Citi Life - Shocks
Citi Life - Shocks
Hi
Merry X-Mas to all - does anyone know a reputable place with affordable prices for shocks for the above mentioned car?
Thank You
Thank You
2005 Golf Life - 1.6i
2001 Polo Playa 2.0 8v - Sold
1995 Hyundai Accent 150i - Sold
1995 Opel Kadet 140i - Sold
- Life160
- Registered for: 20 years 9 months
Re: Citi Life - Shocks
Gabriels are cheap (around R500 to R600 for the rear (2 shocks) and about R700 to R800 for the front (2 shocks). If you lowered your car - these arent great and I would rather opt for a Koni or Bilstein setup. Koni's are roughly around R4k for the full set.8V Playa wrote:Hi
Thank You
- Car Model: Polo 1.2 TSI
Go to stupa quick. Usually not bad hey
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Car Make: Chevy
- Car Model: Sonic 1.6 LS B&W
Just so i am clear, i know that the life awas a little lower than normal citi's, so if i ask for life shocks and springs i should go lower albeit a little only?
- Post Whore
- Registered for: 18 years 2 months
- Car Model: boat
- Membership No: 1133
- Car Make: Chevy
So i should just ask for life springs?
- Kyle
- General
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
Not if you want shocks
- Car Make: Chevy
Kyle wrote:Not if you want shocks
- Kyle
- General
- Car Make: Porsche
King8v wrote:Kyle wrote:Not if you want shocksShocks are still good. just wanna go lower
Why not go good quality lowering springs? like H&R / Eibach ?
- Car Model: Citi 1.8i Ltd
- Membership No: 1972
then do it properly - get koni's
i know on the citi's that came with 15inch wheels (velo, rox, r line and 1.8i)
1) front shock and rear spring is the same as the normal citi range
2) front spring and rear shock is different. shock is an agents only part and no gabriel or aftermarket option is available.
small drop but noticeable in my opinion.
- Car Make: Chevy
Yeah im leaning towards a lowering kit altogether, as the cost is very similar.
Remember all the imported springs H&R and Eibach were designed for a very much lighter car than we currently have in SA now due to spec changes and safety upgrades the MK 1 got heavier , so if H&R / Eibach say 30 or 35 mm it will go lower . The lowered Mk 1 s don't ride well on standard shocks and particularly cheap ones Gab and Mon and so on ( or the imitation cheap black Bilsteins ) these are all in the same league RUBBISH . The KONI sport adjustable is the best thing you can do to the car , serviceable , adjustable ,unbelievable performance and the rake of the car can be adjusted by the rear shock . Pricy unfortunately R 5800.00 now .
Be cautious as in 2007 the rear spring and shock were changed slightly by VW and the sport springs all sat too low at the rear . If you do a spring and shock conversion this does not apply on any model obviously .
Hope that helps . S
Hope that helps . S
Also remember , shocks are a serviceable part of the car , and have to be replaced regularly , Some manufacturers say every 40 k kilos , this is a little bit over the top but seriously at 75 to 100 k really need to change , If a shock is not leaking it does not mean it is ok , far from it , leaking and mileage are the ways to tell if they are gone . Don't trust shaky machines at the local Speedy they test the mounting rubbers and the tyre pressure and not the shock accurately ha ha . If the car feels wobbly or uncertain change the shocks definitely . A very safety critical part of the car that is always over looked till its too late . Lowering cars with standard or cheap shocks is why these forums are full of complaints about hard ride , and the springs always take the wrap . It definitely is not the springs , its the shocks so if you lower a car with springs only do not expect handling , performance or comfort , because all that comes from the shock not the spring . S
I have Gabriel shortened shocks with H&R springs. I enjoy the ride. I just changed shocks and the Gabriel gave me 100000km. The springs was the best money spent.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Car Make: Chevy
Where do you buy shortened shocks? TWT or supaquick?
Twt doesnt do shocks.
I tried Supaquick and they dont do shorten anymore.
Best to get at spare shops and than get them fitted
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Car Make: Chevy
Sweet. How are gabriel gas riders, the black ones?
No issues hey..
Ride is quite nice
Ride is quite nice
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
on my 1.8i i found the overall ride harder than the stock oil shocks. the spring seat on the rears made the car higher at the back so i changed the rears to OEM and the ride was softer but the handling was better than stock..King8v wrote:Sweet. How are gabriel gas riders, the black ones?
Correct. I had to get refund on rears and got OEM from VW.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Life160
Gabriel shortened shocks on Koni springs are horrific!
My car touches all the time compared to the Koni shocks I had. I should have spent the extra cash and went for a Koni shock.
Sent from my iPad using Tapatalk
