Caddy Build - ADY
Rooi_Willie
Car Model: Caddy
Caddy Build - ADY
Postby Rooi_Willie » Sat Apr 13, 2013 12:15 pm
Hey everyone :hi:
So my bum is itching as of late and I had a look at some options (E36 M3, vtec...) and have pretty much settled on building a caddy.
Why? Seems easy enough, shows great results and won't break my bank!! :cool:
I've done a lot of reading on the forum and is VERY informative, so please excuse me if I ask questions that have already been asked, but I'd like some answers pertaining to my specific build.
The Purpose :
I want to keep the caddy clean and understated.
Hoping to get a late model 1.6i
Will only be used on weekends
Will be building the ADY on the side
Don't want to break any records, just for personal use
Need it to be reliable
Wants :
2.0lt 8v
Bigger front brakes
Suspension
Shopping List :
2.0lt 8v ADY motor
210mm 1800 Flywheel & Clutch (9 Pin)
282/288 cam
Service kit & All oil seals
Front brakes
Suspension
Management
Branch & Freeflow
Questions :
1.1 Out of all the available motors, it seems the 2.0 ADY 8v is the most popular for these conversions. Should I at a later stage decide to do a small turbo or gas, would this motor still be suficcient? Ideally (and I'm quite the gadget person :oops: ) I would love to put a 20v inside but that seems waaaaaaay too complicated for my small mind (and expensive), so the ADY will do for now, unless anyone has another option?
1.2 SHould I, for some reason, decide on 16v. What would the general preference be? 1.8 or 2.0? Which one?
2. I'm not aiming for high speeds, rather strong acceleration, Which cam would suit the purpose best?
3. For the front brakes it seems the Mk2 GTi is quite popular. Is this viable or is there an aftermarket alternative? It seems that rear drum upgrades to discs are overrated (and I remember the work involved in doing it to my GT) so can I leave them as they are and just upgrade the fronts?
4. Would like a nice set of coil overs for the front. Any specific suggestions? 99.9% street use, but I may be persuaded to try the track once or twice :oops: (I stay very far from any track so no use in setting up specifically for track use). I'm gaining years so I'm not really after looks, mostly great handling!
5. Management... Now this seems to be a whole new can of worms. I've read lots of comments regarding the MP9 with piggyback or Unichip. But I need something reliable (ek wil nie sukkel nie, nie weer nie :bang: ). Dictator, Gotech, PP ???? What's the general opinion? Please keep in mind future developments (maybe turbo or gas).
6. Gearbox... Will the standard gearbox from the caddy be sufficient? Would I need to upgrade the cvs/side shafts?
7. Branches... 4-2-1 or 4-1 with single diameter or "thicker" to "thinner" pipe (excuse my lack of knowledge regarding pipe diamters :moon: )?
8. Any other pitfalls to look out for? I'd like to get this right from the start!!
Thanks again and in advance for the answers! You guys seem to have a really cool community going and I hope to become a part of it!
Cheers!
RW
ProJect Caddy | Some Sound | Custom Dash | 15" Velocity Wheels
Rooi_Willie
Car Model: Caddy
Re: Caddy Build - ADY
Postby Rooi_Willie » Sat Apr 13, 2013 12:39 pm
aslam325 wrote:Little knowledge that i have
Ady is a very good motor.if you going to look.for more hp everytime rather fit a 16v motor
Vr6 front brakes and braided hoses
Jom coilovers from ddm imports
Im a mp9 type of person....but pp looks to be very good only and i repeat only if tuned by panic on the forum
Ffz gearbox
Thanks for the reply Aslam.
Just think for now 8v's gonna be lighter on the pocket and less intense, as I'd like to build myself (with limited knowledge), but I know 16v is the answer in the long run.
VR6 fronts I heard of, but that leaves me with 5holes???
JOM's look good!!
I stay in the middle of nowhere so a quick run to a tuner is out for me. I need something that I can (maybe) fix myself or at least have one of the local "tuners" take a look at.
FFZ box - Check!
Thanks again bud!
M3THANOL
Blue Bomber
Car Model: Golf Mk2...now....2.0L 8V AGG
Membership No: 1822
Postby M3THANOL » Sun Apr 14, 2013 5:21 pm
if you are planning on boost one day, you can either stick with the 8v and run a cross-flow head (have a look at Jetta2's build thread, very pleasing results and he uses it as a daily) or you can pop on a 16v head which will drop your compression ratio down to around 8.5:1 which is great for boost!! and you have the plus of having a higher flowing head.
