Spring colour on Forge 008 DV
Car Model: 12' Golf 6 GTI
Post by [email protected] » Mon Jun 11, 2012 10:38 pm
Hi Guys,
Just got myself a 008 DV :grin: It comes fitted with a green spring and has 2 additional springs (yellow and blue) supplied with it. I'm running stage 2 sw, don't have a boost gauge so not sure what i'm boosting.
Do I keep the green spring in or fit the yellow one? What are you guys using on your re-mapped cars?
:cool:
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'07 VW Polo Gti - Revo 2
'10 BMW 320i E90 Msport
'05 BMW 318i E46 Msport
'93 Golf CTi
'86 Mazda 323
Mojo
Post Wit Blitz
Car Model: Ibiza Cupra
Re: Spring colour on Forge 008 DV
Post by Mojo » Tue Jun 12, 2012 7:33 am
mines on 2 spacers and yellow spring works well :) Revo 2 some forge bits
whats a boost gauge :crazy:
Seat Ibiza Cupra
Post by dood786 » Tue Jun 12, 2012 8:37 am
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Revo 2 makes +- 20psi so yellow is preferable
Stompie
Boostleak Guru
Car Make: VW POLO
Car Model: 07' GTI 9n3
Membership No: 1843
Post by Stompie » Tue Jun 12, 2012 8:44 am
you basically have the same setup as i do except i have unitronic sw. i am running blue spring but yosh told me to.
yellow spring should work for you, what i read on the forge website - if your car is dumping alot even with a light throttle or rev then add some spacers or change spring as the spring is too soft. so listen to how your car dumps, if alot try some spacers or just try blue spring.
BMW 120D E87
G5 GP
Post by G5 GP » Tue Jun 12, 2012 10:07 am
dood are you sure those are boost levels and not cranking psi...?
STEALTH TUNED296.9whp and 438nm pump fuel, no meth
golf 5 gti ko4. broke the record 13.9
red dsg. broke the record 14.1
Alot more but they werent GTI's
jk
Post by jk » Tue Jun 12, 2012 10:13 am
Are there alot of Stage 2 Revos running around?
Good for everyday driving?
Demon Tweaked
Car Make: VW & VW
Car Model: MK7R & MK6 GTI
Membership No: 1845
Post by Demon Tweaked » Tue Jun 12, 2012 11:37 am
I wish i could remember what mine is.
LB MK7R 359WHP 511NM
MK6 GTI DSG UNITRONIC Stage2
AUDI RS3
BMW E92 M3 350WHP @ Rally Cross Motors
UNITRONIC SEAT Ibiza Cupra 1.8 20vT Stage3 434WHP 509NM @ KAR
VW Citi Chico 1.4
Mojo
Post Wit Blitz
Post by Mojo » Tue Jun 12, 2012 11:55 am
yours probably has a slightly flexible block of metal as a spring :lol:
:hug:
Seat Ibiza Cupra
Post by dood786 » Tue Jun 12, 2012 11:59 am
1.3bar boost is 1.3x14.7=19.11psi
What do you mean by "cranking psi"?
G5 GP
Post by G5 GP » Tue Jun 12, 2012 1:52 pm
the forge actuator came with these spring "psi" pressure printed on the packet.
The PSI pressures indicated are not what the spring will allow boost to get to but rather at what psi the wategate or in this instance the dv will open at.
Double check this - you dont want to be overboosting
Post by [email protected] » Tue Jun 12, 2012 3:42 pm
dood786 wrote:Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Naseem, are you using the yellow spring with your setup?
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'93 Golf CTi
'86 Mazda 323
Post by dood786 » Tue Jun 12, 2012 3:49 pm
We use stock actuators, the spring kit for the dv holds boost better depending on the boost we are running, stage 1 and stage 2 both run 1.3bar boost with 1.4 overboost. I have seen this on my boost gauge
Post by dood786 » Tue Jun 12, 2012 3:50 pm
I am currently still on the green spring, will change to yellow soon, been lazy but i am waiting for some info from forge uk regarding the spacers and then i will change it
Mojo
Post Wit Blitz
Post by Mojo » Tue Jun 12, 2012 3:58 pm
I found it made quite a nice difference but you quickly get used to that being the norm :)
Seat Ibiza Cupra
Life-R
Post by Life-R » Mon Oct 29, 2012 4:40 pm
dood786 wrote:I am currently still on the green spring, will change to yellow soon, been lazy but i am waiting for some info from forge uk regarding the spacers and then i will change it
Sorry to start an old topic again, just wanted to find out, what was Forge's feedback regarding the spacers? Im in the process of buying a 008 DV and wanna install it correctly the first time around.
2014 Polo Bluemotion 1.2 TDi
OEM+
2007 Polo GTi 1.8T
Stealth Tuned/Powerflow DP/PD160+CAI/Forge 008 DV/Forge TIP/4Bar FPR/Seat Sport FMIC/JOM Coilovers
2004 Citi Life 1.6i
Unichip/Viper Branch/Powerflow Exhaust/K&N Filter
Post by dood786 » Mon Oct 29, 2012 5:01 pm
Im actually glad you did
I fitted the yellow spring and can feel boost hold nicer
email from forge
Hi Naseem
Thank you for purchasing Forge Motorsport products.
As a rule of thumb 2 spacers will equal 1 psi but this will vary slightly depending on the application as vacuum pressures vary across engine types and tuning will also affect vacuum pressures.
We do not have an image of how they are fitted but it is relatively straightforward. Unscrew the FMCL007P lid in the anti-clockwise direction and remove the spring from the piston, place the shims in the base of the piston and replace the spring on top of the shims and replace the valve lid.
Best Regards
John Withers
www.forgemotorsport.co.uk
e mail [email protected]
Tel 01452 380999
Fax 01452 386333
Life-R
Post by Life-R » Mon Oct 29, 2012 5:10 pm
Thanks dood :hi: I have just a Stage 1 remap, so gonna go with yellow, with no spacers, i think that should be fine
OEM+
2007 Polo GTi 1.8T
2004 Citi Life 1.6i
Post by dood786 » Mon Oct 29, 2012 7:47 pm
should work perfectly
Stompie
Boostleak Guru
Car Make: VW POLO
Membership No: 1843
Post by Stompie » Mon Oct 29, 2012 8:10 pm
U only go blue at full stage 2 with all mods and some extra tuning. Im running blue spring. Used to run yellow but you can hear the car dump too easy or at slightest throttle..so then the spring is too weak and either need to add some shims or go to the next color spring
BMW 120D E87
