Knife edge crank
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Knife edge crank
Post by Naku786 » Fri Apr 08, 2011 8:58 am
:hi:
What does this mean? I hear alot of guys talking about it & also the TDi crank conversion.
Whats the benefit of it & what application is it intended? (Track car, drag car, daily)
Thanks :driving:
Torker
Car Model: Golf GT
Membership No: 1464
Re: Knife edge crank
Post by Torker » Fri Apr 08, 2011 9:01 am
The stroke on a TDi crank is 95.5mm, larger than a std 2.0 crank's 92.8mm so it will give you slightly larger dispacement.
Current rides:
Hyundai - 1.4 Getz (daily)
Naku786
Cake Laaitie Killer
Post by Naku786 » Fri Apr 08, 2011 9:05 am
Torker wrote:The stroke on a TDi crank is 95.5mm, larger than a std 2.0 crank's 92.8mm so it will give you slightly larger dispacement.
Thats what knife edge means? lol I taught it made your car rev up quicker
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Fri Apr 08, 2011 9:08 am
Knife edging is something different where they take metal of the crank - makes it lighter and more aerodynamic so it should make your engine rev up quicker. You can see the taper on the counter weights on the crank in the photo - that's knife edging:
Current rides:
Naku786
Cake Laaitie Killer
Post by Naku786 » Fri Apr 08, 2011 9:18 am
Torker wrote: Knife edging is something different where they take metal of the crank - makes it lighter and more aerodynamic so it should make your engine rev up quicker. You can see the taper on the counter weights on the crank in the photo - that's knife edging:
Will this decrease the amount of torque(nm) the car produces?
GTiDon
Membership No: 1161
Post by GTiDon » Fri Apr 08, 2011 4:31 pm
Im impressed.. Normally by this time of a thread with this question everybody would be telling you not to knife edge, not to even think about it and to stay away...
Coroner
Car Make: VW / Subaru
Car Model: Citi 1600 / 2.0 T
Membership No: 1502
Post by Coroner » Fri Apr 08, 2011 4:40 pm
gtidon wrote:Im impressed.. Normally by this time of a thread with this question everybody would be telling you not to knife edge, not to even think about it and to stay away...
As far as my research goes, its not recommended for a daily. Also according to the Mythbusters thread the TDI crank eats bearings on a normal 2l.
If not done correctly you could end up with a lot of damage.
Speed is money......how fast do you want to go?
