mp 9 wiring diagram please
vdubs4life
Car Make: mazda 6
Car Model: mps
Post by vdubs4life » Tue Oct 12, 2010 6:33 pm
hi there people does anybody know where i can get a wiring diagram for mp9
or if anybody knows if the injectors are polarity sensitive or not ?
Re: mp 9 wiring diagram please
Post by panic-mechanic » Wed Oct 13, 2010 9:09 am
Injectors are not polarity sensitive no. But if you have a piece of the wiring harness you will see there is one wire that is common to them all. That one is the 12v+
If you just search or look back about a week - somebody posted the mp9 pinout diagram.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
vdubs4life
Car Make: mazda 6
Car Model: mps
Post by vdubs4life » Wed Oct 13, 2010 10:05 am
thanks alot panic ill check back for those pinouts
amstel18
Car Model: Polo TSI
Post by amstel18 » Wed Oct 13, 2010 10:19 am
Here you go:
MP9.0 Pinouts for TiiCo ECU.
1 Ground
2 Throttle body 1
3 NC
4 Injector 4
5 NC
6 Injector 2
7 Injector 1
8 Phase sensor +5V
9 RPM signal ------------------>Rev counter
10 Throttle body 3
11 GND
12 NC
13 Phase sensor signal
14 Throttle body 4
15 NC
16 Throttle body 8
17 GND
18 TMAP 4
19 Knock sensor 2
20 NC
21 Batt 12V
22 NC
23 GND
24 Ignition Control unit
25 Fuel pump relay-------------> Fuel pump switching relay
26 Throttle body 2
27 NC
28 Inj 3
29 Diag K-Line ----------------> to pin 7 on the diagnostic port
30 NC
31 NC
32 NC
33 NC
34 NC
35 AC
36 Vehicle speed input --------> From speed sensor
37 TMAP 3
38 O2 Data --------------------> Oxygen sensor (Exhaust)
39 Knock sensor 1
40 NC
41 Throttle body 5
42 Engine Coolant sensor
43 TMAP 2
44 NC
45 Screen for Phase and Knock sensor wires.
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
vdubs4life
Car Make: mazda 6
Car Model: mps
Post by vdubs4life » Wed Oct 13, 2010 2:11 pm
thanks for the help guys the only thing is the gotech wants three wires for tps and mp9 pinouts just say throttle 1 4 5 which of these is signal which is negative and same goes with distributor and then the idling sensor cause mp9 has like 8 wires to each of these sensors oh and same with water temp
Post by panic-mechanic » Wed Oct 13, 2010 2:28 pm
Uhm - WTF does gotech feature now all of a sudden. You were asking for a wiring diagram for MP9 yes?.
'07 Audi A4 2l TDI
vdubs4life
Car Make: mazda 6
Car Model: mps
Post by vdubs4life » Wed Oct 13, 2010 4:34 pm
Cause im changing from mp9 to gotech if i know the outputs of mp9 then ill know what must connect where on the gotech correct me if im wrong im trying to figure this out
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Wed Oct 13, 2010 4:39 pm
vdubs4life wrote:Cause im changing from mp9 to gotech if i know the outputs of mp9 then ill know what must connect where on the gotech correct me if im wrong im trying to figure this out
Basically the same as what I want to do except I'm going with Dicktator.
PS - Mail sent...
Current rides:
Hyundai - 1.4 Getz (daily)
vdubs4life
Car Make: mazda 6
Car Model: mps
Post by vdubs4life » Thu Oct 14, 2010 10:52 am
nobody know where to get this diagram
UDC
Membership No: 1041
Post by UDC » Thu Oct 14, 2010 11:21 am
MhVW
Car Model: '06 Polo Classic 1.9 TDi
Membership No: 1466
Post by MhVW » Fri Mar 04, 2011 12:23 am
Ok, I'm trying to wire up my EFI management to the MP9 throttle body.
I need to connect the TPS signals to pins 4 - earth, 5 - signal and 7 - 5V. As per the diagram above.
Only problem, I don't know which pin is which on the connector on the MP9 throttle body.
Could anyone assist with a diagram indicating the pin numbering on the MP9 throttle body.
| 2006 VW Polo Classic 1.9TDi ...Tow Car... | ? ? ? ? ? ? ...Weekend Warrior... | 2005 Honda CBX250 Twister ...Daily... |
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Fri Mar 04, 2011 7:08 am
Here's the diagram I used when wiring my Dicktator, the MP9 part should be the same...
Current rides:
MhVW
Membership No: 1466
Post by MhVW » Fri Mar 04, 2011 7:37 am
I'm actually looking for a diagram showing the pin locations on the MP9 throttle body, the one with the stepper motor.
