from a VR6 in my ADY with no hassles. On spitronics though.
Sent via Hedwig
Sent via Hedwig
- Taz0
- Car Model: Polo 9N3 2.slow
- Membership No: 1925
Dicktator works on magnetic aswell it just needs to be changed in the box
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
Mk5 R32
- BADBOY
More info pleasetaz0 wrote:Dicktator works on magnetic aswell it just needs to be changed in the box
Sent from my iPhone 5s using Tapatalk
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- Pieta
Mine worked on that magnetic sensor from the beginning. I fired up the ABF yesterday, worked 100%.CitiCitiBangBang wrote:Does dictator only work with hall units? I'm running a single magnetic pickup from a VR6 in my ADY with no hassles. On spitronics though.
Sent via Hedwig
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
You have to know what (60-2) box you've got and use the right sensor...Pieta wrote:Mine worked on that magnetic sensor from the beginning. I fired up the ABF yesterday, worked 100%.CitiCitiBangBang wrote:Does dictator only work with hall units? I'm running a single magnetic pickup from a VR6 in my ADY with no hassles. On spitronics though.
Sent via Hedwig
Current rides:
- Pieta
Then I might have been lucky!Torker wrote:You have to know what (60-2) box you've got and use the right sensor...Pieta wrote:Mine worked on that magnetic sensor from the beginning. I fired up the ABF yesterday, worked 100%.CitiCitiBangBang wrote:Does dictator only work with hall units? I'm running a single magnetic pickup from a VR6 in my ADY with no hassles. On spitronics though.
Sent via Hedwig
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- BADBOY
Hi guys-I am still battling, no RPM even with the new sensor. PN 10703. The sensor is magnetic!(got stuck to the body while I was changing it) Wired as per diagram....no joy
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- General
Swap the Pos and trigger wires around and try again. Is your laptop connecting to the Dicktator? (Bar going green)BADBOY wrote:Hi guys-I am still battling, no RPM even with the new sensor. PN 10703. The sensor is magnetic!(got stuck to the body while I was changing it) Wired as per diagram....no joy
Current rides:
- BADBOY
Dude you are are legend! I got RPM. Thanks
On the main setup what settings do i use.
Spark mode-wasted spark home position
Dwell-constant duty percentage or charge
Trigger angle?
Trigger angle?
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
- General
PM me your e-mail address so that I can send you the Dicktator write-up...BADBOY wrote:Dude you are are legend! I got RPM. Thanks
Trigger angle?
Are you running wasted spark?
I'll send you the same maps I sent to Pieta, his ABF started up right away on one of them.
Current rides:
- BADBOY
Yes wasted spark, using a golf 4 coill. 4 pin.
Thanks email sent
Thanks email sent
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
VW CC 2.0T DSG
Volvo V50 2.0i-
Volvo V40 T
VW GOLF VR6-
VW Jetta CLI 16v
