MK3 GS fuel tank leak
Dirty Harry
Car Make: People Carrier
Car Model: footswagen
Membership No: 1640
Post by Dirty Harry » Mon Jun 25, 2012 9:15 am
Howzit guys
Its the GS again, giving problems. The SO went this morning to fill up(first time since we have had the car since middle Jan this year) and about 3/4 way of it being filled(47l),petrol starts pissing out the petrol tank.I had a quick squiz and it seems as though its coming from above the joining seem. What are my options here?
Is it possible that because there has not been any fluid it dries out therefore causing this leak sort of like those wooden wine barrels or am thinking up **** here to try divert myself from replacing a petrol tank.
Help will be appreciated.
Cheers
Harry
Car Make: VW, VW, Aprilia
Car Model: Mk3, Caddy, Aprilia RSV4
Re: MK3 GS fuel tank leak
Post by Jetta2 » Mon Jun 25, 2012 9:21 am
The tank is plastic, so it might have a crack or it got damaged somehow. But before you do anything, take out the boot carpet and remove the round black plate (3 screws) and check there for a leak.
But if it is leaking from the seam or it has a crack, you can have it plastic welded or get a new tank form a scrapyard. God luck.
2017 Caddy Maxi Crew Bus
Dirty Harry
Membership No: 1640
Post by Dirty Harry » Mon Jun 25, 2012 9:34 am
Will check that out later.
Thanks Ryan
SUM DP 4 GP
Car Model: MK5 KO4
Membership No: 1394
Post by SUM DP 4 GP » Mon Jun 25, 2012 9:40 am
Harry, if you can't fix it, go to ABC Auto Parts in Kempton, off allandale Road, there's about a 100 G3's there, might be cheaper/worth while to just get a new tank??
Dirty Harry
Membership No: 1640
Post by Dirty Harry » Mon Jun 25, 2012 9:44 am
Thanks Reolan.Will keep that in mind.Will see how bad the damage is then take it from there.
SUM DP 4 GP
Car Model: MK5 KO4
Membership No: 1394
Post by SUM DP 4 GP » Mon Jun 25, 2012 9:50 am
Cool man, all the luck
Post by panic-mechanic » Mon Jun 25, 2012 11:28 am
Most likely just the seal at the fuel cap where the sender unit and pickup sit. It is an absolutel bastard to put in correctly and with the swop to take the pump out and put old gauge and pickup in it probably got pinched or mis-installed. It's not a physical tank leak.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Forest
Car Model: 135i Coupe & S1000RR
Membership No: 1648
Post by Forest » Mon Jun 25, 2012 11:41 am
Hey Harry,
What Panic said....
Stock Standard '89 Golf Mk2 VR6 (Sold)
Project "Merge" Mk2VR6 - The Build
'86 Golf Mk2 AGU 2 Door (Sold)
Project "Tudor" Mk2AGU -The Build
UDC
Membership No: 1041
Post by UDC » Mon Jun 25, 2012 1:01 pm
does the golf 3 tank fit in a golf 2, they look very similar
Post by Jetta2 » Mon Jun 25, 2012 1:03 pm
UDC wrote:does the golf 3 tank fit in a golf 2, they look very similar
Straight swop. No mods needed.
UDC
Membership No: 1041
Post by UDC » Mon Jun 25, 2012 2:07 pm
are the fuel float housing the same size, golf 3 looks bigger
Post by Jetta2 » Mon Jun 25, 2012 2:09 pm
UDC wrote:are the fuel float housing the same size, golf 3 looks bigger
Mk3 pump + fuel level jobbie is way bigger in diameter than the Mk2 item.
UDC
Membership No: 1041
Post by UDC » Mon Jun 25, 2012 2:12 pm
cool thanks bru :cool:
Dirty Harry
Membership No: 1640
Post by Dirty Harry » Mon Jun 25, 2012 8:09 pm
Thanks Stephan and JW, will have a look and see if I can put it on correctly. That is better news. Will update as soon as I find out what the issue is.
Dirty Harry
Membership No: 1640
Post by Dirty Harry » Tue Jun 26, 2012 9:16 am
I think and hope I have sorted the problem out. I think I am still floating a bit from all the fumes as the tank was full. The damn cap was not tightened properly :bang: . I see what you mean its quite a ball ache to put the cap on properly but I managed to tighten it better. I shook the car from side to side to see if anything leaked out and looks like its fine.
Thanks for the help guys.
