Fueling solutions for your TFSI...
For all your REVO software requirements
The LOBA 2.0 TFSI fuel pump will give a fuel volume increase of more than 50% and can sustain over 130 bar.
Our fuel pump meets the very high requirements needed for the latest generation of OEM HPFP specifications.
The materials we decided upon are of the highest possible quality and for this particular application.
Multiple stages of various precision machining, hardening processes, coating processes and quality control inspections characterize this HPFP.
We've tested to over 8500rpm both in a controlled environment and on the track/road to simulate a large range of dynamic conditions.
Doing so was a important part of our mechanical design parameters to ensure the LOBA pump meets our standard.
LOBA HPFP is assembled with a special chemical anti-wear and anti-friction lubricant for initial start up protection.
It comes brand new, pre-assembled, fully checked, tested and ready for installation
USP Drop In High Flow Fuel Pump
Function:
The main purpose of the USP Motorsports fuel pump is to provide enough fuel flow to the high pressure fuel pump to support 400+ horsepower safely. This was done by utilizing an OEM quality fuel pump. Through R&D USP flow tested the factory fuel pump and found that it flows approximately 189 liters per hour. Our high flow drop in fuel pump replacement flows approximately 289 liters per hour, or around 50% more and has been tested in applications over 550whp.
What is included:
High flow in-tank fuel pump w/basket
