Brake bleeding and brake fluid
G-spot
Car Model: 6c Cross polo
Membership No: 1215
Post by G-spot » Tue Oct 30, 2012 8:31 pm
So, As some know I recently acquired a set of S3 brake calipers, discs and pads. I also bought a set of braided lines as well.
Being the DIY man that I am, I'll be attempting to do this installation myself. The mechanical part of it is pretty simple. But I have never completely removed and put back calipers before, Nor have I ever bled a brake system. So here it goes.
What would be the procedure to bleed the brake system on a polo, what is needed to do this.
I also take it ill have to replace most of the brake fluid, what would be the best to use and how much would I need?
what else did i miss?
Grant Hendry
Membership no.:1215
2015 VW Cross Polo 1.2TSI
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
It will be built not bought, cheap not expensive, driven not hidden, abused and used and most of all I own it and I thrash it...
Black&White
Car Model: 6R Cross TDI
Membership No: 1863
Re: Brake bleeding and brake fluid
Post by Black&White » Tue Oct 30, 2012 8:50 pm
Hey bud. I beld my breaks this weekend. I'm not expert but something I do know is u should always bleed ur break furthest from ur "break fluid" pump or what ever. The polo's break fluid bottle sits on the right side of ur engine (steering wheel side). So in other words u should bleed ur left back, then right back, front left and last ur right calliper.
Also u should use DOT4 break fluid.
IMPORTANT: make sure ur bleeding nipple points upwards so that any air in the break lines can escape when being bled.
Need the bleeding procedure?
Anybody pls correct me if I'm wrong with anything, but I'm pretty sure that sound cover it except for the whole bleeding procedure.
Shot
'13 6R CrossPolo TDI
Polo 2.Slow (Sold)
'03 citi life 1.6 ( stolen & retrieved then sold)
'86 mk1 2door CTI (sold)
Sparkz0629
Car Model: 2012 Polo GTI
Membership No: 1768
Post by Sparkz0629 » Tue Oct 30, 2012 9:49 pm
a little trick my buddy taught me to keep things clean...
Get a clear rubber tube that is slightly smaller than the bleeding nipple... then take a Purity (Baby food) bottle, and make a small hole in the lid, just big enough for the tube to fit through.
Make sue you cut the tube a decent length... then you can just slide the tube over the nipple, and all the brake fluid will go into the bottle instead of onto the floor when its being bled...
Sorry, not quite answering your question, but it helps :grin:
Current: 2012 Reflex Silver 6R Polo GTI
2006 1.9TDi Sportline - 158.7Hp & 413Nm at K.A.R 19-05-2012
VWicked wrote: I could do 300km/h if I wanted but I don't trust my brakes stopping from that speed so as soon as i hit exactly 241km/h on my garmin i will tap off, generally it takes me me 6.9 sec to get there so I will just cruise the last 5 sec's to allow the car to cool down..
Car Make: VW, VW, Aprilia
Car Model: Mk3, Caddy, Aprilia RSV4
Post by Jetta2 » Tue Oct 30, 2012 9:56 pm
When bleeding brakes, start from the wheel that is furtherest from the master cylinder and work forward.
So, left rear - right rear - left front - right front.
2017 Caddy Maxi Crew Bus
2013 Aprilia RSV4 APRC track toy
Howie-WP
Membership No: 2033
Post by Howie-WP » Tue Oct 30, 2012 11:43 pm
Black&White wrote:Hey bud. I beld my breaks this weekend. I'm not expert but something I do know is u should always bleed ur break furthest from ur "break fluid" pump or what ever. The polo's break fluid bottle sits on the right side of ur engine (steering wheel side). So in other words u should bleed ur left back, then right back, front left and last ur right calliper.
Shot
*brake :crazy:
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Post by Neuk » Wed Oct 31, 2012 3:19 am
ROFL's at Howie :grin:
Relatively simple process, I had help when we did Fes' recently, I suggest getting help as it is a nightmare trying to do it yourself...
Nic
Daily Drive: 2015 VW Golf R
Black&White
Membership No: 1863
Post by Black&White » Wed Oct 31, 2012 5:46 am
Shot
*brake :crazy:
Ahhhh **** me. Can't believe I did that. This blady boertjie. MY BAD
Polo 2.Slow (Sold)
Duck
Car Model: MK7.5 GTD
Membership No: 695
Post by Duck » Wed Oct 31, 2012 6:43 am
If you have a VAG Com Cable you can bleed the brakes using the ABS pump. I did it this way on my SL. Otherwise get someone to sit inside the car pump the brake pedal hold, then you open the bleed nipple. It does not matter which wheel you bleed first.
Build your car for yourself, not what an internet forum tells you.
Current rides
2018 MK7.5 GTD
1992 1.6L 16VT http://www.vwclub.co.za/forum/viewtopic ... 11&t=60525
My Ex Rides
1981 1.3 Escort sold
1988 1.6 VW Fox sold
1995 Jetta 3 CLI sold
1997 Vr6 Hi-jacked
2000 2.0L MK4 Golf sold
2003 1.4 TDI Highline sold
2006 Polo 1.9 S/L sold
1994 CTI 8v Turbo retired
2010 1.6 TDI Sold
2011 Polo 6RGTISold
2013 MK7 2.0L TDI DSG Sold
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Wed Oct 31, 2012 7:07 am
When I did the brakes on my GT I had nobody to help me bleed it so I concocted the below out of an old Gardena spraybottle. the cap goes onto the reservoir, you pump up the pressure, open the bleed nipple and the old brakefluid comes out. Works a charm.
