Best Oil for high milage
- naidup
- Car Model: Citi 1.4i
Howzit guys...
Whats the best oil for a high mileage engine(340 000kms)? -normal 8v motor.
I've tried Shell Helix HX3 and it worked fine but is very noisey on cold start, tried magnetec and motor was silent thou oil consumption was higher.
Any other good oils? Shell Helix HX5 -15w40?
Let's hear what you guys use.
Thanks in advance
Thanks in advance
- Tdi jetta 4 ever
Re: Best Oil for high milage
There is a shell helix marked on the can "for high mileage motors" but I can't remember the name.
Robin
robinwisse@gmail.com
- Fran
- Registered for: 20 years 6 months
- Membership No: 1306
There is Shell Helix High Mileage, 25W60, also a yellow container.
2000 Vw Citi ABF 2.1 16v, tdi crank, 84mm pistons, Dicktator - 115.5kW & 202 Nm at the wheels
- Tdi jetta 4 ever
Aha^^^^^thats the one.
Robin
Fran wrote:There is Shell Helix High Mileage, 25W60, also a yellow container.
and add a bottle of wynns charge.
HORSEPOWER WINS CONVERSATIONS TORQUE WIN'S RACES!
- naidup
Wouldn't that oil make it more noisey as it's much thicker? Would the 15w40 not be better?
Castrol high mileage 15w 40 worked wonders on my range rover with 220 000 km on it
Current: 2013 Golf 7 GTi (White)
Ex: 2011 Polo GTi 6R (Candy White)
Ex: 2006 1.9 Golf 5 TDI (Blue Graphite Pearl)
Ex: 1996 4.6 Range Rover (Niagra Grey)
Ex: 2007 1.6i Velocity STD (A/C T/B S&G)
Ex: 2004 1.4 Chico (Tossa Blue)
Ex: 1976 1600 Beetle (Black)
- BIGMIG
- Porra Love
- Membership No: 1574
I heard that stuff is very bad for lifter and oil pumps due to it getting way to thickScooby GP wrote:Fran wrote:There is Shell Helix High Mileage, 25W60, also a yellow container.
- naidup
So did I.I heard that stuff is very bad for lifter and oil pumps due to it getting way to thick
Went to GW PMB and the guy sold me Shell Helix HX5 15w40- says it's a better oil.
Will it not be too thin for the high mileage?
Last time i used this oil i had to change my oil pump due to bad oil pressure.
- naidup
bump...
- heineken
- Car Model: MKII Jetta CSL
- Membership No: 2009
Last year on my MK2 Jetta I used Shell Helix HX3 20w50 and found it very noisy on start up as well as using half a pint of oil every week.qwerty wrote:So did I.I heard that stuff is very bad for lifter and oil pumps due to it getting way to thick
This year started using Shell Helix HX5 15w40 and found it to be much more quiet, a small improvement in fuel consumption and uses half a pint of oil every 2 weeks.
Next week my car is going in for an oil service, going to try Shell Helix HX7 10w40 and see how it goes.
Smooth Carpuretor: http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=129428
- cli 16v
- Car Make: Mazda
- Car Model: CX5
The 15W40 is not " a better oil" it just has a different viscosity than the 25W60. I would use the Helix 25W60 or Castrol high mileage 20W50 as the problem you are having is the so called "thinner" oil is being burnt up due to it leaking through oil seals and increasing oil consumption.
'15 MKVII GTi
'07 MKV GTi OEM+
'89 MKII Golf CSL OEM
'97 MKIII GTi Exec
'15 MKVII GTi
'07 MKV GTi OEM+
'97 MKIII GTi Exec
- General
- Registered for: 18 years
- Car Model: Golf 7R
i used Shell High Mileage on my DeCo. car ran good with it.
- Major-General
- Registered for: 21 years 1 month
- Car Model: MK1
If the motor is using oil, use a thicker viscosity.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- GolfMad
- Car Make: Nissan
- Car Model: Terrano 2.7 TDi 4x4
I used Shell, 20w50 back when I had my Audi 500, with 417,XXX kilos on original engine, and it ran smooth and quiet, allthough using about 0.5l per 1000 kilos...
- naidup
Another thing that worries me is that with Shell HX3(20w50)is the topup pints in the tin say HX3 but SAE40. I did notice the car does give out a bigger puff of smoke with HX3 oil(i know, i know-valve stem seals are worn). Isn't 25w60 going to be even nosier on start up due to it being thicker?
Just curious.
Just curious.
- graham savage
- Colonel
- Membership No: 803
Jus put gearbox oil
- cli 16v
- Car Make: Mazda
- Car Model: CX5
graham savage wrote:Jus put gearbox oil
Dude that noise if it will be there at start up is something you will have to live with. You say your valve stem seals are worn, you are trying to put a plaster on a a stab wound. Oils are not developed to stop cars from smoking they are developed to lubricate moving parts so you not going to find this optimum oil that will stop your car from smoking.
'15 MKVII GTi
'07 MKV GTi OEM+
'97 MKIII GTi Exec
'15 MKVII GTi
'07 MKV GTi OEM+
'97 MKIII GTi Exec
- freezaburn
- Car Make: VW, Audi, Toyota,BMW
- Car Model: GTi,Citi Sport,Raider,A4, 316i
Castrol High Mileage - ask my 1.6 Citi Spor, It's been going for 26 years *cough*
All Current Rides:
-2009 Audi A4 (B8) 2.0T FSI Avant (155kw)
-2005 Audi A4 (B7) 2.0T FSI Avant (147kw)
-2005 Toyota Hilux D/C 2.7VVTi (118kw)
-1995 BMW E36 316i
-1994 Golf MK3 GTI 2.0 Exec (85kw)
-1986 Citi Golf Sport 1.6 (63kw)
- naidup
I know i need to do the motor but just don't have the time right now to get it done with Christmas etc. so I'm looking for a reasonably good oil to prevent further wear. besides put it on a dyno not too long ago to check for any power loss and it's just as strong as any other 1.4i. Gonna change the gearbox oil too(BOT130M).
Maybe I'll just try the Shell Helix HX5K-High Mileage and get it done with for now.
- naidup
One more thing...
Will the 25w60 oil not be too thick and cause the oil pump to struggle causing problems on cold start?
- graham savage
- Colonel
When your motor is bleeding oil out from worn main and big ends a thicker oil is better for the pump to build some pressure...qwerty wrote:One more thing...
- Preggz
- Car Model: 06 Velociti & 13 6r PGti
my Velociti is Due for a Service its doing around 270XXXkm
what oil should i get.
VW Service kit for Citi golf comes with castrol magnatec oil (is it fine)
LöW Ridër Velociti
JOMs FTW
Reflex Sliver Polo 6R GTI
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
- Blade
- Car Make: Polo
I read a few years back on the net that its not advisable to change oils from fully synthetic to regular oil unless you 1st do a engine flush. You could damage your seals by doing that because the 1 expand the seals and the other shrink the seals.
Shaheem
Polo 6, 1.4 Comfortline
- Neuk
- Treasurer
- Membership No: 806
What grade oil is in that service kit?Preggz wrote:Hi guys
