Golf MK1 1998 carburator
VWKyleVW
Car Model: Citi Golf 1.4i
Post by VWKyleVW » Sun Jan 27, 2013 7:44 pm
Hi.
I replaced my 1998 Golf MK1 1.6 Carb and I bought it from Goldwagen and my question is right in front of the carb there is a solenoid type thing that has to do with the accelerator (so I think) and then at the back of the carb there is 3 nozzles what are they for? I know the one is for a vacuum that comes from your distributor but I would like to have all of it connected if possible and will it make a difference?
I will post pics if needed.
Re: Golf MK1 1998 carburator
Post by panic-mechanic » Mon Jan 28, 2013 7:00 am
A soleNoid is an electrical device. There is one on the citi golf( not mk1 if it is '98) and that is at the back of The carb. It is the idle cutoff valve so that the car dies when you switch it off.
The thing in the front is a vacuum actuator which opens rhe 2nd stage of the carburettor. The other nipples are for items like idle up if you have aircon. They are not all used.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
VWKyleVW
Post by VWKyleVW » Mon Jan 28, 2013 11:32 am
Sorry my mistake it is a vacuum you are correct i will post a pic tonight of what i am querying about as well so that i don't get confused ,
There is one more question as well that i want to find out about,
i replaced my old intake manifold with a different one as the old one was leaking all over the show and the idling was not all to good it fluctuated, now with the new one it is still doing it why would that be as there is a new seal/bracket or gasket whatever it is called on with the new carb how can i get this issue solved?
Thanks for all the help
No Turbo!!!
No Gas!!!
Just Kicking Ass!!!
Post by panic-mechanic » Mon Jan 28, 2013 12:52 pm
Well it depends on why it was fluctuating in the first place. Some things one cannot diagnose on a forum and needs to be seen. Have you checked ignition timing, plugs, etc.etc.
'09 Audi Q5 3l tdi
VWKyleVW
Post by VWKyleVW » Mon Jan 28, 2013 2:27 pm
It was leaking petrol by the manifold and carb so when i looked at the manifold i saw that most of the holes were striped and messed up so i put on a different one and now it is sealed and not leaking or sucking air there but the idling goes up and down, i want to take it in so that the air and fuel can be set in properly.
No Turbo!!!
No Gas!!!
Just Kicking Ass!!!
VWKyleVW
Post by VWKyleVW » Tue Jan 29, 2013 8:09 pm
i also want to find out how many degrees must my timing be set on?
and here is the image:
No Turbo!!!
No Gas!!!
Just Kicking Ass!!!
Post by panic-mechanic » Wed Jan 30, 2013 7:20 am
That unit is the idle-up for aircon.
'09 Audi Q5 3l tdi
VWKyleVW
Post by VWKyleVW » Wed Jan 30, 2013 8:28 am
and what must the timing be set to on my car? it is on 3 degrees at the moment i want to now what the standard setting is.
No Turbo!!!
No Gas!!!
Just Kicking Ass!!!
Post by panic-mechanic » Wed Jan 30, 2013 8:58 am
6-8 here.
'09 Audi Q5 3l tdi
VWKyleVW
Post by VWKyleVW » Wed Jan 30, 2013 9:03 am
awesome thanks for all the help i really appreciate it!!!!! :hurray: :troll:
No Turbo!!!
No Gas!!!
Just Kicking Ass!!!