MhVW wrote:I need to connect the TPS signals to pins 4 - earth, 5 - signal and 7 - 5V. As per the diagram above.
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Fri Mar 04, 2011 7:40 am
MhVW wrote:I'm actually looking for a diagram showing the pin locations on the MP9 throttle body, the one with the stepper motor.
Top tip - You'll see I've included the MP9 wire colors as well so if you put in a bit of effort you'll be able to see which pin goes where...
Current rides:
MhVW
Membership No: 1466
Post by MhVW » Fri Mar 04, 2011 8:22 am
Torker wrote:Top tip - You'll see I've included the MP9 wire colors as well so if you put in a bit of effort you'll be able to see which pin goes where...
Thanx for the top tip, but I never mentioned that I've got a harness... :bang: :bang: :bang:
Rendering your top tip useless... :bang: :bang: :bang:
I've got no plug nor wiring as as referernce, thus the need for the pin locations on the MP9 throttle body.
Need to solder the wires to the throttle body until I can do it properly. :crazy:
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Fri Mar 04, 2011 12:42 pm
You know what, I've got all the info you need but you can seeing that you've got that sort of an attitude with somebody that is trying to help you, you can get stuffed... :moon:
Current rides:
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Fri Mar 04, 2011 2:04 pm
What i did was remove the whole mp9 harness,comp box and sell (easily get R 1000 for it). Keep injector harness and get a tp100 wiring harness from GW for R 150 or so, and wire it like the dicktator/(gotech) manual tells you to. Much easier and you get some money back!!
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
MhVW
Membership No: 1466
Post by MhVW » Fri Mar 04, 2011 5:49 pm
Torker wrote:You know what, I've got all the info you need but you can seeing that you've got that sort of an attitude with somebody that is trying to help you, you can get stuffed... :moon:
Excuse my ignorance, but would you please care to explain how your table would be of any help.
You're referencing MP9 ECU pin-outs, associated wire color codes and function with the wire color codes and pin-outs of the Dicktator EFI unit.
I don't have any MP9 wiring on the car. It's originaly a carb model. Further more I don't have the MP9 throttle body plug or part of the harness. I only have the MP9 throttle body and my management.
graham savage
Car Model: Caddy's, Mk2's, Mk4, Ford etc
Membership No: 803
Post by graham savage » Sat Mar 05, 2011 9:19 am
Then Why be asking for a MP9 diagram? You have nothing MP9 but ask for MP9 info??? Ask for help wiring slotech onto MP9 throttle body... give the right info in the beginning and get the right info in the end... how must we know what you have or have not?
Better yet, seeing as though you are such a clever ****, why not measure the resistance/voltages on the TB like it tells you to do in the slotech manual, All you are looking for is the TPS signal... WHICH you don't really need but then again who's to say you have a multimeter or know how to use it?
https://www.facebook.com/groups/TeamGoldwagen/
[url]http://www.vwchallenge.co,za[/url]
Quik-Trix
Membership No: 3004
Post by Quik-Trix » Sat Mar 05, 2011 11:58 am
MhVW wrote:Could anyone assist with a diagram indicating the pin numbering on the MP9 throttle body.
Maybe this might help
MhVW
Membership No: 1466
Post by MhVW » Mon Mar 07, 2011 8:23 am
*snip*
Thanx, Quik-Trix
That's exactly what I asked for from the start.
I've already managed to figure it out, but this is a good illustration of the pin numbering on the MP9 throttle body.
Post by panic-mechanic » Mon Mar 07, 2011 8:54 am
5,7,8 is the tps wires.
'07 Audi A4 2l TDI
MhVW
Membership No: 1466
Post by MhVW » Mon Mar 07, 2011 10:09 am
panic-mechanic wrote:5,7,8 is the tps wires.
According to the table posted earlier pin-8 is the "closed throttle position switch" and the Gotech wiring diagram before that indicates TPS on pins-4,5,7.
I picked up the TPS on 4,5,7.
But will go test to pin-8 as well, could've made a mistake.
Post by panic-mechanic » Mon Mar 07, 2011 10:57 am
I have seen the guys use 4,5,7. It really is only one of the common earths that change. 5,7 is the pins with the resistance over it. The other is 'ground'.
'07 Audi A4 2l TDI
MhVW
Membership No: 1466
Post by MhVW » Mon Mar 07, 2011 11:41 am
panic-mechanic wrote:I have seen the guys use 4,5,7. It really is only one of the common earths that change. 5,7 is the pins with the resistance over it. The other is 'ground'.
Thanx, will check it out for interest sake.
