Polo 1.9 Tdi 6 speed gearbox in a jetta 4 1.9 Tdi ?
Tdi jetta 4 ever
Car Model: Jetta 4 1.9 Tdi, Isuzu2.5DKBLe
Post by Tdi jetta 4 ever »
Does it fit? Any modifications needed? Is the gear ratios the same as the 5 speed jetta box except for the 5th and 6th gear?
Robin
robinwisse@gmail.com
waynemodz
Car Make: SEAT
Car Model: 1.8T 20v IC
Re: Polo 1.9 Tdi 6 speed gearbox in a jetta 4 1.9 Tdi ?
Post by waynemodz »
Tdi jetta 4 ever wrote:Does it fit? Any modifications needed? Is the gear ratios the same as the 5 speed jetta box except for the 5th and 6th gear?
no the ratios are not the same.
yes it fits.
you need the cable shift system with the gbox. plug and play
Wayne Modz
Toxic Tuning
Tdi jetta 4 ever
yes it fits.
Thanks, so i need the shifter and the cables?
Robin
waynemodz
Car Make: SEAT
Post by waynemodz »
yes, because if you take your 5speed now, you cant select a 6 gear right?
so even if you put a 6 speed box you need the cables to get 6th.
get the entire unit.
:thumbup:
Wayne Modz
Toxic Tuning
Digit Riaan
Registered for: 19 years 11 months
Post by Digit Riaan »
I'm sure you need different shafts and obviously the starter and clutch kit. The reason why you can not shift to sixth now is because you have a 5spd box, it is not necessarily a shifter restriction, just make sure before you buy one. AFAIK the 6spd box also has no speedo gear.
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
waynemodz
Car Make: SEAT
Post by waynemodz »
porno_ster wrote:I'm sure you need different shafts and obviously the starter and clutch kit. The reason why you can not shift to sixth now is because you have a 5spd box, it is not necessarily a shifter restriction, just make sure before you buy one. AFAIK the 6spd box also has no speedo gear.
the clutch is a must...he said modifications...its not exactly a mod...
the 6 speed reads speed from the wheel speed sensor ,of the abs system....
im sure the 5 speed jetta also uses speedsensors....
check it up
Wayne Modz
Toxic Tuning
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
The question is why you would want to do the swap...Is there reasoning behind why you intend doing this, current box broken so you need a replacement?
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Tdi jetta 4 ever
dazza wrote:The question is why you would want to do the swap...Is there reasoning behind why you intend doing this, current box broken so you need a replacement?
Yes i might get a 6 speed box from someone i know, and yes my box needs replacement as the 3 and 5th gear is grating.
I think it should be better to get the original 5 speed box then. I dont want to get a other clutch kit etc. That will be costing too much.
Robin
MeTsU
Registered for: 18 years 10 months
Car Model: 2005 Polo 1.9 TDi Sportline
Membership No: 1644
Post by MeTsU »
check it up
Nope, the gearbox has a speedometer sender (G22) on it. It scans a sender wheel on the diff. It's located below the cable shift cable mounting plate.
2005 Polo 1.9TDi Sportline - Sooty
Digit Riaan
check it up
Oh, ok.
BatteryWorldPtaEast
Registered for: 17 years 11 months
Car Model: Polo TDI Sportline
Membership No: 1572
Post by BatteryWorldPtaEast »
It depends which 6 speed box it is , the sportline box only have a reverse light switch on it,nothing else.
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
waynemodz
Car Make: SEAT
Post by waynemodz »
I Went to the local performance shop yesterday,
theres a guy who tried to change over to 6speed...
he's looking for a 5sp now, he says its kak loads of modifications.
so if u do pursuit this, i hope its for a good coarse.
sometimes parts come cheap but getting them to work is expensive.
like my bigturbo i got @ R1800, i still need R5000 for nozzles, another R2500 for manifold ...all because...
i got a big turbo haha...it woulda been cheaper to just get a bolt on cupra turbo. same concept.
it be cheaper to stick to 5sp
Wayne Modz
Toxic Tuning
Tdi jetta 4 ever
Thanks guys, i will rather stay with the original box then.
Robin
Njabulo187
Registered for: 5 years 2 months
Post by Njabulo187 »
So what mods can I put on my jetta 4 1.9tdi to make it abit more faster than normal?
Ashveer03
Post by Ashveer03 »
Software upgrade
