golf mk1 horn staying on
araf69
Car Model: 2008 MK5 GTi DSG
Membership No: 1739
Postby araf69 » Mon Feb 27, 2012 7:34 pm
Tried to put dual hooters today. Wired it up with the relay. But when I put the key on. The hooter says on without pressing the button. Tested the wiring with a test light, seems the problem is with the steering wheel and power is coming from there when the ignition is on. Anything to look for that touching on the steering?
I did remove the steering wheel to put an ignition switch. Old hooter was disconnected at the time but was working with the same steering wheel.
my rides thread : viewtopic.php?f=11&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
otti
Car Model: ´80 gti 1.8t + ´00 mkIV 2.slow
Re: golf mk1 horn staying on
Postby otti » Mon Feb 27, 2012 7:57 pm
seems like your steering coloum gets ground to me, check the penetration through the firewall if it contacts there!
maybe you clamped a cable....
KID'K
Car Model: Kombi Pannelvan, MK2 CSL
Postby KID'K » Mon Feb 27, 2012 7:59 pm
If you suspect anything on the steering wheel, check the gold contactors in between the steering wheel and the ignition column. Check if there’s no metal contact between the two, if there’s any foreign object making the two to contact remove it. Otherwise verify your hooter wiring. If the problem persists get an auto electrician to check it out for you.
In this industry nothing just bolts on. you've got to just make it fit.
Postby panic-mechanic » Tue Feb 28, 2012 7:35 am
You do know that there is always power on the hooter circuit when the ignition is on and that the steering wheel button grounds the circuit to make it work?
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 7:50 am
Thanks panic did not know that? Should I try another steering?
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Postby panic-mechanic » Tue Feb 28, 2012 7:52 am
No perhaps have a little look at your wiring?
'07 Audi A4 2l TDI
SJP100
Postby SJP100 » Tue Feb 28, 2012 8:47 am
Hope this helps
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 9:56 am
That's helps a lot. I do have an earth running of the horn currently and not the button, is that the problem?
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Tue Feb 28, 2012 11:18 am
araf69 wrote:That's helps a lot. I do have an earth running of the horn currently and not the button, is that the problem?
If you take the earth off does the horn stop? If so, that is your problem.
Current rides:
Hyundai - 1.4 Getz (daily)
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 12:22 pm
I tried that yesterday the horn goes off when I pull out the earth. Where must I put the earth. I did mount the earth on the body in the engine bay.
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Tue Feb 28, 2012 12:35 pm
araf69 wrote:I tried that yesterday the horn goes off when I pull out the earth. Where must I put the earth. I did mount the earth on the body in the engine bay.
The earth must be switched through the hooter button on the steering wheel. When my horn stopped working I pulled in a seperate wire to a button on the dash and used that instead of the button on the steering wheel.
Current rides:
SJP100
Postby SJP100 » Tue Feb 28, 2012 12:36 pm
There's your problem. You should just supply the positive, the horn button supplies the earth.
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 2:09 pm
where must put the earth then? or does the button have the earth. Have tried that but then nothing happens when I press the button when I pulled the earth out.
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Torker
Car Model: Golf GT
Membership No: 1464
Postby Torker » Tue Feb 28, 2012 2:14 pm
araf69 wrote:where must put the earth then? or does the button have the earth. Have tried that but then nothing happens when I press the button when I pulled the earth out.
There is an earth strap from the body to the steering column inside the engine bay - make sure it's intact. Also on the back of the steering wheel there's copper slip rings with fingers that get the potentials to the hooter button - make sure it's making proper contact there...
Current rides:
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 4:15 pm
My old hooter worked fine before this. The only thing that I did was remove the steering column to put a new ignition switch. those springs on the steering shaft important? I didn't put then back
Ex 95 uno turbo
Ex 84 mk1 2 door GT
araf69
Membership No: 1739
Postby araf69 » Tue Feb 28, 2012 7:20 pm
Steering Shaft seems to problem. Its too wobbly. Can it be that? Does the spring in the steering shaft play a role somehow?
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Return to “General Tech Discussions”
Users browsing this forum: Gollum, hubbly_bubbly, Majestic-12 [Bot] and 79 guests