Current rides:
Hyundai - 1.4 Getz (daily)
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Wed Oct 31, 2012 7:15 am
Easy to do dude, let me know I will help you
1992 Golf Mk2 VR6
1989 Golf Mk2 16vT
2018 Golf Mk7.5 R
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk » Wed Oct 31, 2012 7:17 am
That looks bloody useful...
Nic
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk » Wed Oct 31, 2012 7:26 am
VWicked wrote:Easy to do dude, let me know I will help you
This isn't a CitiGolf, are you sure you can help?
Nic
Sparkz0629
Membership No: 1768
Post by Sparkz0629 » Wed Oct 31, 2012 8:04 am
This isn't a mk1, are you sure you can help?
fixxored :lol: :moon:
joggiep
Car Model: RSQ3
Membership No: 664
Post by joggiep » Wed Oct 31, 2012 9:20 am
Neuk wrote: I suggest getting help as it is a nightmare trying to do it yourself...
Or go to Midas and pay R80 for a little simple tool called an easy bleed !.. Works like a charm and one man opperation :wink:
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
CURRENT CARS
BMW 335
2226cc
Post by 2226cc » Wed Oct 31, 2012 9:48 am
Also need to do this at some point.
http://faculty.ccp.edu/faculty/dreed/ca ... /index.htm
http://www.instructables.com/id/A-DIY-P ... e-Bleeder/
You can get bleeders like this from retail or tool suppliers. They cost a stupid R1,500 for something like the Motive bleeder. Can get a decent pressure sprayer from most garden centres or hardwares for around R100 or even cheaper. I was even thinking just a container, a valve and bicycle pump would be fine to pressurize the bottle. I think don't overdo on the pressure though, it might affect seals, etc.
I was also looking at vacuum bleeders recently, but I understand there is plenty possibility of sucking air past the bleed nipple which will then head back into the system.
I tried easibleed, still got air in the lines, but that was when the drum brake cylinder popped apart as I removed the shoes. Might just have been my own rush-job stupidity.
VWicked
Membership No: 1492
Post by VWicked » Wed Oct 31, 2012 9:53 am
kwaa, lame response from a lame Catt...
1992 Golf Mk2 VR6
1989 Golf Mk2 16vT
2018 Golf Mk7.5 R
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk » Wed Oct 31, 2012 10:29 am
You cut me deep, real deep...
:grin:
Nic
joggiep
Car Model: RSQ3
Membership No: 664
Post by joggiep » Wed Oct 31, 2012 11:30 am
2226cc wrote:I tried easibleed, still got air in the lines, but that was when the drum brake cylinder popped apart as I removed the shoes. Might just have been my own rush-job stupidity.
IIRC you can adjust the little one way valve ... Might also be your issue.. mine works perfectly .. Used it om both the Jetta and the caddy .. have used it a few times to do the Hydro clutch on the Jetta.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
CURRENT CARS
BMW 335
2226cc
Post by 2226cc » Wed Oct 31, 2012 12:01 pm
The real problem is actually me trying to rush the job. These jobs always happen on a weekend and usually with more than one thing needed doing and all to be done by the next morning, etc, etc, etc. :roll:
G-spot
Membership No: 1215
Post by G-spot » Wed Oct 31, 2012 5:42 pm
Gents, Thanks for the replies
What brake fluid should I use, I was told to use Ferodo Dot5 fluid, Apparently its a racing brake fluid??? Is this a good idea? Its about R100 a 500ml bottle and was told I would need 2?
Grant Hendry
Membership no.:1215
2007 VW Golf GTI
2012 VW Polo GTI
2226cc
Post by 2226cc » Wed Oct 31, 2012 6:31 pm
No dot5 is silicone based. Do not mix with dot4.
I understand if you do want to use it you will need a complete brake system flush.
Use a good dot 4 or I think dot 5.1
I recall 3, 4 and 5.1 use the same base but 5 is completely different.
Maybe try and find ATE Super Blue DOT 4 racing fluid. It's on my wish list.
mk2-phreak
Post by mk2-phreak » Wed Oct 31, 2012 7:18 pm
G-Spot wrote:Gents, Thanks for the replies
no
Use dot4 fluid
G-spot
Membership No: 1215
Post by G-spot » Wed Oct 31, 2012 7:43 pm
no
Use dot4 fluid
Reason being? whats the difference between 'racing fluid' and normal? just the boiling temp?
Grant Hendry
Membership no.:1215
2007 VW Golf GTI
2012 VW Polo GTI
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Wed Oct 31, 2012 7:46 pm
no
Use dot4 fluid
Pimped from here: http://en.wikipedia.org/wiki/DOT_5
DOT 5 is one of several designations of automotive hydraulic brake fluid, denoting a particular mixture of chemicals imparting specified ranges of boiling point.
DOT 5 is a silicone-based brake fluid (contains at least 70% by weight of a diorgano polysiloxane[1]).
Unlike polyethylene glycol based fluids, it is hydrophobic. Its chief advantage over other forms of brake fluid is that silicone exhibits a more stable viscosity index in extreme temperatures. It is widely used in the antique automobile arena as well as it does not damage paint.
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure. DOT 5 brake fluid is not compatible with anti-lock brake systems. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.
Current rides:
Post by lawrence » Wed Oct 31, 2012 8:33 pm
I have been running with dot 5.1fluid in the polo for a long while now.
I survived a track day at Hesketh with no brake fade, running Ferodo premiums on standard diam vented and slotted discs, with braided lines so something 's got to be working.
They work hundreds in my normal every day traffic commute too.
I suppose the 'upgrade' is worthwhile if you intend on a lot of heavy braking?
Just my 2c
Sent from my iPad using Tapatalk HD
