After finding this thread on spark plugs for the Citi FI engine or more specific velo one.
http://vwclub.co.za/forum/viewtopic.php?f=3&t=147097
I'm suffering quite a bit on fuel economy on this car. 11km/l avg chilled driving style
What is the correct spark plug gap on these engines? Mine is measured on 0.034" or 0.864mm
Currently have Bosch on the right and my old Carb Chico's NGK's on the left. Is the color normal?
Velo flux capacitors
- nacho!
1997 Suzuki Samurai aka - Zombie Fire truck
2005 Velociti 1.4i
1990 Jetta MKII CLi (sold)
2005 Chico 1.4 (sold)
2005 Velociti 1.4i
- nacho!
Re: Velo flux capacitors
I found the gap to be 0.7mm
Does a velo have a knock sensor?
2005 Velociti 1.4i
2005 Velociti 1.4i
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
Yes they do!nacho! wrote:I found the gap to be 0.7mm
Sent from my GT-N7105 using Tapatalk 2
- nacho!
Where is it located and what will happen if it goes bonkers?Viper wrote:Yes they do!nacho! wrote:I found the gap to be 0.7mm
2005 Velociti 1.4i
2005 Velociti 1.4i
- Car Make: SEAT
- Membership No: 478
Spark plug on the right is pretty much the correct burn, spark plug on the left is fouling up, so the heat range of the spark plug could be too cold, or the gap could be incorrect.nacho! wrote:After finding this thread on spark plugs for the Citi FI engine or more specific velo one.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Make: SEAT
Have a look at the below picture... it is pretty much behind the dip stick.nacho! wrote:Where is it located and what will happen if it goes bonkers?Viper wrote:Yes they do!nacho! wrote:I found the gap to be 0.7mm
It doesn't work very well in the first place, so if it goes, I doubt you would even notice.
If I were you I would check your water temp sender and MAP sensor.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- nacho!
What should the Ohmage read on the MAP and Water temp sender and which pins?
Interesting I've disconnected the MAP sensor before (just to check if it's working) and the car runs like it has an 276 Cam in it, I assume it over fuels running on a base map
I'l take a reading today and will appreciate it if anyone else can do the same to compare the values for future reference
Thanks much for the advice
2005 Velociti 1.4i
2005 Velociti 1.4i
- nacho!
2005 Velociti 1.4i
2005 Velociti 1.4i
- Car Make: SEAT
1.6 carb motor converted to 2.0 MP9, so that is where the old fuel pump used to bolt onto.
On the factory MP9 motors (like yours) there is a block breather there.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
