http://www.youtube.com/watch?v=U1DNsecR-7c
I'm gonna buy a t304 stainless steel 63mm 3 box flowtech catback next year. Apparently R2800 for it, shipped to JHB.ryanrich wrote:Fark that'll be loud by bypassing both boxes, GTI sounds like a tractor on steroids with a straight pipe.
It's mondayruan9n wrote:Not at all...
no you will not need a different map for the straight through setupACiD_Omega wrote:It's mondayruan9n wrote:Not at all...
...Can't tell if trolling...
couple kg's for sure, but to be honest you won't really notice itrodga wrote:interesting, but how much weight will that system add compared to a normal system?
Why? won't they behave differently regarding turbo spool?PoLonY wrote:no you will not need a different map for the straight through setup
suppose a few kgs here or there wont make much differencePoLonY wrote:couple kg's for sure, but to be honest you won't really notice itrodga wrote:interesting, but how much weight will that system add compared to a normal system?
nope, the exhaust after the DP, the "cat-back" section doesn't do much except for the noiseACiD_Omega wrote:Why? won't they behave differently regarding turbo spool?PoLonY wrote:no you will not need a different map for the straight through setup
Also it's low down, so the weight won't affect handling etc enough to make it noticeable....rodga wrote:suppose a few kgs here or there wont make much differencePoLonY wrote:couple kg's for sure, but to be honest you won't really notice itrodga wrote:interesting, but how much weight will that system add compared to a normal system?
Thank youPoLonY wrote:nope, the exhaust after the DP, the "cat-back" section doesn't do much except for the noiseACiD_Omega wrote:Why? won't they behave differently regarding turbo spool?PoLonY wrote:no you will not need a different map for the straight through setup
DP makes the biggest difference to spool etc...
even if the turbo spools differently the ecu can compensate rather easily. hell the turbo spool is different depending on what gear you are in.PoLonY wrote:nope, the exhaust after the DP, the "cat-back" section doesn't do much except for the noiseACiD_Omega wrote:Why? won't they behave differently regarding turbo spool?PoLonY wrote:no you will not need a different map for the straight through setup
Europe has some pretty hectic noise level laws...if the police reckon your is too loud and the take it to test it and it is...well big fine coming your wayKillerwatt wrote:nicely built but 2 things make me wonder if its worth it.
Assuming these are straiht through boxes, is there really a restriction?
and why does he close off the silenced exhaust when the bypass is opened?
could be ECU, a electronic boost controller signal switching on a relay at a set boost pressure, or even a simple on/off switchdirty d wrote:what controls the valve,ecu?
Yip also a straight through system can become tiring to the ears quickly on a long trip/cruising...Killerwatt wrote:ooh gotcha, didnt realise about the noise laws.
resonace could be the issue, but i doubt it would be louder than just the pipe. never know though.