I'm literally can't evening!
http://www.iamsecond.com/
Current: The Blue Bomber
http://www.vwclub.co.za/phpbb3/viewtopic.php?f=11&t=151592
1/4 mile: 16.5s @ 133km/h (ODI-2013/10/27)
1km: 165km/h (ODI-2013/10/27)
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Sun Apr 14, 2013 7:38 pm
M3THANOL wrote:if you are planning on boost one day, you can either stick with the 8v and run a cross-flow head (have a look at Jetta2's build thread, very pleasing results and he uses it as a daily) or you can pop on a 16v head which will drop your compression ratio down to around 8.5:1 which is great for boost!! and you have the plus of having a higher flowing head.
Thanks bud!
How will the stock crank, rods and pistons hold up under boost?
maranou
Postby maranou » Sun Apr 14, 2013 7:51 pm
ady wil work nice,std 90kw 180nm
-can fit short mp9 loom R1500 and decoded and chipped box R450 if u suply box or R900+if he suply's box for 2l from allen hout bay 0834421122 u canscan it with vagcom or vw tool and pirate cables are R350-500 so then u can self diagnose and fix it if u have a laptop
-u need a map sensor and to dril a hole on intake and fit it to the ady intake and mp9 coil and fit a 2e distr in the ady to get it to work,the trottelbody and injectors and knock sensor on ady works with mp9 loom/box, u also need feulpump and 8mm steel feed line from pump to rail,u can keep the std 6mm carb line for return
-u can fit a 16v head on the ady sub with a steal headgasket and be right for turbo and 8.5cr,u just need to machine the pistons for 16v
-u get the brake kit from volkspares for the vr6 upgrade,there is brakes to move the calipers out and the disc are bored to 4 hole,so fit and go,just fit vented disc pads from cti or velocity,u can also buy the brakets and vr6 280mm brakes and dril it your self to 4x100
-all caddy's come with big cv inner and outer so wil be strong enoug for n/a 2l8v,when u go turbo the outers wil brake if u drive like a baboon
-branch u can buy cowley or powerflow or tnt,R1250+- and fit it your self and get a 57mm 2 box freeflow fitted ,exh places ask R800 to fit branch that's crazy
-get tuning art front coilies or jom as they are softer for daily R2500+-
-remove the second leafspring from the top at the back to drop the back too
-282 wil be nice for dailly and power on top,if u wane go 8v turbo rather get a 272 or 276 as it wil work on turbo motor too
-manegement that everyone can tune is dictator ,depending where u stay
look in my long build tread,there are picks of the vr6 brake upgrade and enough info on 16v turbo
http://www.vwclub.co.za/phpbb3/viewtopic.php?f=11&t=72987
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
araf69
Car Model: 2008 MK5 GTi DSG
Membership No: 1739
Postby araf69 » Sun Apr 14, 2013 10:04 pm
Rooi_Willie wrote:Hey everyone :hi:
The Purpose :
RW
Unfortunately caddys in SA come with 1.8carb and 1.6 carb. The late models only came with 1.6 carb only. The fuel tank can be modded to run fuel injection. Late models already come with ffz box. Caddy front brakes are already vented as well.
my rides thread : viewtopic.php?f=11&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 7:17 am
The Purpose :
RW
Are you sure? I'm sure I've seen 1.6i's advertised........... :type:
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 7:20 am
maranou wrote:ady wil work nice,std 90kw 180nm
Thanks for the great info bud!
If I decide to go Dicktator or PP or whatever do I still need :
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Mon Apr 15, 2013 7:21 am
Rooi_Willie wrote:
The Purpose :
RW
The Caddy panelvan came with 1.6i motor...
Current rides:
Hyundai - 1.4 Getz (daily)
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 7:40 am
Torker wrote:
:bang: :bang: :bang: :bang: :bang: :bang:
So that means 1.6i tank & fuel lines and pump to get extra....????
