Possible leak somewhere...Update- Leak found...now to FIX
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
hozit guys,
hope this is in the correct section.
last year about September my polo started making some hissing sounds, almost sounds like a leaking exhaust.
i went and checked the exhaust but no leaks, ran logs and no boost leaks as ECU is getting the requested boost. changed DP as i thought it could maybe be the De-cat i was running or the gasket between the DP and Turbo. but still this hissing leaking noise is there.
this noise comes in when you rev the car, or start driving...
could this be the symptoms of a cracked manifold? i still have all my power and the sound doesn't seem to get louder?
seriously need to get rid of this sound....its irritating!!
- Amith11
- Car Make: DUH !!!
- Car Model: MK7 GTI
- Membership No: 1545
Re: Possible leak somewhere...Please help
At the risk of me sounding dumb...
Is it not just your D/V ?
MK 7 GTi
(Daily)
amith.singh@icloud.com
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk4 GTI .:R (True Love)
MK3 Cabriolette 2.0l Exec
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
(Daily)
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
- Stompie
- Boostleak Guru
- Car Make: BMW
lol im open for any sugestions.
why would you say DV? i mean this hissing starts happening from pull away through revs, at low revs there isnt any boost so the boost can open it...ive changed springs as well. new TIP was installed to make sure its not a leak.
the only thing i havent checked is the manifold, mani gasket, mani to turbo gasket...
- Tdi jetta 4 ever
Does this happen when the aircon is on or off?
Robin
robinwisse@gmail.com
- Stompie
- Boostleak Guru
- Car Make: BMW
haven't really checked it that way but air-con is mostly off...
- ruler_70
- Colonel
- Car Model: Golf 7 GTI
I had a similar sound coming from my engine bay and it turned out it was my engine cover that had come loose and was rattling.
Check that the silver part of the engine cover isnt loose.
Current: 2018 Golf 7.5 GTI
Ex: 2016 Golf 7 GTI
Ex: 2014 Audi A3 Sportback 1.8T
Ex: 08 Silver Bird Polo GTI
Ex: 06 Polo 1.6i Comfortline
Ex: 98 Mk3 Golf GSX 1.8i
Ex: 2016 Golf 7 GTI
- Stompie
- Boostleak Guru
- Car Make: BMW
serious? i know its loose, will remove it and check if it goes away
- ruler_70
- Colonel
Its a long shot, but i really hope its sorts out your problem.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- Stompie
- Boostleak Guru
- Car Make: BMW
mee too!!! its been going on since last year, took it to FRC, they put it on the lift and checked for leaks arround the turbo but couldnt find anything...i simply cant see wat is causing this....and car was dynoed with this and power was strong, i mean stock it was stronger that some other polo gti's. so im not loosing power....
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Have you fiddled with boost pipes or intake manifold to fit a boost gauge or something similar?
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
nope, no boost gauge...sound started after i fited a cone filter last year, tried putting back the airbox and sound is still there...
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Try and look at what you have changed when you fitted the filter.PoloGTIman wrote:nope, no boost gauge...sound started after i fited a cone filter last year, tried putting back the airbox and sound is still there...
NB - did you reconnect that tiny tube that goes to the top of the airbox somewhere? Not sure if the GTI has it but there is one on the TDI airbox. I will try to find a pic...
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- BatteryWorldPtaEast
- Car Model: Polo TDI Sportline
- Membership No: 1572
Does the GTI also have the vacuum hose on the airbox ?
Check where it is ,it needs to be connected to the intake.
Hope it helps.
Hope it helps.
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
That is what I was trying to describe above.BatteryWorldPtaEast wrote:Does the GTI also have the vacuum hose on the airbox ?
Hope it helps.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
@meantdi - no there isnt any blue tube on my airbox, on the side there is a pipe that sucks in air to warm up the catalytic converter...but that only sucks air when you start the car.
at first i had only the 90deg bend with cone, without any software or dv. this is how i started modding the car...lol, replaced DV with forge one, sound was still there, replaced the pancake tip with a brand new Forge TIP, sound is still there, checked exhause and decatted and sound still there, replaced the whole DP with wildcat one and new gasket, sound still there. now all i can think is that the manifold is cracked or the caskets between turbo and block is leaking...but if they were leaking, the sound would have become louder...
this is why i think its a crack??
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Tube is not blue but black on the TDI. Most probably the GTI does not have one...PoloGTIman wrote:@meantdi - no there isnt any blue tube on my airbox, on the side there is a pipe that sucks in air to warm up the catalytic converter...but that only sucks air when you start the car.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
how thick is this pipe?
because the one ive got on the side is about 40mm in diameter.
but that isnt a vacuum im sure.
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Tiny, 5mm max in diameter.PoloGTIman wrote:how thick is this pipe?
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
no defnitley havent seen anything like that...? will have a look to make sure.
will a small pipe like that be able to make such a noise ?
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Not sure how load the noise is.PoloGTIman wrote:no defnitley havent seen anything like that...? will have a look to make sure.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
the noise is coming from the driver side, if i open the passenger window and close the driver side i cant hear the noise.....if that maybe helps. also not loud! but you can hear it...
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
I have uploaded a pic from a Seat Ibiza TDI. Like I said, the GTI may not have that tiny pipe going to the airbox...
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Stompie
- Boostleak Guru
- Car Make: BMW
sup guys,
ok some good news, i took my car in for its 75k oil service yesterday at Bryanston VW and booked the car with frans.
went to fetch the car and frans asked me if i knew why my exhaust is so loud...i said no? but have a suspicion that the manifold is maybe cracked....
while doing the service he had a look and says its between the turbo and manifold. says it could either be the gasket or the manifold that wobbled where it connects to the turbo...
now, where can i get a new manifold and gasket and what would it cost? think i will first try a new gasket (cheaper option) and if the sound still stays then look at either repairing the manifold or replacing it (mabe with a bigger mani)
he also says that i will be loosing alot of power as the air is escaping before it hits the turbo so not spinning the turbo as strong as it should...
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Re: Possible leak somewhere...Update- Leak found...now to FI
WHEN MY CAR IS FIXED just book it in for Frans to put a new gasket in for you.
- Sparkz0629
- Car Model: 2012 Polo GTI
- Membership No: 1768
lol sinbad, you still waiting for your car????Sinbad wrote:WHEN MY CAR IS FIXED just book it in for Frans to put a new gasket in for you.
Current: 2012 Reflex Silver 6R Polo GTI
2006 1.9TDi Sportline - 158.7Hp & 413Nm at K.A.R 19-05-2012
VWicked wrote: I could do 300km/h if I wanted but I don't trust my brakes stopping from that speed so as soon as i hit exactly 241km/h on my garmin i will tap off, generally it takes me me 6.9 sec to get there so I will just cruise the last 5 sec's to allow the car to cool down..
