vw golf 1 Hand brake cable and disks.
DJLSchoemm
Car Model: 2006 Ford Ranger 2.5 TDI
Postby DJLSchoemm » Fri Nov 29, 2013 11:42 am
Hi all. Ok so I have converted my wife's citi velo from drums to disks at the rear.
So I had to cut a small section away from the axel to accommodate one of the caliper mounting bolts.
But what I wanted to find out what do you do with the hand brake cable. There is no way I will be able to fit the cable and if I do fit it the angle will be way to much and it will snap the cable.
I used golf 2 gti stub axels and disks and calipers.
I did the conversion because I got all the parts for the same price as new drums and shoes for the car.
Donavan
Re: vw golf 1 Hand brake cable and disks.
Postby Donavan » Fri Nov 29, 2013 11:45 am
U use mk2 cables iirc
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
Howie-WP
Membership No: 2033
Postby Howie-WP » Fri Nov 29, 2013 11:51 am
DJLSchoemm wrote:Hi all. Ok so I have converted my wife's citi velo from drums to disks at the rear.
So I hade to cut a small peace away from the axel to accommodate one of the caliper mounting bolts.
But what I wanted to find out what do you do with the hand brake cable. There is no why I will be able to fit the cable and if I do fit it the angel will be why to much and it will brake the cable.
:crazy:
DJLSchoemm wrote:I did the conversion because I got all the parts for the same price as new drums and shoes for the car.
Drums would be a straight fit, having parts at same price and now you need to mod to make it work.
DJLSchoemm
Postby DJLSchoemm » Fri Nov 29, 2013 12:00 pm
hehe sorry for the spelling this auto correct is driving me crazy!!! :crazy:
I know it would have been a straight fit. But I did the conversion so would just like to know must I cut the axel or something to get the cables to work.
Yes you use Jetta 2 cables.
nd_s
Car Model: 89 Jetta 2 , 03 Polo 05 Polo
Membership No: 1691
Postby nd_s » Fri Nov 29, 2013 12:35 pm
And set the brake bias valve, else the rear will lock up..
DJLSchoemm
Postby DJLSchoemm » Fri Nov 29, 2013 12:52 pm
The velo has a valve at the master cylinder that reduces brake force at the back.
I tested it and the front wheels lock up but not the rears.
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Fri Nov 29, 2013 1:27 pm
Double Post
Current rides:
Hyundai - 1.4 Getz (daily)
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Fri Nov 29, 2013 1:33 pm
1st off, did you fit the calipers in the right postion? It is possible to fit them in the wrong postion if you swap the stub axles around. What handbrake cables are you using? The correct ones is Jumbo GTi (Goldwagen stock code A159). I used the existing handbrake cable guides on the rear axle, the cables goes into the calipers from the bottom and everything lines up 100%
Current rides:
DJLSchoemm
Postby DJLSchoemm » Fri Nov 29, 2013 1:43 pm
My calipers sit exactly like yours.
I used the cables from a Jetta 2 with disk brakes at the back but the calipers and stub axels came from a Golf 2 GTI.
I also had to cut a section from the rear axel to get the one bolt that holds the caliper in place to fit.
2226cc
Postby 2226cc » Fri Nov 29, 2013 8:39 pm
Post pics on the setup so people can get a clear idea of how you've done it and why cutting was needed.
DJLSchoemm
Postby DJLSchoemm » Tue Dec 03, 2013 11:29 am
Ok the cable is connected but when I pull the handbrake up the car will still move?
So I have no idea what is going on with the thing!!
Tander
Car Model: Leon Cupra
Membership No: 1713
Postby Tander » Tue Dec 03, 2013 11:33 am
DJLSchoemm wrote:Ok the cable is connected but when I pull the handbrake up the car will still move?
Like above posted asked - post pictures of what you have done so we can clearly see.
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
2226cc
Postby 2226cc » Tue Dec 03, 2013 11:35 am
The fact you had to cut something away doesn't bode well. Haven't heard of others who've done this conversion having to cut away stuff.
Baldwin02002
Car Model: Mk2 GTS
Postby Baldwin02002 » Thu Dec 05, 2013 12:47 pm
Hi, i did mine early this year. I fitted Jetta 2 second generation cables as the first generation ones were shorter. I bought them from GW.
Mk2 GTS 1.8 --> 2.0 16v MP9
S4 2004 --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
DJLSchoemm
Postby DJLSchoemm » Fri Dec 06, 2013 1:39 pm
Ok. Here is a photo.
I use Jetta 2 cables.
This is the problem I am having.
THANAS
Car Model: MkV Jetta TFSI Sportline
Membership No: 2035
Postby THANAS » Fri Dec 06, 2013 1:58 pm
DJLSchoemm wrote:Ok. Here is a photo.
Be honest, did you drive over a peacock? :???: :lol:
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Fri Dec 06, 2013 2:15 pm
I'll take a pic of my setup this weekend so that we can compare it, my cable definitely doesn't have that kink...
Current rides:
DJLSchoemm
Postby DJLSchoemm » Fri Dec 06, 2013 3:19 pm
Thanks.
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Mon Dec 09, 2013 11:58 am
DJLSchoemm wrote:Thanks.
I forgot about those pics, will try to get some tomorrow when changing my rear wheel bearings...
Current rides:
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Postby Naku786 » Mon Dec 09, 2013 12:27 pm
subd for updates :grin:
Taz0
Wire Puller Extraordinaire
Car Model: Mk1 golf
Membership No: 1925
Postby Taz0 » Tue Dec 10, 2013 9:11 am
How do you guys keep it from locking up?
Always wanted to do the conversion but was too scared of the lock up stories I hear of
Contact me for your Revo software
And air suspension needs
REVO Authorised Dealer
EUROProjektz Garage
DJLSchoemm
Postby DJLSchoemm » Tue Dec 10, 2013 9:44 am
On the Velociti and probably all the newer golf 1 models there are an valve at the front on the master cylinder before it goes to the rear. Will take a pic. That valve reduces braking force to the rear.
Works well the front locks up I could not get the rears to lock up yet.
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Tue Dec 10, 2013 6:07 pm
DJLSchoemm wrote:On the Velociti and probably all the newer golf 1 models there are an valve at the front on the master cylinder before it goes to the rear. Will take a pic. That valve reduces braking force to the rear.
I never fitted a bias on my Velo, never needed it - it had the same brakes as my GT.
Pics as promised - no kink in the cable:
No need to cut anything to get the brakes to fit:
Current rides:
DJLSchoemm
Postby DJLSchoemm » Wed Dec 11, 2013 9:39 am
I have no idea why my setup looks different. The stub axel can only go on one way ells the holes don't line up. I will have a look over the weekend and see if I can sort this out.
Thanks for the photos.
Taz0
Car Model: Mk1 golf
Membership No: 1925
Postby Taz0 » Wed Dec 11, 2013 10:02 am
This is one mod I'll be doing when my drums are worn out
EUROProjektz Garage
Return to “General Tech Discussions”
Users browsing this forum: PapaJo and 68 guests
