Mk1 rev counter sender unit
klippie
Car Model: MK1 Caddy, Mk3 VR6 Jetta
Membership No: 1658
Post by klippie » Mon Dec 19, 2011 6:40 pm
Ok guys a quick Q,
Where does the rev counter in the cluster get its data from? I have a new cluster but the rev counter is dead, i suspect the sender unit to be fault if there is such a thing...
Everything else on the cluster works
**** you thunder, you can suck my ****!
the BlueWafle http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=119334 - SOLD
the Storm Trooper http://www.vwclub.co.za/phpbb3/viewtopi ... 9#p1612279 - Crashed
jetta786
Car Model: MK2 JETTA CLX 2LTR
Membership No: 1715
Re: Mk1 rev counter sender unit
Post by jetta786 » Mon Dec 19, 2011 7:14 pm
Did your old cluster not have a rev counter? if not and u fitted one to accomodate rev counter, then the signal comes from the negative of your 2 pin coil.
klippie
Membership No: 1658
Post by klippie » Mon Dec 19, 2011 10:11 pm
thank you velly much. will check tomorrow moring. the old cluster did have a rev counter, but the board connector was f'ed. so got a new one. the rev counter has never worked. so thus i believe that to be the problem. ill look for a wiring diagram for the cluster online. to make sure that the wire is running to the coil.
marnus
Membership No: 1975
Post by marnus » Mon Dec 19, 2011 11:26 pm
What management are you running dicktator?
marnus
Membership No: 1975
Post by marnus » Mon Dec 19, 2011 11:27 pm
Are you running any aftermarket management?
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 10:07 am
Hi Marnus,
Yes I'm running Dicktator......
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 2:31 pm
bump, what does Dicktator have to do with the issue? Please explain?
ACiD_Omega
Car Model: 2004 Chico under construction
Membership No: 1820
Post by ACiD_Omega » Tue Dec 20, 2011 4:23 pm
Your dicktator can also supply tach signal, but the diagrams on the website doesn't work on my PC, good luck
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 4:32 pm
what is the website
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 4:34 pm
no worries, i found the diagram. i see the pin that supplies the output. now to find one for the cluster.
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Tue Dec 20, 2011 4:36 pm
Bru its pin 4 on dicktator that supplies rev counter signal. you using square dash cluster so it will work fine without resistors etc.
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
VWicked
Membership No: 1492
Post by VWicked » Tue Dec 20, 2011 4:37 pm
i think the wire is green for rev counter on the cluster but check. its been over two years that i had a look at a citi type cluster
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 4:48 pm
ill have a look, I'm just scared I'm gonna cut the wrong wires and break something.
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 5:10 pm
There are to many wiring diagrams on the web, making my head spin........
http://www.veedubz.co.za/tech/VW%20Hayn ... AGRAMS.pdf
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 5:44 pm
found this, does it look right?
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 5:47 pm
and this,
seems like its the red and black wire
jetta786
Membership No: 1715
Post by jetta786 » Tue Dec 20, 2011 6:40 pm
on what car is this? i see your profile reflects caddy??
check this link. make sure the ecu is connected correctly.
http://www.dicktator.co.za/diagrams.html
hope this will help.
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 9:33 pm
ok, so i cut the blue no 4 wire running to the ecu, connected that (ecu side) to the cluster. Nothing.
My harnes plug looks like this,
Gray
Brown
Purple
Yellow with a red stripe
Red with a black stripe
Red
Blue with a white stripe
Thick Black
Thick Black
Blue
Blue with a red stripe
Black
I connected it with the Yellow/white and the red/black.
any idea's?
klippie
Membership No: 1658
Post by klippie » Tue Dec 20, 2011 9:34 pm
jetta786 wrote:on what car is this? i see your profile reflects caddy??
Used it thanx bud. Jip Caddy 82 and 2006 cluster
marnus
Membership No: 1975
Post by marnus » Wed Dec 21, 2011 10:24 am
Is this for the old shape dashboard?
klippie
Membership No: 1658
Post by klippie » Wed Dec 21, 2011 12:16 pm
that is correct sir!
klippie
Membership No: 1658
Post by klippie » Wed Dec 21, 2011 3:45 pm
Ok, so i will be running a new wire through from the coil, to which wire do i connect this new one? See above for colors.
marnus
Membership No: 1975
Post by marnus » Thu Dec 22, 2011 7:34 am
I had the same problem but I have the new dash. I have a old wiring loom laying around. Will have a look and maybe trace the wires for you.
Check this. Here the guys say on the old dash its the thick green wire but dont see a thick green wire on your wires.
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=128344
klippie
Membership No: 1658
Post by klippie » Thu Dec 22, 2011 8:19 am
thanx, no green wire on the loom, will rip it all out this weekend and do some testing.......
CeeTwo
Membership No: 1469
Post by CeeTwo » Thu Dec 22, 2011 10:10 am
marnus wrote:I had the same problem but I have the new dash. I have a old wiring loom laying around. Will have a look and maybe trace the wires for you.
Sup Marnus,
How did you solve the new dash rev counter problem? im running dicktator with new dash?
Daily: Suzuki Ertiga
Weekends: Q7 3.0 TDI
