Which plugs? Rocc 1.4TSI
Posted: Wed Oct 24, 2012 10:13 am
by Superslik
Hi Guys
Need to change plugs in my Rocc. Which are the best plugs to use and where can I buy from?
Re: Which plugs? Rocc 1.4TSI
Posted: Wed Oct 24, 2012 11:33 am
by ruan9n
BKR7EIX from KAR @ R550
BCPR7EIX from Mooloo but he has no stock
Try Yosh @ unitronic too.
Posted: Wed Oct 24, 2012 11:44 am
by Superslik
Shot Ruan!
Posted: Wed Oct 24, 2012 12:33 pm
by Sparkz0629
Are these the colder plugs? and if so, is there any benefit on a stock car, or a stage 1 car?
Posted: Wed Oct 24, 2012 2:19 pm
by dazza
Sparkz0629 wrote:Are these the colder plugs? and if so, is there any benefit on a stock car, or a stage 1 car?
In theory they should help with timing pull so yeah
Posted: Wed Oct 24, 2012 2:42 pm
by ree1
0.8 gap i think
Posted: Wed Oct 24, 2012 9:41 pm
by ruan9n
ree1 wrote:0.8 gap i think
& 0.7 modded
Posted: Thu Oct 25, 2012 6:54 am
by Sparkz0629
So just to confirm, it would be benificial in a stock/stage 1 polo GTI, but needs to be gapped to 0.8.
Then once more modding is done, then its better when gapped to 0.7?
What would the benefit be of colder plugs? sorry for the noob question
Posted: Thu Oct 25, 2012 10:22 am
by ruan9n
Just stick to 0.7 from the start. Colder plugs = less timing pull and better fuel efficiency.
Posted: Thu Oct 25, 2012 11:39 am
by Duck
The main reason for the guys running colder plugs is to prevent pre-ignition.
Once a motor has been modded the boost fuel and timing is increased, this in turn increases the combustion temps. By using a colder plug with a smaller plug gap helps prevent detination (Pinging). When a motor starts to Ping the ECU pulls timing to stop the pining. You can run a colder plug on your motor , it will help.
