MK5 GTi won't rev up
- VokofWagen
- Car Model: MK2 GTi 1.8T 20v golf
Howzit guys
I used the search function but it takes too long with my phone.
The car had a fuel pressure issue due to the cam follower wearing out. So the fuel pump was replaced the cam was replaced, intake, all the valves and sensors connected to the intake, dv, pcv, fuel filters etc
Now when the car starts it has a rough and lumpy idle and sounds really bad, it becomes smooth eventually. The car smokes on idle and when driving. The car won't rev past 3000rpm. The only fault that it throws out is feul press and 5 different pumps have been fitted.
Any links or advise will be much appreciated.
Ps its an axx motor with around 200k km on dsg
'91 Mk2 GTi 20VT exec
Mk1 GT 2l 8v 105Hp 144Nm Sold
DUB LIFE!
Pubs, clubs and Dubs
DUB LIFE!
- Gansnek
- Car Make: BMW
- Car Model: 330e
Re: MK5 GTi won't rev up
did you have the valves checked?
Current: F30 BMW 330e '17, F30 BMW 320i '14
Ex: Kia Sportage '13 (POS)
Ex: Candy White G6 GTi '10 Stage 2
Ex: United Grey G5 GTi '08 KO4
- dazza
- Car Make: VW and VW
- Membership No: 1327
Are you sure the cam was replaced and not just the cam follower?
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- VokofWagen
Valves meaning engine or you refering other valves?
Whole cam was replaces with the follower.
DUB LIFE!
DUB LIFE!
- Post Whore
- Membership No: 1343
Who worked on the car?
Do you smell fuel coming from the enginebay? Any noticeable oil stains?
- Fransua
- Car Model: A6 V6 TDI
I know this sounds weird but try changing the spark plugs.
We once had the same issue with sparkplugs fitted that same day. Turbo car sparkplugs recommended by Goldwagen broke that very same day and the car could not rev higher than 3000rpm. It just starts to grobble at 3000rpm
- VokofWagen
Its my friends car, an audi technician helped with some stuff and the initial guy I do not know I will find out. I did notice a bit of oil but can't recall where, will check for sure! Its been to VW 3 times already
DUB LIFE!
DUB LIFE!
- Post Whore
Coilpack
Sparkplugs
Leak
PCV bust or not connected correctly
Popped DV also causes jerk, no power and wont rev up
Sparkplugs
Leak
- VokofWagen
Howzit
I have not worked on the car in a while, but decided I must try fix it! I keep getting fuel pressure error. It will not go past 6.5bar. We have checked the voltage on the plugs and they all right and the pump is new. Any ideas?
***EDIT TO ADD***
Error code is 004195 - fuel pressure regulation : control range not reached
P1063-002- lower limit exceeded
Freeze frame:
Fault status: 01100010
Fault priority: 0
Fault frequency: 1
Milage:263544km
Time indication: 0
Freeze frame:
RPM: 1250/min
Load: 54.5%
Speed: 0.0km/h
Temp: 71
Temp:44
Absolute pre: 870.0 mbar
Voltage:13.97v
***EDIT TO ADD***
Freeze frame:
Fault priority: 0
Fault frequency: 1
Milage:263544km
Time indication: 0
Freeze frame:
RPM: 1250/min
Load: 54.5%
Speed: 0.0km/h
Temp: 71
Temp:44
Voltage:13.97v
DUB LIFE!
DUB LIFE!
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
I assume you mean rail pressure?
Check your hpfp cam follower. I suspect you may need a new one. And camshaft. And pump.
Oh I see you have changed all that.
Check the pump connections and stuff. What pressure does the rail hit when you log the car? Should be 50 bar at idle.
- VokofWagen
Yeah most of it has been replaced. I have read that even though the cam follower is smoothe its height can be worn down.
I am not to clued up with running logs etc but I did see its saying 46.3bars.
I will be replacing the brass fitting and the bolt next!
Will hopefully be able to keep the thread updated.
DUB LIFE!
DUB LIFE!
- Post Whore
You should be seeing 100bar on a stock mk5 from what i remeber. Stage2 mk5's hit 115bar and 2+ hit 130bar. What you are experiencing are fuelcuts. Maybe the banjo bolt isn't tight enough and it is leaking pressure or the stock fuelpump is fubar, maybe even the LPFP is moertoe and not supplying enough fuel from the tank to the hpfp.
- Sinbad
- Post Whore
He said he sees 46 bar at idle - that is too low. Spec is 50. He also sees 6 bar from the rear pump, and that is just fine.
Maybe fuel filter?
If the banjo bolt was leaking there'd be a hell of a fuel smell in the engine bay.
Lumpy idle, smoke on idle...
Maybe a leaking injector? That would prevent the rail reaching the pressure it needs at low RPM?
Maybe fuel filter?
- Post Whore
You are right.Sinbad wrote:He said he sees 46 bar at idle - that is too low. Spec is 50. He also sees 6 bar from the rear pump, and that is just fine.
Maybe fuel filter?
- Car Model: caddy
- Membership No: 1147
throttle body?