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Mon Apr 15, 2013 7:46 am
I've heard the Caddy tank is fine for fuel injection, just need a high pressure pump. ADY manifold comes without MAP sensor if you want to run MP9, you can source a MP9 intake manifold and use that, alternatively run Dicktator, doesn't need MAP. If you are looking at going big on the cam at a later stage (298), I suggest going with aftermarket from the start, MP9 doesn't like the big cam, it confuses the MAP and the ECU.
Current rides:
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 8:03 am
Ok, so I don't NEED the whole MP9 shebang???
I can make everything work with aftermarket management???
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Mon Apr 15, 2013 8:13 am
Yes, Dicktator (and most other managements) needs the following to run:
Air Temp (Optional), Water Temp, TPS Signal, Dizzy Signal, 3-pin coil (or 2-pin coil with TP100). It will switch your Fuel pump and injectors and do idling control if needed.
Current rides:
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 8:39 am
Sjoe! That's good news! Thanks bud!
maranou
Postby maranou » Mon Apr 15, 2013 9:07 am
U said u stay in the middle of no where,we stil don't know where that is,but if u want reliability and wane be able to fix it your self u can go mp9 and get everything as I said,it is beter to fit dictator if u wane turbo the car later or go big cams,u can use the ady as is on the dictator,just need a 2e distr and mp9 coil as it has a ignition module built in and give good spark even under 1bar boost,or else u can go tp100 and normal coil but cost more and need to get tp100 plug then and all,on the ady wiring u get with the motor there is a plug for the mp9 coil normally
But if u go dictator u really need a tuner....if it is tuned right first time and the car stand a day by him so he can do cold start the next morning and sort that out it wil be reliable alot
800m @ 233km/h
donftw
Car Model: 82 rabbit caddy
Postby donftw » Mon Apr 15, 2013 9:36 am
You can go dicktor or mp9. With a good tuner dicktor works like a dream.
Im running mp9 on mine, upgraded my fuel pump and running injection on an 82.
Was my build last year. She runs like a dream #weekendspecial.
Busy doing a respray at the moment, if you need help on your build and a good dicktor tuner leme know.
Have a friend in comso running sick cars :drool: , specialist tuner... :driving:
Current rides
Bmw 118
VW 82 rabbit caddy, 1.8 mp9
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 9:40 am
maranou wrote:U said u stay in the middle of no where,we stil don't know where that is,but if u want reliability and wane be able to fix it your self u can go mp9 and get everything as I said,it is beter to fit dictator if u wane turbo the car later or go big cams,u can use the ady as is on the dictator,just need a 2e distr and mp9 coil as it has a ignition module built in and give good spark even under 1bar boost,or else u can go tp100 and normal coil but cost more and need to get tp100 plug then and all,on the ady wiring u get with the motor there is a plug for the mp9 coil normally
The middle of nowhere is.............. Klerksdorp :hi:
It's not really that far away from everything. +/- 200km from JHB so I wouldn't want to drive all the way there often. There is a couple of local tuners, but from my GT build a couple of years ago, I haven't had ANY good experiences :crazy: :crazy: :crazy:
So what exactly would I need for N/A 2.0 8v in my Caddy if I go out and buy an ADY motor...?
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 9:48 am
donftw wrote:You can go dicktor or mp9. With a good tuner dicktor works like a dream.
Thanks bud!
You cabby looks sweet!!
Do you have a build thread on it?
Comso???
donftw
Postby donftw » Mon Apr 15, 2013 9:53 am
Cosomo city randburg.
Nope :bang: only joined the forum last week.
Current rides
Bmw 118
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Mon Apr 15, 2013 10:50 am
Outside of Gauteng Klerksdorp probably got the most tuners so it shouldn't be a problem to find a good one...
Current rides:
Rooi_Willie
Car Model: Caddy
Postby Rooi_Willie » Mon Apr 15, 2013 11:05 am
Lots of tuners... Yes
Good tuners... Debateable :tosser:
araf69
Membership No: 1739
Postby araf69 » Mon Apr 15, 2013 1:21 pm
Are you sure? I'm sure I've seen 1.6i's advertised........... :type:[/quote]
The Caddy panelvan came with 1.6i motor...[/quote]
Those are the new Generation caddy. Not the mk1/ pickup type. You can use the existing caddy fuel tank tank as the golf and caddy tanks are different.
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Return to “N/A Engines”
Users browsing this forum: coreycouger, magesh01, RedBeard and 25 guests
