ITG vs EVOMS TFSI
Preasen
ITG vs EVOMS TFSI
Post by Preasen » Fri Mar 07, 2014 8:01 am
Hi Guys
I've read up countless topics on tfsi inatkes and it boils down to this 2brands ..
Well i managed to source a ITG after turning grey and giving up a few times ..
I fitted it yesterday wic was fairly simple ..
Just a few questions ..
1. How much louder is the evoms to the itg ( Assume it is as its a open filter )
2. Does the ITG need to adapt to the car and will it get louder after a few hundred km's
3. I know software will need to be done now to accompany the mod performance wise but will it also make it louder
The intake sounds awesome and car dumps/turbo spoils insanely but i would prefer it to be alittle louder ..
Thanks in advance ..
Pre
Balls
Car Make: BAARRP
Car Model: PSSSHH
Membership No: 1708
Re: ITG vs EVOMS TFSI
Post by Balls » Fri Mar 07, 2014 8:17 am
What car? Software will help more boost bigger dump. How does the ITG adapt to the car? You mean the car adapt to the ITG..
2003 Subaru Impreza WRX
2012 KTM XCF-W 250
2006 Audi A4 DTM
2007 Polo TDI Sportline
2011 Golf GTI VI DSG
2007 Golf GTI V K04
2008 SEAT Cupra 1.8T
2005 Polo TDI Sportline
Preasen
Post by Preasen » Fri Mar 07, 2014 8:23 am
Golf 5 gti .. yea car adapts to the itg ..
Does the ecu recognise more air intake and does it automatically adapts to that ?
I had a RunX rsi previous and thats what happened with that ecu ..
ryanrich
Car Model: A4 2.0T S-Line
Post by ryanrich » Fri Mar 07, 2014 8:33 am
ITG or Stealth Atom FTW. I hated the sound of an open intake, sounds like a vacuum cleaner sucking. EVOMS is loooooud.
crumbs
Race Chip
Car Model: Citi Rox 1.6i
Post by crumbs » Fri Mar 07, 2014 8:45 am
Do you still have the cover inside your bonnet? if so, remove it....
Preasen
Post by Preasen » Fri Mar 07, 2014 10:03 am
You talking abt the foam surround that comes with the intake ? i fitted that as well ..
Bit of a crap heatshield it separates the filter from the area the cold air enters the engine bay .. need to build up a better heatshield
crumbs
Race Chip
Post by crumbs » Fri Mar 07, 2014 10:14 am
Nope, the black heatshield that is clipped on the inside of the bonnet.
Preasen
Post by Preasen » Fri Mar 07, 2014 10:15 am
ok thanks will give that a try
DazzG_177
Car Make: SEAT
Car Model: Leon Cupra
Post by DazzG_177 » Fri Mar 07, 2014 10:17 am
Are you at the highveld or coast?
Highest I flowed with EVOMS on my K04 TFSI was 289 g/s.
Still going to try a few other intakes out.
Nav
Car Model: MK7 Fiesta ST
Post by Nav » Fri Mar 07, 2014 10:32 am
Sup Dude
ITG Will adapt to the car it may seem like you cannot even hear it when you first fit it on. once you drive 200 some odd km's you will start to hear the build up and the tooosh! lol.
2013 Fiesta ST, AMG Reps, 35mm HnR Stance, Primaforce Zorst
Preasen
Post by Preasen » Fri Mar 07, 2014 10:41 am
Thanks Nav i tawt so that would happen .. btw seen you car around in Durbz looks Sweeeeeeet .... :drool:
Preasen
Post by Preasen » Fri Mar 07, 2014 4:46 pm
Daz im at the Coast ..
@ryan i think i wud prefer louder .. so il swap for the evoms if i get the chance hey ...
Solo786
Autowerks
Car Make: Porsche,BMW,VW
Membership No: 1251
Post by Solo786 » Fri Mar 07, 2014 4:47 pm
ITG is louder under boost than evoms... flows better too
MERCEDES|BMW|PORSCHE|AUDI|VW|FORD
Respect my AuthoriTaah!
Check out Autowerks on Fb
Check out AutoSpa on Fb
Preasen
Post by Preasen » Fri Mar 07, 2014 4:51 pm
I think i sud hear a tfsi with evoms to settle my niggling mind
Solo786
Autowerks
Membership No: 1251
Post by Solo786 » Fri Mar 07, 2014 4:56 pm
depends if you want the performance or the noise..
Preasen
Post by Preasen » Fri Mar 07, 2014 5:01 pm
Point taken definitelythe performance ..
Wouldn't wana spend that amount on an intake just for the noise that would be stupid of me.. guess i should stop stressing abt the loudness of the intake and be happy with the performance level after software is done
Cant be a drastic defference in performance between the 2 intakes .. is der ???
Solo786
Autowerks
Membership No: 1251
Post by Solo786 » Fri Mar 07, 2014 5:59 pm
I havent tried back to back with ITG/EVOMS, But I have seen Stealth Atom 2 back to back with Evoms and Stealth Atom wins by almost 3kw an 8nm over what an evoms makes
Preasen
Post by Preasen » Sat Mar 08, 2014 6:47 am
Thanks for the info Solo .. im going to stick with the itg and add software ..
Post by ruan9n » Sun Mar 09, 2014 12:03 pm
Solo786 wrote:ITG is louder under boost than evoms... flows better too
+1
I had a k&n typhoon, evoms and Itg on my mk5- the Itg was the best with its huge foam filter directly at the air slat in the grille. I got rid of that stinky, filthy itg foam heatshield which blocked off airflow to the filter and made a custom air scoop.
If you plan on running revo software then get an itg, evoms and the atom works well for everything else like unitronic, frc, stealth.
Preasen
Post by Preasen » Sun Mar 09, 2014 12:21 pm
Im thinking of FRnR software ... do u have a diy build for the air scoop .. also wana build 1 and remove the original cause its blocking off the cold air
Post by ruan9n » Sun Mar 09, 2014 1:52 pm
Preasen wrote:Im thinking of FRnR software ... do u have a diy build for the air scoop .. also wana build 1 and remove the original cause its blocking off the cold air
I made a home made heatshield for the itg which I feel directs more air towards the filter. I made it from an old fiberglass gemini gate motor cover I had lying around in my garage.
How it started out.....
Bull3t Proof
Car Model: Ibiza Cupra TDi
Post by Bull3t Proof » Tue Mar 11, 2014 12:58 pm
Use your nose as an intake....lol
As Solo786 says... ATOM FTW. I have done some research on it, and the reviews are AWESOME!
the Evoms on K03 is not as loud when compared to a K04 with Evoms. On my Audi, the Evoms never reached the high Pitch it does on the Cupra.
I am currently looking for the Stealth ATOM.
TDi is Sold Bhai.. Just bought another Leon Cupra!
Crono Ibiza Cupra TDi
White Ibiza Cupra TDi
BMW F30 330d
Preasen
Post by Preasen » Tue Mar 11, 2014 4:33 pm
Jokes u got madir ..
Never tawt ul part will the TDI ..
I'm used to the ITG now .. Loving it jus wana build a better scoop/heatshiled .. I got Kimo on the job for that thanks to ryans pics we working around that ..
When u coming down to durbz bullet ?
