golf 4 2.0 exhaust - make it softer!
golfer23
Car Model: MK 4 Golf 2.0
Post by golfer23 » Wed Apr 25, 2012 9:06 pm
so my golf was having a problem with the cat a few years back, so instead of forking out R14k at vw, i paid powerflow for a very standard system, the back box is very big, and the car only has one box as they can not put one by the cat.....
also, i got bit of a kit on the car, and the exhaust tip is is a big one to fill the design.....
so my question is, if i change to a smaller exhaust tip, will it help in making the sound softer?
2003 Golf 4 2.slow
_______________________________________________________
".......life moves pretty fast, you don't stop and look around once in a while, you could miss it......" Ferris Beuller
Car Make: VW, VW, Aprilia
Car Model: Mk3, Caddy, Aprilia RSV4
Re: golf 4 2.0 exhaust - make it softer!
Post by Jetta2 » Wed Apr 25, 2012 9:19 pm
No, fitting a smaller zorst tip won't make the sound level softer. Adding silencers will.
Has the Cat been removed? If it has, why not have a small diameter silencer fitted in the space it was in?
2017 Caddy Maxi Crew Bus
2013 Aprilia RSV4 APRC track toy
golfer23
Post by golfer23 » Wed Apr 25, 2012 9:49 pm
Jetta2 wrote:No, fitting a smaller zorst tip won't make the sound level softer. Adding silencers will.
ya cat is gone......they told me that because the area where the cat is, it such a high heat area that they cannot put a box there, and if they do, the heat will just eat through the inside of it, it wont last long and they wont guaranty it.
2003 Golf 4 2.slow
graham savage
Car Model: Caddy's, Mk2's, Mk4, Ford etc
Membership No: 803
Post by graham savage » Wed Apr 25, 2012 10:01 pm
Thats BS
When mine was stock I had the cat cut out and a box put in it's place with no issues however that stock rear box is HUGE and does all the work really
https://www.facebook.com/groups/TeamGoldwagen/
[url]http://www.vwchallenge.co,za[/url]
golfer23
Post by golfer23 » Wed Apr 25, 2012 10:05 pm
the rear box i have is big....will post a pic of it tomorrow.....so should i go and put a smaller box in?
2003 Golf 4 2.slow
Post by panic-mechanic » Thu Apr 26, 2012 7:28 am
It not the physical size the dermines how loud it is. It's the design of the silencer box inside and the quality. Go to an exhaust shop and sak for something quieter. If they can't help go somewhere else.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
golfer23
Post by golfer23 » Thu Apr 26, 2012 10:20 am
well its a powerflow.....good?bad? thought they very good.....my main issue its sort of a droning noise 100-120 at around 3000rpm.....and in general, i like a sporty noise, but i still want it softer.....sound deadening another option?
2003 Golf 4 2.slow
Killerwatt
Car Model: S3
Post by Killerwatt » Thu Apr 26, 2012 10:23 am
the pysical size of the box dpes have a small effect on the loudness. But like panic said, the internal design is a bigger factor.
One box on a NA car will definitly be loud. Go to another exhaust shop and get a second box installed, there is plenty of space in the center tunnel for it.
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi » Thu Apr 26, 2012 10:30 am
Killerwatt wrote:the pysical size of the box dpes have a small effect on the loudness. But like panic said, the internal design is a bigger factor.
:iagree:
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
golfer23
Post by golfer23 » Thu Apr 26, 2012 10:33 am
ok will try get to a powerflow on saturday, but that whole story of "the heat burning through the box as where the cat was is a very high heat area" is just bs?
2003 Golf 4 2.slow
MeanTdi
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi » Thu Apr 26, 2012 10:40 am
golfer23 wrote:ok will try get to a powerflow on saturday, but that whole story of "the heat burning through the box as where the cat was is a very high heat area" is just bs?
LOL :lol: ....bs. :hi:
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Smok3X
Car Make: SEAT
Car Model: LEON CUPRA 2.0 TFSi K04
Membership No: 3083
Post by Smok3X » Thu Apr 26, 2012 11:17 am
That is the biggest load of BS I have ever heard!
If anything, there MUST be another box there, its a called a MESH WRAP box, its different to the rear box as it is made with some sort of mesh like metal material, its purpose is to absorb the excessive heat coming down from your branch and in that way help to save your rear box from burning out!
If you put your car on a dyno for a few minutes... your exhaust system will overheat due to the lack of air cooling and you will see that rear box burn out and sometimes even sparks fly out when it over heats with the insane EGT's! I have seen it many times on cars with no centre mesh wrap box.
Basically, get a mesh wrap box fitted in the middle! More boxes = less noise!
I learnt all this from my friend who owns Powerflow in Prince Alfred street Durban, his name is Darren, they did some awesome mandrel bend 304 stainless exhaust work for me!
Oh and that droning noise you hear is a characteristic noise of Powerflow boxes... They just love to drone... add more boxes and it will help.
Leon CUPRA - 2.0TFSi K04--> Rides Thread
[email protected] Artz - Stock
[email protected] Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and [email protected]
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and [email protected] Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
Mojo
Post Wit Blitz
Car Model: Ibiza Cupra
Post by Mojo » Thu Apr 26, 2012 12:02 pm
Prince Alfred Powerflow FTW !
Seat Ibiza Cupra
golfer23
Post by golfer23 » Thu Apr 26, 2012 12:14 pm
lol im in cape town @ mojo.....
so i called powerflow salt river and tokai.....both say that in stock form there normally is a silencer behind the handbrake, they should be able to fit one for me, tokai said a high heat one i think......salt river said should be R750....made a booking for saturday if i dont get there today.....will let u guys know the outcome....thanks for the help! hope u guys have an awesome long weekend!
2003 Golf 4 2.slow
Mojo
Post Wit Blitz
Post by Mojo » Thu Apr 26, 2012 12:29 pm
haha - cool just reinforcing that i dig them too :)
hope you come right dude that sounds promising - bottom line is they should supply you what you ask for with there advice and recommendations to be your decision along the way
All the best enjoy the break
Seat Ibiza Cupra
Post by panic-mechanic » Thu Apr 26, 2012 12:35 pm
The one they fit there is called a resonator....It removes that droning sound you talking about. Also know as resonance.
'09 Audi Q5 3l tdi
Smok3X
Car Make: SEAT
Membership No: 3083
Post by Smok3X » Thu Apr 26, 2012 1:04 pm
Yes, thats it, Resonator box, its made with mesh wrap... Look at the litte white sticker on the box, you will see it. Goodluck and happy quieter driving lol.
1/4 Mile:14.61s
joggiep
Car Model: RSQ3
Membership No: 664
Post by joggiep » Thu Apr 26, 2012 1:26 pm
Builders sell ear pluggs for like R12..... problem solved.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
CURRENT CARS
BMW 335
Mojo
Post Wit Blitz
Post by Mojo » Thu Apr 26, 2012 1:52 pm
Seat Ibiza Cupra
