Barometric Pressure / Engine Speed Sensors
Gareth.Hooper
Membership No: 1624
Post by Gareth.Hooper » Thu Apr 05, 2012 8:38 am
Hi All.
Does anyone know what these two sensors will set me back give or take:
3 Faults Found
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
00528 - Barometric Pressure (Altitude) Sensor (F96)
06-00 - Signal too High
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
Readiness: N/A
I am suspecting the mixture adaption is an affect from the Barometric Sensor.
Gareth
Re: Barometric Pressure / Engine Speed Sensors
Post by panic-mechanic » Thu Apr 05, 2012 10:06 am
Will help if we know what car. Is the car running at all. If yes you can ignore the g28 crank sensor one.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Gareth.Hooper
Membership No: 1624
Post by Gareth.Hooper » Thu Apr 05, 2012 10:16 am
Apologies.
2002 Golf 4 GTi 110
190 000km
Runs
However, randomly it wont start, turns but does not start.
My scenario is similiar to a vwvortex poster that had the same concern with the engine sensor resolving the concern. Just querying locally first to ascertain validity.
Example, this morning it started first time when leaving home. Drove 2km and stopped and fuel station (shop) -10 minutes max, when leaving there the car would not start, igntion does its thing but engine does not actually start.
Another Example, Left office for Orange grove, all good, spent 3 hours that side, when leaving the same thing.
Car can be roll started.
Gareth
Post by panic-mechanic » Thu Apr 05, 2012 10:25 am
Well then it's possible that you have an issue with the pickup. It could also be the cam pickup that messes around. The main thing you have to do is some invstigating. Next it won't start have a look in vagcom and see if you can see the engine rpm in the measuring blocks. Should crank at around 220 rpm. If it shows 0 then you know the pickup is not working.
'09 Audi Q5 3l tdi
BatteryWorldPtaEast
Car Model: Polo TDI Sportline
Membership No: 1572
Post by BatteryWorldPtaEast » Thu Apr 05, 2012 11:49 am
As far as I know this is in the ECU ,but I can be wrong.
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
www.servicespst.com - maintenance / service plan incl tyres
crashtestdummy
Post by crashtestdummy » Thu Apr 05, 2012 12:54 pm
This sensor is located behind the left grill of the front bumper
Digit Riaan
Post by Digit Riaan » Thu Apr 05, 2012 1:00 pm
crashtestdummy wrote:Barometric Pressure (Altitude) Sensor (F96
You sure? My AGU's sat on the firewall, just behind the turbo intake pipe...
http://www.golfgtiforum.co.uk/index.php?topic=176545.0
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100 383, '79 Golf LS
Hers: '10 Mitsubishi Outlander
crashtestdummy
Post by crashtestdummy » Thu Apr 05, 2012 1:29 pm
You are right, i got confused bet this and the external temp sensor.. :oops:
Golf Fanatic
Post by Golf Fanatic » Sat Apr 07, 2012 7:44 pm
I had an error for the barometric pressure sensor, the car had no issue drove normal. Replaced the sensor did not make any difference. Was told that the sensor detects how thick the air is (altitude)and relates the info to the computer box
Hope this helps : :hug:
A3 1.8T Sportech Yellow
Mazda 3
MK1 1800 8v Sidies (Sold My Heart Aches)
MK3 GTI Black (Sold..)
K1 GPR Prokart
Suzuki GSX R 400
Suzuki GSX R 750 (Motor Blown)
Speed
Lunatic
Under
Throttle
g60 golf
Membership No: 388
Post by g60 golf » Wed Apr 11, 2012 7:11 am
G28 can cause start issue on some so can the alltitude sensor as that determins how much fuel is needed for the alltitude you at.
It sits on the fire wall behind airbox and then latter units in the engine ecu.
Check the wires for the unit and swop the unit out first same for the g28 if you can.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
