caravelle pistons on abf turbo?
shuaib
Car Model: Citi golf
Post by shuaib » Fri Sep 07, 2012 11:02 am
hi guys
would like to know if its possible to use a set of caravelle (ae nural) pistons to lower the comp on my abf motor? i know guys use 2e pistons, but i already have a brand new set of caravelle pistons that were given to me, would like to use the stock rods and some arp bolts also, will these pistons be ok?dont plan on boosting more than 1 bar anytime soon.
1.8iblackie
Car Model: vw polo classic. NO ENGINE
Re: caravelle pistons on abf turbo?
Post by 1.8iblackie » Fri Sep 07, 2012 11:15 am
Measure the height from wrist pin to top and compare to that of the abf piston. If its te same height or less it will work and might even drom CR to low and they will need pockets for the inlet valve.
8vT 187.2kW and 361Nm
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Fri Sep 07, 2012 11:24 am
Other issue I can see with th caravelle is the wrist pin size which is 20mm vs 2e (21mm). Either you will need to machine the pistons(if possible) or get bushes for the rods to bring the size down to 20mm. Ideally to save yourself stress, sell the pistons and get 2e's.
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
Riddy
Post by Riddy » Fri Sep 07, 2012 11:28 am
fit an ABF and get done with it
Ridhwaan
Current ride
BMW (E90) 320D
CITI sport - Stock
Ex Rides
CITI sport - Stock
6N Polo Classic ABF
VWicked
Membership No: 1492
Post by VWicked » Fri Sep 07, 2012 11:37 am
That car is already an ABF...
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
Killerwatt
Car Model: S3
Post by Killerwatt » Fri Sep 07, 2012 11:40 am
Do you have 2.3 or 2.5 pistons?
shuaib
Post by shuaib » Fri Sep 07, 2012 12:25 pm
hmm interesting... i have the 2.5 caravelle pistons... will see if i can get 2e pistons rather then? need to get this motor done asap :bang:
Killerwatt
Car Model: S3
Post by Killerwatt » Fri Sep 07, 2012 12:48 pm
yup can use those pistons but you may have to machine them down a bit to det the right deck height.
But 2e pistons would be better. You can try and find the rare semiforged ones.
Donavan
Post by Donavan » Fri Sep 07, 2012 1:05 pm
No u cant, wrist pin differs and your compression will be to low. There a 2mm difference in deck height between the 2e and combi pistons.
click on the link to see the pic.
2E pistons is your answer
http://i50.photobucket.com/albums/f349/ ... CF0159.jpg
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
shuaib
Post by shuaib » Fri Sep 07, 2012 4:53 pm
thanx to all for the advice ,managed to source some 2e pistons , hope they are in good nick :fear:
iv changed my mind so many times with this damn car now, time to just boost it and be done :driving:
