AEN vs FFZ
Benitovw
Car Model: CITI ADY
AEN vs FFZ
Post by Benitovw » Sun Jul 31, 2011 4:32 pm
Guys which one will be better on a 2l ADY motor for the quarter mile?
CITI 2L 8V
Torker
Car Model: Golf GT
Membership No: 1464
Re: AEN vs FFZ
Post by Torker » Sun Jul 31, 2011 5:30 pm
I've got a hybrid gearbox in my GT, AEN gear ratios and FFZ final drive - makes for a nice short ratio gearbox:
FFZ Ratios - 3.46/1.94/1.37/1.03/0.85 and final drive 3.94
AEN Ratios - 3.46/2.12/1.44/1.13/0.85 and final drive 3.67
1st and 5th is the same, 2nd, 3rd and 4th is better spaced.
Current rides:
Hyundai - 1.4 Getz (daily)
Benitovw
Car Model: CITI ADY
Re: AEN vs FFZ
Post by Benitovw » Sun Jul 31, 2011 6:31 pm
@Torker but which 1 would be better cause I have a AEN box would a FFZ box be faster?
CITI 2L 8V
Torker
Car Model: Golf GT
Membership No: 1464
Re: AEN vs FFZ
Post by Torker » Sun Jul 31, 2011 7:00 pm
FFZ Speeds:
AEN Speeds:
From the above you can see that the FFZ got the shorter 1st gear and 3rd gear but the longer 2nd gear - I would say that apart from the less than ideal 2nd gear the FFZ would be the better option for short sprints. The long 5th gear in the AEN is more geared towards saving fuel than performance.
Current rides:
Benitovw
Car Model: CITI ADY
Re: AEN vs FFZ
Post by Benitovw » Sun Jul 31, 2011 7:35 pm
Thanx Torker
I'll stick with the AEN because from 1st to 4th it looks close but I need the longer 5th for my everyday driving.
CITI 2L 8V
Fiefster
Car Model: 2005 1.4 CitiGolf
Re: AEN vs FFZ
Post by Fiefster » Mon Aug 01, 2011 9:06 am
:hijack: Can anyone please explain to me what the final drive is?
Nuclear powered spaceship
Disguised as a 1400 citiGolf
CRASH_IT
Car Model: 8P S3
Membership No: 1540
Re: AEN vs FFZ
Post by CRASH_IT » Mon Aug 01, 2011 10:28 am
:crazy:
What went wrong in my AEN then i dont know cause that thing was kak!
Short sprints were awesome but 5 gear at 120km/h @ nearly 4000rpm!
I now have a FFZ and is alot better 120km/h @ 3500rpm!
Lil more legs in the mid range gears tho.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
Fiefster
Re: AEN vs FFZ
Post by Fiefster » Mon Aug 01, 2011 11:12 am
CRASH_IT wrote::crazy:
My ffz box is like this. 120km/h (on the clock) and I'm at 3500 rpm, 120 true speed and I'm at 4k rpm. Top out at +-175km/h on a straight.
pepa
Re: AEN vs FFZ
Post by pepa » Mon Aug 01, 2011 12:16 pm
from those 2 graphs i see teh AEN is
faster in all gears.
teh lower teh number of teh gear & diff
teh longer teh gearing & diff ratio.
teh higher then teh opposite.
FFZ is a nice ratio for std & mild tuned cars.
For hi output engines go with longer ratios
a FFZ with a 3.67 final ratio......hmmmm i wonder.
Sud go well with some beeg torque.Anyone?
Benitovw
Car Model: CITI ADY
Re: AEN vs FFZ
Post by Benitovw » Mon Aug 01, 2011 2:52 pm
So which is faster on 2l ADY motor the AEN box or the FFZ box for 400m?
CITI 2L 8V
Torker
Car Model: Golf GT
Membership No: 1464
Re: AEN vs FFZ
Post by Torker » Mon Aug 01, 2011 2:58 pm
After Poy built me a close ratio box (AEN gears and FFZ final drive) he used the stuff left over to built me a box with FFZ gears and AEN (3.67) final drive. I sold it to aarchaic on the forum and he put it in his Jetta - he was looking for a more relaxed drive and he is very happy with it.
Current rides:
Wit Ark
Car Model: Citi Chico baby dragster
Re: AEN vs FFZ
Post by Wit Ark » Thu Aug 04, 2011 5:31 pm
This is what Poy built for me
3.45 1st 2.12 2nd 1.44 3rd 1.13th and 0.85 5th
Final drive ratio is 4.25
Diff bolt kit
Vereway limmited slip diff
Overshift stoppers on 3rd and 4th, not so sure what these are for.
Pre load and backlash is done perfectly to 5kg, whatever that means or do
Rose joint adjustable short shifter kit
2.0i ADY. 90.2kW & 198.1Nm atw excl. 40Horses VAT 13.9980sec @ OKH nationals 7/4/2012
aarchaic
Car Model: 1991 Jetta Clx Mk2
Membership No: 1628
Re: AEN vs FFZ
Post by aarchaic » Mon Aug 08, 2011 12:13 am
FFZ will be better as it has more torque to get you off the line. but you will run out of legs on longer runs.
Membership Number: 1628
1991 Vw Jetta MK2 CLX ( ADY 2.0, 8v 282 cam , 96.7hp atw 144 Nm )
91 Vw Jetta Mk2 Build - ADY - Dyno Graph Pg 16
In Car Entertainment Build & Install Completed - Thread
Jeremy Clarkson : “I'll tell you what. We'll try it my way first... and then we'll finish!”
aarchaic
Membership No: 1628
Re: AEN vs FFZ
Post by aarchaic » Mon Aug 08, 2011 12:21 am
pepa wrote:a FFZ with a 3.67 final ratio......hmmmm i wonder.
with 195 / 50 - 15 wheels at 4000 rpm these are the speeds you should get
Std FFZ - 129.65km/h
Std AEN - 132.94km/h
FFZ gears AEN Final Drive - 139.19km.h
