Going to get the polo gti logged later today.
Scenario: If I am driving at 120 for a while, then I try to accelerate > the car does not accelerate even if I press the pedal flat. Boost gauge reads 0.1
When I let go the pedal completely and accelerate again immediately it accelerates fine.
Car details:
07 Polo GTi, Stage 2.
Problem arised after I changed cambelt + blank off plate and delete + fitment of boost gauge.
Thought it was the lambda's but I changed those and problem still there.
Throttle body was also faulty and changed that > possibility it got damaged as a result of an underlying issue.
Has anyone experienced something similar?
I am thinking it has something to do with the routing of air or a control valve is faulty.
Will keep posted on progress.
