G cam
- Car Model: MK1 2.0 8v
G cam
What is the difference between a g-cam and a estas cam or 276,288...
and will it work on a mp9 head?
Will it make a power difference?
"Life is much like going to the gym. The most painful part is deciding to go, once you get past that........IT' EASY!!!"
- Post Whore
- Car Model: boat
- Membership No: 1133
Re: G cam
Will it make bigger power than the standard cam?
What is a standard cams degrees?
- Post Whore
- Car Model: boat
- Colonel
- Membership No: 1041
Re: G cam
what cam is on the car currently, the mp9 heads normally come with a A-cam and IIRC its the same profile as the G-cam.
also the g-cam might not fit on the mp9 head because some of them took 4 cam caps.
Re: G cam
Well its a standard cam that came with the mp9 head.
So actually I'll do better if I sell the G-cam and get a case of beers and get vrot, because I got a raw deal!
- Colonel
- Registered for: 20 years 9 months
- Car Model: 2010 Golf MK6 TSi
Re: G cam
Totally irrelevant, cams are identical regardless if the head had 4 or 5 cam caps, and can be swapped from head to anotherUDC wrote:also the g-cam might not fit on the mp9 head because some of them took 4 cam caps.
- Colonel
Re: G cam
g cam is very mild cam, when my car was carb I fitted a g cam and expected a huge difference but it wasn't so, it did make a differnence but very slight.
when I tried fitting my the g cam from my carb head after my mp9 conversion, it did not fit due to head not accommodating the journal for 5th cam cap
Re: G cam
The hydraulic cam variants works as follows:
026 G = 1.8 K-jet (4 bearing head)
026 A = 2.0 Digifant (ditto)
026 L = 1.8 carb (ditto)
026 AF = 1.4 MP9 (ditto)
037 D = 1.6/1.8 MP9 (5 bearing head)
The G, A and D has the same profile and lobe separation. The difference between them being that the keyway position of A and G differs and D has 5 journals. The profile of L and AF is identical; keyway position differs.
Lift curve comparison between G (A, D) and AF (L).
Lift curve comparison between G (A, D), Estas 268 and Estas 276.
Cam "cards":
AF
G
268
and 276.
I hope this helps.
Cam "cards":
AF
G
268
and 276.
I hope this helps.
- zain_c
Re: G cam
the G-cam works with the mp9 head...i've heard and know numerous guys running G-cam's in the Velociti's and Citi.Com...my opinion. Dont waste your time with a G-cam...they claim they kwik till my 272 starts talking. ESTA's FTW!!!! I got a 272deg Esta's...it rocks!
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: G cam
[quote="Nellis"]The hydraulic cam variants works as follows:
Thanx Nellis, this i what Iwanted to know
I was given the g-cam so I might as well use it.
- Car Model: Caddy AGG 2L Carb
- General
- Car Model: MKV .:R32
- Membership No: 1227
Re: G cam
You beat me to itNellis wrote:Neither of them; the 026 L is used in the 1600 HM engine.caddy club wrote:And what about the 1.6 carb is it also using A or G cam
MKV Golf .:R32
Project :83' MK GTI aka "The Phantom"
BMW 130i
MK VI GTI DSG
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
- General
Re: G cam
Nellis wrote:...next time I'll wait longer..De@n wrote:
You beat me to it
Thanks for the info dude.
Learnt the above as I am sitting with 2 G-cams and an "L" cam.
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: G cam
This is good but what is the profiles is what i want...
A cam, is it 252, if so what is bcam etc.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Post Whore
- Car Model: boat
- Post Whore
- Car Model: boat
