Software MAP differences DSG vs Manual ?
Posted: Sat Oct 27, 2012 11:14 pm
by Wazza
Hi All
I have heard that there are differences between a map for a manual and a map for a dsg. I have read that there are additional parameters that need to be accounted for when flashing a dsg that don't come into effect on a manual map
Is this true ?
Sent from my BlackBerry using Tapatalk
Re: Software MAP differences DSG vs Manual ?
Posted: Sun Oct 28, 2012 6:28 pm
by Wazza
Wazza wrote:Hi All
Is this true ?
Anyone?
Posted: Sun Oct 28, 2012 7:30 pm
by Burner1144
I'm also interested in this... Does the dsg ecu also need tweaking and can it handle a software upgrade without failing due to the
added torque?
Posted: Mon Oct 29, 2012 7:26 am
by Wazza
Burner1144 wrote:I'm also interested in this... Does the dsg ecu also need tweaking and can it handle a software upgrade without failing due to the
added torque?
Howzit bud
I'm not talking about DSG ecu flashing I am refering to performance maps for the engine ECU that incorporate additional parameters in the MAP for DSG integration that do not exist on MAPS that are used on manual gearbox cars
Posted: Mon Oct 29, 2012 10:57 am
by Zubair
As far as I know maps are identicle on either gearbox.
Posted: Mon Oct 29, 2012 2:19 pm
by Demon Tweaked
+1
Posted: Wed Oct 31, 2012 11:14 pm
by Wazza
Zubair wrote:As far as I know maps are identicle on either gearbox.
Thanks Zubs
That's what I wanted to hear
So the DSG box operates totally independently from the motor ECU using its own ECU programing
So what would cause the DSG box to start hesitating after each shift at WOT immediatly after loading a software MAP ?
Posted: Thu Nov 01, 2012 5:55 am
by Abnormal
Is the dsg ecu completely seperate or does it get some info from the engime ecu? I thought that the dsg ecu got torque output from the engine ecu.
Posted: Thu Nov 01, 2012 10:35 am
by Zubair
Thanks Zubs
What software did you load?
Posted: Sat Nov 03, 2012 4:30 pm
by Wazza
Zubair wrote:
Thanks Zubs
LOL I'd rather not mention names yet as we are still in the process of logging and diag but wanted to do a bit of investigation on my own for now
Posted: Wed Nov 14, 2012 5:58 pm
by Wazza
Ok So the problem is history now
I had the car flashed back to stock and there's no DSG shifting issues at all I'm M D or sport mode with TC on or off
But I'm not saying its the map
There may be some other explanation for this strangeness
Posted: Wed Nov 14, 2012 8:44 pm
by Burner1144
I too flashed a stg 1 software map and immediately noticed afterwards that my reverse is jerky especially climbing a slight incline. Pulling away in D or S from standstill is pretty violent no matter how nicely you try modulate the pedal. Wasn't like this with OEM map.
Shifts though while driving are still smooth with no hesitations.
I thought of maybe resetting dsg box and letting it recalibrate, seems like quite a process.
At the same time ...dont want it to be a case of fiddle, fiddle, f...k..ed
Posted: Thu Nov 15, 2012 4:48 pm
by Wazza
Burner1144 wrote:I too flashed a stg 1 software map and immediately noticed afterwards that my reverse is jerky especially climbing a slight incline. Pulling away in D or S from standstill is pretty violent no matter how nicely you try modulate the pedal. Wasn't like this with OEM map.
Howzit man the DSG reset is pretty easy if you have a VAGCOM cable , But the reset only lets the DSG recalibrate the clutch take up it has nothing to do with the input power from the motor so it may make your changes a bit smoother , also check when last your DSG was serviced
Cheers
Posted: Thu Nov 15, 2012 10:52 pm
by Porra46
Just for the record guys...
Who is all experiencing this? And what type if software are you guys using??
This seems to be an issue that doesnt happen only if your car has APR software... Lots of reads on overseas forums...
Posted: Thu Nov 15, 2012 10:54 pm
by Zubair
Apr?
Posted: Thu Nov 15, 2012 10:57 pm
by Porra46
APR as in www.goapr.com
There maps dont have as much glitches as others... Quite a few people have complained on the mk5, mk6 and vortex forums...
It can be remedied though. Your tuner must give it some attention. It is fixable.
Posted: Thu Nov 15, 2012 11:11 pm
by Zubair
I know APR, I meant was this an APR issue or a local is lekker brand
Posted: Thu Nov 15, 2012 11:30 pm
by Porra46
Zubair wrote:I know APR, I meant was this an APR issue or a local is lekker brand
Sorry bud. Misunderstood you.
APR are the only ones that dont have issues in their software.
Posted: Fri Nov 16, 2012 7:13 am
by tfsi
I've seen many Apr hesitation threads...many... :smile:
Posted: Fri Nov 16, 2012 7:52 am
by Porra46
Not denying it bud.
Most cases its a bad tune and if you don't inform your tuner that you are unhappy, how can he help you...
I'm with ETuners... Not APR.
Posted: Fri Nov 16, 2012 8:50 am
by tfsi
Porra46 wrote:I'm with ETuners... Not APR.
Lol. With Shaheen? Do you stay about 350km from him? Did you think you had dv issues? Did you dyno stock at 194kw? Does your car now make 240kw? At the fly? Stalker alert... :troll:
Posted: Fri Nov 16, 2012 9:53 am
by Porra46
Hahaha! :lol:
Posted: Fri Nov 16, 2012 10:26 am
by Wazza
Hi Guys
My issues have been resolved , Unfortunately im not willing to post up specific info in this thread ,PM me if you want specifics
I think Burners issue is completely different to mine , I will be investigating other software vendors and hopefully I do not have this issue again
